    MMM-Fuel
    fuel pricegas stationpetrol stationvoice-controltankerkoenigspritpreisrechnernsw
    178 Posts 48 Posters 586.1k Views 48 Watching
      sdetweil @Stefan_TR96
      @Stefan_TR96 did u run npm install in the module folders with a package.json file? u need to
        Stefan_TR96 @sdetweil
        @sdetweil said in MMM-Fuel:
        tried to install it again and got following warning:
        npm WARN stylelint-config-standard@16.0.0 requires a peer of stylelint@^7.8.0 but none is installed. You must install peer dependencies yourself.
          @Stefan_TR96 that’s just a warning
            Stefan_TR96
            @cowboysdude if I type the generated url manually to the browser, I get the data
              @Stefan_TR96 >tried to install it again and got following warning:
              what is ‘it’…
              the module may need updating after MM was updated…
              do
              cd ~/MagicMirror/modules/MMM-Fuel
              npm install
                Stefan_TR96
                @sdetweil i did de install again (changed to MM-Fuel directory and did sudo npm install) as you wrote and got the warning i posted
                  @Stefan_TR96 said in MMM-Fuel:
                  sudo
                  never sudo
                    Stefan_TR96
                    @sdetweil same results without sudo
                      @Stefan_TR96 yes, does mm run? Do you get output?
                        Stefan_TR96
                        @sdetweil yes, mirror and all other modules are running without any errors … just mmm-fuel is displaying loading
                          @Stefan_TR96 open the developers window, ctrl-shift-i on the keyboard, select the console tab and scroll up to see any errors.
                          You can filter by module, by placing part of the module name in the filter field.
                            Stefan_TR96
                            is there any possibility to control this without a physical keybord? I’m just able to connect via Remote desktop or ssh? Thx for your help, I’m a complete beginner
                            • strawberry 3.141S
                              I just released version 2.0.2
                              Added
                              • French Translations
                              • Clarification for config option updateInterval in readme
                              Changed
                              • Dependency Update
                              Removed
                              • Github pages
                              https://github.com/fewieden/MMM-fuel
                              [card:fewieden/MMM-Fuel]
                                Cetax @strawberry 3.141
                                @strawberry-3-141 Hi,
                                is there a way to hide the distance?
                                Can you tell me where I can comment that out?
                                Thank you for your help.
                                greeting
                                Stefan
                                • strawberry 3.141S
                                  strawberry 3.141 Project Sponsor Module Developer @Cetax
                                  @Cetax add this in your custom.css file at ~/MagicMirror/css/custom.css
                                  .MMM-Fuel th:nth-child(3), .MMM-Fuel td:nth-child(3) {
                                      display: none;
                                    @strawberry-3-141 said in MMM-Fuel:
                                    display: none;
                                    Yeah… :ok_hand:
                                    thank u very much… Thats cool :thumbs_up:
                                    • strawberry 3.141S
                                      The map modal was broken for quite some time, I managed to make it work again and switched to MMM-Modal at the same time.
                                      [2.1.0]
                                      Changed
                                      • Using MMM-Modal to display modals like gas station and voice commands.
                                      https://github.com/fewieden/MMM-Fuel
                                      • StoffbeuteluweS
                                        Stoffbeuteluwe Project Sponsor @strawberry 3.141
                                        is it possible to change the name from E5 to Super?
                                        • strawberry 3.141S
                                          strawberry 3.141 Project Sponsor Module Developer @Stoffbeuteluwe
                                          @Stoffbeuteluwe to not touch any source files of the module you can add the following to the custom.css file
                                          .MMM-Fuel th:nth-child(2) span { /* Replace 2 with the correct column */
                                              visibility: hidden;
                                          .MMM-Fuel th:nth-child(2) span:after { /* Replace 2 with the correct column */
                                              visibility: visible;
                                              content: "Super";
                                              margin-left: -21px; /* Pixels that the original text occupies */
                                          StoffbeuteluweS 1 Reply Last reply Reply Quote 1
                                          • StoffbeuteluweS
                                            @strawberry-3-141 Oh Perfect thank you very much
                                            • 8 / 9
