    MMM-Fuel
    fuel pricegas stationpetrol stationvoice-controltankerkoenigspritpreisrechnernsw
    178 Posts 48 Posters 589.7k Views 48 Watching
      Stefan_TR96 @sdetweil
      @sdetweil said in MMM-Fuel:
      @Stefan_TR96 did u run npm install in the module folders with a package.json file? u need to
      tried to install it again and got following warning:
      npm WARN stylelint-config-standard@16.0.0 requires a peer of stylelint@^7.8.0 but none is installed. You must install peer dependencies yourself.
        sdetweil @Stefan_TR96
        @Stefan_TR96 that’s just a warning
          Stefan_TR96
          @cowboysdude if I type the generated url manually to the browser, I get the data
            @Stefan_TR96 >tried to install it again and got following warning:
            what is ‘it’…
            the module may need updating after MM was updated…
            do
            cd ~/MagicMirror/modules/MMM-Fuel
            npm install
              Stefan_TR96
              @sdetweil i did de install again (changed to MM-Fuel directory and did sudo npm install) as you wrote and got the warning i posted
                @Stefan_TR96 said in MMM-Fuel:
                sudo
                never sudo
                  Stefan_TR96
                  @sdetweil same results without sudo
                    @Stefan_TR96 yes, does mm run? Do you get output?
                      Stefan_TR96
                      @sdetweil yes, mirror and all other modules are running without any errors … just mmm-fuel is displaying loading
                        @Stefan_TR96 open the developers window, ctrl-shift-i on the keyboard, select the console tab and scroll up to see any errors.
                        You can filter by module, by placing part of the module name in the filter field.
                          Stefan_TR96
                          is there any possibility to control this without a physical keybord? I’m just able to connect via Remote desktop or ssh? Thx for your help, I’m a complete beginner
                          • strawberry 3.141S
                            I just released version 2.0.2
                            Added
                            • French Translations
                            • Clarification for config option updateInterval in readme
                            Changed
                            • Dependency Update
                            Removed
                            • Github pages
                            https://github.com/fewieden/MMM-fuel
                            [card:fewieden/MMM-Fuel]
                            C 1 Reply Last reply
                              Cetax @strawberry 3.141
                              @strawberry-3-141 Hi,
                              is there a way to hide the distance?
                              Can you tell me where I can comment that out?
                              Thank you for your help.
                              greeting
                              Stefan
                              • strawberry 3.141S
                                strawberry 3.141 Project Sponsor Module Developer @Cetax
                                @Cetax add this in your custom.css file at ~/MagicMirror/css/custom.css
                                .MMM-Fuel th:nth-child(3), .MMM-Fuel td:nth-child(3) {
                                    display: none;
                                  @strawberry-3-141 said in MMM-Fuel:
                                  display: none;
                                  Yeah… :ok_hand:
                                  thank u very much… Thats cool :thumbs_up:
                                  • strawberry 3.141S
                                    The map modal was broken for quite some time, I managed to make it work again and switched to MMM-Modal at the same time.
                                    [2.1.0]
                                    Changed
                                    • Using MMM-Modal to display modals like gas station and voice commands.
                                    https://github.com/fewieden/MMM-Fuel
                                    StoffbeuteluweS 1 Reply Last reply
                                    • StoffbeuteluweS
                                      Stoffbeuteluwe Project Sponsor @strawberry 3.141
                                      is it possible to change the name from E5 to Super?
                                      • strawberry 3.141S
                                        strawberry 3.141 Project Sponsor Module Developer @Stoffbeuteluwe
                                        @Stoffbeuteluwe to not touch any source files of the module you can add the following to the custom.css file
                                        .MMM-Fuel th:nth-child(2) span { /* Replace 2 with the correct column */
                                            visibility: hidden;
                                        .MMM-Fuel th:nth-child(2) span:after { /* Replace 2 with the correct column */
                                            visibility: visible;
                                            content: "Super";
                                            margin-left: -21px; /* Pixels that the original text occupies */
                                        • StoffbeuteluweS
                                          @strawberry-3-141 Oh Perfect thank you very much
                                          • strawberry 3.141S
                                            [2.1.1]
                                            Fixed
                                            • Wrong value in config option sortBy no longer keeps module in state loading forever.
                                            • 8 / 9
