    MMM-Fuel
    fuel pricegas stationpetrol stationvoice-controltankerkoenigspritpreisrechnernsw
    178 Posts 48 Posters 589.6k Views 48 Watching
    • strawberry 3.141S
      The map modal was broken for quite some time, I managed to make it work again and switched to MMM-Modal at the same time.
      [2.1.0]
      Changed
      • Using MMM-Modal to display modals like gas station and voice commands.
      https://github.com/fewieden/MMM-Fuel
      [card:fewieden/MMM-Fuel]
      StoffbeuteluweS 1 Reply Last reply
      • StoffbeuteluweS
        Stoffbeuteluwe Project Sponsor @strawberry 3.141
        @strawberry-3-141 Hi,
        is it possible to change the name from E5 to Super?
        • strawberry 3.141S
          strawberry 3.141 Project Sponsor Module Developer @Stoffbeuteluwe
          @Stoffbeuteluwe to not touch any source files of the module you can add the following to the custom.css file
          .MMM-Fuel th:nth-child(2) span { /* Replace 2 with the correct column */
              visibility: hidden;
          .MMM-Fuel th:nth-child(2) span:after { /* Replace 2 with the correct column */
              visibility: visible;
              content: "Super";
              margin-left: -21px; /* Pixels that the original text occupies */
          • StoffbeuteluweS
            @strawberry-3-141 Oh Perfect thank you very much
            • strawberry 3.141S
              [2.1.1]
              Fixed
              • Wrong value in config option sortBy no longer keeps module in state loading forever.
                Pielo
                when i set the shortenText-Function on true, then comes the first lettern only. When I set this function on false, than is the module to wide.
                What can i do? Can I set the size of this modul?
                alt text
                • strawberry 3.141S
                  strawberry 3.141 Project Sponsor Module Developer @Pielo
                  @Pielo the documentation states that you need to provide an integer of how many character you want to see, the value false is just to deactivate the behavior.
                  Option          Default Description
                  shortenText	false	Integer of characters to be shown for name and address. Default shows all.
                  If you do shortenText: 5, then it will show 5 characters and shortenText: 10 will show 10 and so on
                  • strawberry 3.141S
                    Version 2.1.2
                    Added
                    • Config option showDistance https://github.com/fewieden/MMM-Fuel/pull/49
                    • Missing jsdoc documentation
                    Changed
                    • Dependency update
                    Fixed
                    • Deinit map had a hardcoded index for markers.
                    Reply Quote 2
                    • strawberry 3.141S
                      strawberry 3.141 Project Sponsor Module Developer @strawberry 3.141
                      Version 2.2.0
                      Thanks to @TheDuffman85 for his contribution to this release. This version allows either to search by radius, specific station, or a combination of those two for provider Tankerkönig (Germany).
                      Added
                      • Config option stationIds to check prices of specific gas stations (Tankerkönig only)
                      • Github actions
                      Changed
                      • 3rd decimal is now superscripted
                      • Price and distance values are now localized based on global config option locale.
                      Removed
                      • Travis-CI integration
                      [card: fewieden/MMM-Fuel]
                        RIKKO14
                        Does this module work for France?
                        • eniacE
                          eniac
                          Hello … getting this Error with npm start DEV
                          [17:08:01.452] [LOG] Error: Error no fuel station detail
                          at setStationInfos (/home/pi/MagicMirror/modules/MMM-Fuel/apis/tankerkoenig.js:189:19)
                          at process._tickCallback (internal/process/next_tick.js:68:7)
                              module: "MMM-Fuel",
                          	//provider: "tankerkoenig",
                                  api_key: "xxxxxxxxxxxxxxxxxxxxxx",
                          	lat: 50.873798,
                                  lng: 8.023410,
                                  types: ["E5"],
                          	updateInterval: 60000,
                          	stationIds:
                              "id": "9ac83212-c785-476f-9862-34a4b04f6320",
                              "name": "BELL Oil",
                          What could that be ?
                          • strawberry 3.141S
                            @RIKKO14 currently this module only supports Germany, Austria and NSW in Australia.
                            If you find an API for data in France the module can be expanded. A guide can be found here.
                            @eniac there are a couple of issues.
                            1. You have the wrong format for the stationIds. It should be stationIds: ["9ac83212-c785-476f-9862-34a4b04f6320"].
                            2. I suggest not going lower than the default update interval of 15min. You currently fetch data every minute, which can lead to a suspension of your API key as other users experienced before. Also see limitations here https://creativecommons.tankerkoenig.de/terms
                            3. The fuel type should be lowercase
                            4. The fuel station id you tried is inside the default search radius. There seems to be a bug currently, where we still make a request even if the list is empty. I suggest to either disable the radius search or remove the station ids.
                              module: "MMM-Fuel",
                                api_key: "XXXXXXXXXXXX",
                                lat: 50.873798,
                                lng: 8.023410,
                                types: ["e5"],
                                stationIds: ["9ac83212-c785-476f-9862-34a4b04f6320"],
                                radius: 0
                              module: "MMM-Fuel",
                                lat: 50.873798,
                                lng: 8.023410,
                                types: ["e5"]
                            C 1 Reply Last reply
                            • strawberry 3.141S
                              Version 2.2.1
                              Fixed
                              • Filtering of station ids lead to invalid price request for provider tankerkoenig
                              Changed
                              • Log a warning if no fuel station detail could be fetched
                              • Updated provider integration documentation
                                codac
                                With the new update of MM I’m getting the following error:
                                0|mm       | [15.04.2021 14:11.21.945] [ERROR] (node:15096) UnhandledPromiseRejectionWarning: Error: Cannot find module 'geolib'
                                0|mm       | Require stack:
                                0|mm       | - /home/pi/MagicMirror/modules/MMM-Fuel/apis/tankerkoenig.js
                                0|mm       | - /home/pi/MagicMirror/modules/MMM-Fuel/node_helper.js
                                0|mm       | - /home/pi/MagicMirror/js/app.js
                                0|mm       | - /home/pi/MagicMirror/js/electron.js
                                0|mm       | - /home/pi/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js
                                  Commander @strawberry 3.141
                                  @strawberry-3-141
                                  Hello, i want to check prices of only 3 specific gas stations, but it doesn`t work.
                                  code_text:
                                                 api_key: "XXXXXXXXXXXXX-XXX-XXXX-XXXXXXXXXXXX",
                                                 types: ["e5"],
                                         	       rotate: true,
                                         	       showDistance:false,
                                         	       lat: 50.8634,
                                                 lng: 8.03944,
                                                 stationIds: ["238715f9-60d6-4f7a-9e74-c40fdb71a79d"],
                                                 radius: 0,
                                         	       lat: 50.8708534,
                                                 lng: 8.014519,
                                                 stationIds: ["1b41801e-ee5e-490e-86d6-474bafec5dc4"],
                                                 radius: 0,
                                         	       lat: 50.871715,
                                         	       lng: 8.012415,
                                                 stationIds: ["4b9763df-8cce-426f-a1d5-2b44d413550a"],
                                                 radius: 0,
                                                 // all your config options, which are different than their default values
                                  I try to set stationIds like that:
                                  stationIds: ["238715f9-60d6-4f7a-9e74-c40fdb71a79d,1b41801e-ee5e-490e-86d6-474bafec5dc4,4b9763df-8cce-426f-a1d5-2b44d413550a"],
                                  but it also doesn`t work.
                                  Could you explaine how set specific gas stations?
                                  JalibuJ 1 Reply Last reply
                                  • JalibuJ
                                    Jalibu Module Developer @Commander
                                    @commander said in MMM-Fuel:
                                    stationIds: [“238715f9-60d6-4f7a-9e74-c40fdb71a79d,1b41801e-ee5e-490e-86d6-474bafec5dc4,4b9763df-8cce-426f-a1d5-2b44d413550a”],
                                    try
                                    stationIds: ["238715f9-60d6-4f7a-9e74-c40fdb71a79d", "1b41801e-ee5e-490e-86d6-474bafec5dc4", "4b9763df-8cce-426f-a1d5-2b44d413550a"],
                                      Commander @Jalibu
                                      @jalibu said in MMM-Fuel:
                                      stationIds: [“238715f9-60d6-4f7a-9e74-c40fdb71a79d”, “1b41801e-ee5e-490e-86d6-474bafec5dc4”, “4b9763df-8cce-426f-a1d5-2b44d413550a”],
                                      Oh yes tanks !
                                        Seansation
                                        is it possible to sort by distance without rotation?
                                        			module: "MMM-Fuel",
                                        				api_key: "my_key",
                                        				showAddress: false,
                                        				rotate: false,
                                        				lat: my_lat,
                                        				lng: my_lng,
                                        				shortenText: false,
                                        				types: ["e5"],
                                        				sortBy: "e5", //possible to sort by distance? e.g. sortBy: "distance"
                                        Thank you
                                        • strawberry 3.141S
                                          strawberry 3.141 Project Sponsor Module Developer @Seansation
                                          @seansation this is currently not supported, feel free to send a pr.
                                          • strawberry 3.141S
                                            Now also supporting fuel prices in the USA. Take a look at https://github.com/cowboysdude/MMM-Gas for different style of the same information.
                                            2.3.0
                                            MagicMirror² version >= 2.15.0 required.
                                            Added
                                            • Provider: autoblog
                                            • Config option: showBrand
                                            • Integrated MagicMirror logger on server side
                                            • Dependency: node-html-parser
                                            • Config option excludeStationIds to exclude gas stations from radius (Tankerkönig only)
                                            Changed
                                            • Updated Github config files
                                            • Updated dependencies
                                            Removed
                                            • Dependency: fs-extra
                                            • Dependency: geolib
                                            Link to module https://github.com/fewieden/MMM-Fuel
                                            Reply Quote 2
                                            • 8 / 9
