    MMM-Fuel
    fuel pricegas stationpetrol stationvoice-controltankerkoenigspritpreisrechnernsw
    178 Posts 48 Posters 586.1k Views 48 Watching
    • strawberry 3.141S
      I just released version 2.0.2
      Added
      • French Translations
      • Clarification for config option updateInterval in readme
      Changed
      • Dependency Update
      Removed
      • Github pages
      https://github.com/fewieden/MMM-fuel
      [card:fewieden/MMM-Fuel]
        Cetax @strawberry 3.141
        @strawberry-3-141 Hi,
        is there a way to hide the distance?
        Can you tell me where I can comment that out?
        Thank you for your help.
        greeting
        Stefan
        • strawberry 3.141S
          strawberry 3.141 Project Sponsor Module Developer @Cetax
          @Cetax add this in your custom.css file at ~/MagicMirror/css/custom.css
          .MMM-Fuel th:nth-child(3), .MMM-Fuel td:nth-child(3) {
              display: none;
            @strawberry-3-141 said in MMM-Fuel:
            display: none;
            Yeah… :ok_hand:
            thank u very much… Thats cool :thumbs_up:
            • strawberry 3.141S
              The map modal was broken for quite some time, I managed to make it work again and switched to MMM-Modal at the same time.
              [2.1.0]
              Changed
              • Using MMM-Modal to display modals like gas station and voice commands.
              https://github.com/fewieden/MMM-Fuel
              • StoffbeuteluweS
                Stoffbeuteluwe Project Sponsor @strawberry 3.141
                is it possible to change the name from E5 to Super?
                • strawberry 3.141S
                  strawberry 3.141 Project Sponsor Module Developer @Stoffbeuteluwe
                  @Stoffbeuteluwe to not touch any source files of the module you can add the following to the custom.css file
                  .MMM-Fuel th:nth-child(2) span { /* Replace 2 with the correct column */
                      visibility: hidden;
                  .MMM-Fuel th:nth-child(2) span:after { /* Replace 2 with the correct column */
                      visibility: visible;
                      content: "Super";
                      margin-left: -21px; /* Pixels that the original text occupies */
                  StoffbeuteluweS 1 Reply Last reply Reply Quote 1
                  • StoffbeuteluweS
                    @strawberry-3-141 Oh Perfect thank you very much
                    • strawberry 3.141S
                      [2.1.1]
                      Fixed
                      • Wrong value in config option sortBy no longer keeps module in state loading forever.
                        Pielo
                        when i set the shortenText-Function on true, then comes the first lettern only. When I set this function on false, than is the module to wide.
                        What can i do? Can I set the size of this modul?
                        alt text
                        • strawberry 3.141S
                          strawberry 3.141 Project Sponsor Module Developer @Pielo
                          @Pielo the documentation states that you need to provide an integer of how many character you want to see, the value false is just to deactivate the behavior.
                          Option          Default Description
                          shortenText	false	Integer of characters to be shown for name and address. Default shows all.
                          If you do shortenText: 5, then it will show 5 characters and shortenText: 10 will show 10 and so on
                          • strawberry 3.141S
                            Version 2.1.2
                            Added
                            • Config option showDistance https://github.com/fewieden/MMM-Fuel/pull/49
                            • Missing jsdoc documentation
                            Changed
                            • Dependency update
                            Fixed
                            • Deinit map had a hardcoded index for markers.
                            strawberry 3.141S 1 Reply Last reply Reply Quote 2
                            • strawberry 3.141S
                              strawberry 3.141 Project Sponsor Module Developer @strawberry 3.141
                              Version 2.2.0
                              Thanks to @TheDuffman85 for his contribution to this release. This version allows either to search by radius, specific station, or a combination of those two for provider Tankerkönig (Germany).
                              Added
                              • Config option stationIds to check prices of specific gas stations (Tankerkönig only)
                              • Github actions
                              Changed
                              • 3rd decimal is now superscripted
                              • Price and distance values are now localized based on global config option locale.
                              Removed
                              • Travis-CI integration
                              [card: fewieden/MMM-Fuel]
                                RIKKO14
                                Does this module work for France?
                                • eniacE
                                  eniac
                                  Hello … getting this Error with npm start DEV
                                  [17:08:01.452] [LOG] Error: Error no fuel station detail
                                  at setStationInfos (/home/pi/MagicMirror/modules/MMM-Fuel/apis/tankerkoenig.js:189:19)
                                  at process._tickCallback (internal/process/next_tick.js:68:7)
                                      module: "MMM-Fuel",
                                  	//provider: "tankerkoenig",
                                          api_key: "xxxxxxxxxxxxxxxxxxxxxx",
                                  	lat: 50.873798,
                                          lng: 8.023410,
                                          types: ["E5"],
                                  	updateInterval: 60000,
                                  	stationIds:
                                      "id": "9ac83212-c785-476f-9862-34a4b04f6320",
                                      "name": "BELL Oil",
                                  What could that be ?
                                  • strawberry 3.141S
                                    @RIKKO14 currently this module only supports Germany, Austria and NSW in Australia.
                                    If you find an API for data in France the module can be expanded. A guide can be found here.
                                    @eniac there are a couple of issues.
                                    1. You have the wrong format for the stationIds. It should be stationIds: ["9ac83212-c785-476f-9862-34a4b04f6320"].
                                    2. I suggest not going lower than the default update interval of 15min. You currently fetch data every minute, which can lead to a suspension of your API key as other users experienced before. Also see limitations here https://creativecommons.tankerkoenig.de/terms
                                    3. The fuel type should be lowercase
                                    4. The fuel station id you tried is inside the default search radius. There seems to be a bug currently, where we still make a request even if the list is empty. I suggest to either disable the radius search or remove the station ids.
                                      module: "MMM-Fuel",
                                        api_key: "XXXXXXXXXXXX",
                                        lat: 50.873798,
                                        lng: 8.023410,
                                        types: ["e5"],
                                        stationIds: ["9ac83212-c785-476f-9862-34a4b04f6320"],
                                        radius: 0
                                      module: "MMM-Fuel",
                                        lat: 50.873798,
                                        lng: 8.023410,
                                        types: ["e5"]
                                    • strawberry 3.141S
                                      Version 2.2.1
                                      Fixed
                                      • Filtering of station ids lead to invalid price request for provider tankerkoenig
                                      Changed
                                      • Log a warning if no fuel station detail could be fetched
                                      • Updated provider integration documentation
                                        codac
                                        With the new update of MM I’m getting the following error:
                                        0|mm       | [15.04.2021 14:11.21.945] [ERROR] (node:15096) UnhandledPromiseRejectionWarning: Error: Cannot find module 'geolib'
                                        0|mm       | Require stack:
                                        0|mm       | - /home/pi/MagicMirror/modules/MMM-Fuel/apis/tankerkoenig.js
                                        0|mm       | - /home/pi/MagicMirror/modules/MMM-Fuel/node_helper.js
                                        0|mm       | - /home/pi/MagicMirror/js/app.js
                                        0|mm       | - /home/pi/MagicMirror/js/electron.js
                                        0|mm       | - /home/pi/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js
                                          Commander @strawberry 3.141
                                          @strawberry-3-141
                                          Hello, i want to check prices of only 3 specific gas stations, but it doesn`t work.
                                          code_text:
                                                         api_key: "XXXXXXXXXXXXX-XXX-XXXX-XXXXXXXXXXXX",
                                                         types: ["e5"],
                                                 	       rotate: true,
                                                 	       showDistance:false,
                                                 	       lat: 50.8634,
                                                         lng: 8.03944,
                                                         stationIds: ["238715f9-60d6-4f7a-9e74-c40fdb71a79d"],
                                                         radius: 0,
                                                 	       lat: 50.8708534,
                                                         lng: 8.014519,
                                                         stationIds: ["1b41801e-ee5e-490e-86d6-474bafec5dc4"],
                                                         radius: 0,
                                                 	       lat: 50.871715,
                                                 	       lng: 8.012415,
                                                         stationIds: ["4b9763df-8cce-426f-a1d5-2b44d413550a"],
                                                         radius: 0,
                                                         // all your config options, which are different than their default values
                                          I try to set stationIds like that:
                                          stationIds: ["238715f9-60d6-4f7a-9e74-c40fdb71a79d,1b41801e-ee5e-490e-86d6-474bafec5dc4,4b9763df-8cce-426f-a1d5-2b44d413550a"],
                                          but it also doesn`t work.
                                          Could you explaine how set specific gas stations?
                                          JalibuJ 1 Reply Last reply Reply Quote 0
                                          • JalibuJ
                                            Jalibu Module Developer @Commander
                                            @commander said in MMM-Fuel:
                                            stationIds: [“238715f9-60d6-4f7a-9e74-c40fdb71a79d,1b41801e-ee5e-490e-86d6-474bafec5dc4,4b9763df-8cce-426f-a1d5-2b44d413550a”],
                                            try
                                            stationIds: ["238715f9-60d6-4f7a-9e74-c40fdb71a79d", "1b41801e-ee5e-490e-86d6-474bafec5dc4", "4b9763df-8cce-426f-a1d5-2b44d413550a"],
                                            • 8 / 9
