    MMM-Fuel
    fuel pricegas stationpetrol stationvoice-controltankerkoenigspritpreisrechnernsw
    178 Posts 48 Posters 589.4k Views 48 Watching
    • A
      anno1972
      Hi all
      tankerkoenig does not provide API keys anomore - as far as I see there is no free provider anymore.
      How will this module run in future?
      Cheers
      Andy
      FoziF cowboysdudeC 2 Replies Last reply
      • FoziF
        Fozi Project Sponsor @anno1972
        @anno1972 you can still register for a API key
        https://creativecommons.tankerkoenig.de/ —> API-key
        A 1 Reply Last reply
        • A
          anno1972 @Fozi
          @Fozi thanks - by fault I used the wrong link to the Tankerkönig Monitor where registration wasn’t possible
          Happy New Year
          • cowboysdudeC
            cowboysdude Module Developer @anno1972
            @anno1972 NO api, no work.
            It can be done … I did it for the US but no clue about outside the country…
              Stefan_TR96
              Hi, since I updated MagicMirror I have a Problem running MMM-Fuel. I’m using the Provider “Spritpreisrechner” and it’s only “Loading”.
              npm start dev
              puts out the error
              TypeError: collection[type] is not iterable
              at Object.getData (/home/pi/MagicMirror/modules/MMM-Fuel/apis/spritpreisrechner.js:141:41)
              at process._tickCallback (internal/process/next_tick.js:68:7)
              Anybody an idea what I can do to solve this problem?
              Thanks S
              cowboysdudeC S 2 Replies Last reply
              • cowboysdudeC
                cowboysdude Module Developer @Stefan_TR96
                @Stefan_TR96 Data could have changed.
                  sdetweil @Stefan_TR96
                  @Stefan_TR96 did u run npm install in the module folders with a package.json file? u need to
                    Stefan_TR96 @sdetweil
                    @sdetweil said in MMM-Fuel:
                    tried to install it again and got following warning:
                    npm WARN stylelint-config-standard@16.0.0 requires a peer of stylelint@^7.8.0 but none is installed. You must install peer dependencies yourself.
                      @Stefan_TR96 that’s just a warning
                        Stefan_TR96
                        @cowboysdude if I type the generated url manually to the browser, I get the data
                          @Stefan_TR96 >tried to install it again and got following warning:
                          what is ‘it’…
                          the module may need updating after MM was updated…
                          do
                          cd ~/MagicMirror/modules/MMM-Fuel
                          npm install
                            Stefan_TR96
                            @sdetweil i did de install again (changed to MM-Fuel directory and did sudo npm install) as you wrote and got the warning i posted
                              @Stefan_TR96 said in MMM-Fuel:
                              sudo
                              never sudo
                                Stefan_TR96
                                @sdetweil same results without sudo
                                  @Stefan_TR96 yes, does mm run? Do you get output?
                                    Stefan_TR96
                                    @sdetweil yes, mirror and all other modules are running without any errors … just mmm-fuel is displaying loading
                                      @Stefan_TR96 open the developers window, ctrl-shift-i on the keyboard, select the console tab and scroll up to see any errors.
                                      You can filter by module, by placing part of the module name in the filter field.
                                        Stefan_TR96
                                        is there any possibility to control this without a physical keybord? I’m just able to connect via Remote desktop or ssh? Thx for your help, I’m a complete beginner
                                        • strawberry 3.141S
                                          I just released version 2.0.2
                                          Added
                                          • French Translations
                                          • Clarification for config option updateInterval in readme
                                          Changed
                                          • Dependency Update
                                          Removed
                                          • Github pages
                                          https://github.com/fewieden/MMM-fuel
                                          [card:fewieden/MMM-Fuel]
                                          C 1 Reply Last reply
                                            Cetax @strawberry 3.141
                                            @strawberry-3-141 Hi,
                                            is there a way to hide the distance?
                                            Can you tell me where I can comment that out?
                                            Thank you for your help.
                                            greeting
                                            Stefan
                                            • 7 / 9
