    MMM-Fuel
    fuel pricegas stationpetrol stationvoice-controltankerkoenigspritpreisrechnernsw
    178 Posts 48 Posters 586.1k Views 48 Watching
      Stefan_TR96
      @cowboysdude if I type the generated url manually to the browser, I get the data
        sdetweil @Stefan_TR96
        @Stefan_TR96 >tried to install it again and got following warning:
        what is ‘it’…
        the module may need updating after MM was updated…
        do
        cd ~/MagicMirror/modules/MMM-Fuel
        npm install
          Stefan_TR96
          @sdetweil i did de install again (changed to MM-Fuel directory and did sudo npm install) as you wrote and got the warning i posted
            @Stefan_TR96 said in MMM-Fuel:
            sudo
            never sudo
              Stefan_TR96
              @sdetweil same results without sudo
                @Stefan_TR96 yes, does mm run? Do you get output?
                  Stefan_TR96
                  @sdetweil yes, mirror and all other modules are running without any errors … just mmm-fuel is displaying loading
                    @Stefan_TR96 open the developers window, ctrl-shift-i on the keyboard, select the console tab and scroll up to see any errors.
                    You can filter by module, by placing part of the module name in the filter field.
                      Stefan_TR96
                      is there any possibility to control this without a physical keybord? I’m just able to connect via Remote desktop or ssh? Thx for your help, I’m a complete beginner
                      • strawberry 3.141S
                        I just released version 2.0.2
                        Added
                        • French Translations
                        • Clarification for config option updateInterval in readme
                        Changed
                        • Dependency Update
                        Removed
                        • Github pages
                        https://github.com/fewieden/MMM-fuel
                        [card:fewieden/MMM-Fuel]
                          Cetax @strawberry 3.141
                          @strawberry-3-141 Hi,
                          is there a way to hide the distance?
                          Can you tell me where I can comment that out?
                          Thank you for your help.
                          greeting
                          Stefan
                          • strawberry 3.141S
                            strawberry 3.141 Project Sponsor Module Developer @Cetax
                            @Cetax add this in your custom.css file at ~/MagicMirror/css/custom.css
                            .MMM-Fuel th:nth-child(3), .MMM-Fuel td:nth-child(3) {
                                display: none;
                              @strawberry-3-141 said in MMM-Fuel:
                              display: none;
                              Yeah… :ok_hand:
                              thank u very much… Thats cool :thumbs_up:
                              • strawberry 3.141S
                                The map modal was broken for quite some time, I managed to make it work again and switched to MMM-Modal at the same time.
                                [2.1.0]
                                Changed
                                • Using MMM-Modal to display modals like gas station and voice commands.
                                https://github.com/fewieden/MMM-Fuel
                                • StoffbeuteluweS
                                  Stoffbeuteluwe Project Sponsor @strawberry 3.141
                                  is it possible to change the name from E5 to Super?
                                  • strawberry 3.141S
                                    strawberry 3.141 Project Sponsor Module Developer @Stoffbeuteluwe
                                    @Stoffbeuteluwe to not touch any source files of the module you can add the following to the custom.css file
                                    .MMM-Fuel th:nth-child(2) span { /* Replace 2 with the correct column */
                                        visibility: hidden;
                                    .MMM-Fuel th:nth-child(2) span:after { /* Replace 2 with the correct column */
                                        visibility: visible;
                                        content: "Super";
                                        margin-left: -21px; /* Pixels that the original text occupies */
                                    StoffbeuteluweS 1 Reply Last reply Reply Quote 1
                                    • StoffbeuteluweS
                                      @strawberry-3-141 Oh Perfect thank you very much
                                      • strawberry 3.141S
                                        [2.1.1]
                                        Fixed
                                        • Wrong value in config option sortBy no longer keeps module in state loading forever.
                                          Pielo
                                          when i set the shortenText-Function on true, then comes the first lettern only. When I set this function on false, than is the module to wide.
                                          What can i do? Can I set the size of this modul?
                                          alt text
                                          • strawberry 3.141S
                                            strawberry 3.141 Project Sponsor Module Developer @Pielo
                                            @Pielo the documentation states that you need to provide an integer of how many character you want to see, the value false is just to deactivate the behavior.
                                            Option          Default Description
                                            shortenText	false	Integer of characters to be shown for name and address. Default shows all.
                                            If you do shortenText: 5, then it will show 5 characters and shortenText: 10 will show 10 and so on
                                            • 8 / 9
