    MMM-Fuel
    fuel pricegas stationpetrol stationvoice-controltankerkoenigspritpreisrechnernsw
    178 Posts 48 Posters 579.6k Views 48 Watching
      Stefan_TR96
      @sdetweil same results without sudo
        sdetweil @Stefan_TR96
        @Stefan_TR96 yes, does mm run? Do you get output?
          Stefan_TR96
          @sdetweil yes, mirror and all other modules are running without any errors … just mmm-fuel is displaying loading
            @Stefan_TR96 open the developers window, ctrl-shift-i on the keyboard, select the console tab and scroll up to see any errors.
            You can filter by module, by placing part of the module name in the filter field.
              Stefan_TR96
              is there any possibility to control this without a physical keybord? I’m just able to connect via Remote desktop or ssh? Thx for your help, I’m a complete beginner
              • strawberry 3.141S Offline
                I just released version 2.0.2
                Added
                • French Translations
                • Clarification for config option updateInterval in readme
                Changed
                • Dependency Update
                Removed
                • Github pages
                https://github.com/fewieden/MMM-fuel
                [card:fewieden/MMM-Fuel]
                  Cetax @strawberry 3.141
                  @strawberry-3-141 Hi,
                  is there a way to hide the distance?
                  Can you tell me where I can comment that out?
                  Thank you for your help.
                  greeting
                  Stefan
                    strawberry 3.141 Project Sponsor Module Developer @Cetax
                    @Cetax add this in your custom.css file at ~/MagicMirror/css/custom.css
                    .MMM-Fuel th:nth-child(3), .MMM-Fuel td:nth-child(3) {
                        display: none;
                      @strawberry-3-141 said in MMM-Fuel:
                      display: none;
                      Yeah… :ok_hand:
                      thank u very much… Thats cool :thumbs_up:
                        The map modal was broken for quite some time, I managed to make it work again and switched to MMM-Modal at the same time.
                        [2.1.0]
                        Changed
                        • Using MMM-Modal to display modals like gas station and voice commands.
                        https://github.com/fewieden/MMM-Fuel
                        • StoffbeuteluweS Offline
                          Stoffbeuteluwe Project Sponsor @strawberry 3.141
                          is it possible to change the name from E5 to Super?
                            strawberry 3.141 Project Sponsor Module Developer @Stoffbeuteluwe
                            @Stoffbeuteluwe to not touch any source files of the module you can add the following to the custom.css file
                            .MMM-Fuel th:nth-child(2) span { /* Replace 2 with the correct column */
                                visibility: hidden;
                            .MMM-Fuel th:nth-child(2) span:after { /* Replace 2 with the correct column */
                                visibility: visible;
                                content: "Super";
                                margin-left: -21px; /* Pixels that the original text occupies */
                            StoffbeuteluweS 1 Reply Last reply Reply Quote 1
                              @strawberry-3-141 Oh Perfect thank you very much
                                [2.1.1]
                                Fixed
                                • Wrong value in config option sortBy no longer keeps module in state loading forever.
                                  Pielo
                                  when i set the shortenText-Function on true, then comes the first lettern only. When I set this function on false, than is the module to wide.
                                  What can i do? Can I set the size of this modul?
                                  alt text
                                    strawberry 3.141 Project Sponsor Module Developer @Pielo
                                    @Pielo the documentation states that you need to provide an integer of how many character you want to see, the value false is just to deactivate the behavior.
                                    Option          Default Description
                                    shortenText	false	Integer of characters to be shown for name and address. Default shows all.
                                    If you do shortenText: 5, then it will show 5 characters and shortenText: 10 will show 10 and so on
                                      Version 2.1.2
                                      Added
                                      • Config option showDistance https://github.com/fewieden/MMM-Fuel/pull/49
                                      • Missing jsdoc documentation
                                      Changed
                                      • Dependency update
                                      Fixed
                                      • Deinit map had a hardcoded index for markers.
                                      strawberry 3.141S 1 Reply Last reply Reply Quote 2
                                        strawberry 3.141 Project Sponsor Module Developer @strawberry 3.141
                                        Version 2.2.0
                                        Thanks to @TheDuffman85 for his contribution to this release. This version allows either to search by radius, specific station, or a combination of those two for provider Tankerkönig (Germany).
                                        Added
                                        • Config option stationIds to check prices of specific gas stations (Tankerkönig only)
                                        • Github actions
                                        Changed
                                        • 3rd decimal is now superscripted
                                        • Price and distance values are now localized based on global config option locale.
                                        Removed
                                        • Travis-CI integration
                                        [card: fewieden/MMM-Fuel]
                                          RIKKO14
                                          Does this module work for France?
                                          • eniacE Offline
                                            eniac
                                            Hello … getting this Error with npm start DEV
                                            [17:08:01.452] [LOG] Error: Error no fuel station detail
                                            at setStationInfos (/home/pi/MagicMirror/modules/MMM-Fuel/apis/tankerkoenig.js:189:19)
                                            at process._tickCallback (internal/process/next_tick.js:68:7)
                                                module: "MMM-Fuel",
                                            	//provider: "tankerkoenig",
                                                    api_key: "xxxxxxxxxxxxxxxxxxxxxx",
                                            	lat: 50.873798,
                                                    lng: 8.023410,
                                                    types: ["E5"],
                                            	updateInterval: 60000,
                                            	stationIds:
                                                "id": "9ac83212-c785-476f-9862-34a4b04f6320",
                                                "name": "BELL Oil",
                                            What could that be ?
                                            • 8 / 9
