    MMM-Fuel
    fuel pricegas stationpetrol stationvoice-controltankerkoenigspritpreisrechnernsw
    178 Posts 48 Posters 586.1k Views 48 Watching
    • cowboysdudeC
      cowboysdude Module Developer @anno1972
      @anno1972 NO api, no work.
      It can be done … I did it for the US but no clue about outside the country…
        Stefan_TR96
        Hi, since I updated MagicMirror I have a Problem running MMM-Fuel. I’m using the Provider “Spritpreisrechner” and it’s only “Loading”.
        npm start dev
        puts out the error
        TypeError: collection[type] is not iterable
        at Object.getData (/home/pi/MagicMirror/modules/MMM-Fuel/apis/spritpreisrechner.js:141:41)
        at process._tickCallback (internal/process/next_tick.js:68:7)
        Anybody an idea what I can do to solve this problem?
        Thanks S
        cowboysdudeC S 2 Replies Last reply Reply Quote 0
        • cowboysdudeC
          cowboysdude Module Developer @Stefan_TR96
          @Stefan_TR96 Data could have changed.
            sdetweil @Stefan_TR96
            @Stefan_TR96 did u run npm install in the module folders with a package.json file? u need to
              Stefan_TR96 @sdetweil
              @sdetweil said in MMM-Fuel:
              tried to install it again and got following warning:
              npm WARN stylelint-config-standard@16.0.0 requires a peer of stylelint@^7.8.0 but none is installed. You must install peer dependencies yourself.
                @Stefan_TR96 that’s just a warning
                  Stefan_TR96
                  @cowboysdude if I type the generated url manually to the browser, I get the data
                    @Stefan_TR96 >tried to install it again and got following warning:
                    what is ‘it’…
                    the module may need updating after MM was updated…
                    do
                    cd ~/MagicMirror/modules/MMM-Fuel
                    npm install
                      Stefan_TR96
                      @sdetweil i did de install again (changed to MM-Fuel directory and did sudo npm install) as you wrote and got the warning i posted
                        @Stefan_TR96 said in MMM-Fuel:
                        sudo
                        never sudo
                          Stefan_TR96
                          @sdetweil same results without sudo
                            @Stefan_TR96 yes, does mm run? Do you get output?
                              Stefan_TR96
                              @sdetweil yes, mirror and all other modules are running without any errors … just mmm-fuel is displaying loading
                                @Stefan_TR96 open the developers window, ctrl-shift-i on the keyboard, select the console tab and scroll up to see any errors.
                                You can filter by module, by placing part of the module name in the filter field.
                                  Stefan_TR96
                                  is there any possibility to control this without a physical keybord? I’m just able to connect via Remote desktop or ssh? Thx for your help, I’m a complete beginner
                                  • strawberry 3.141S
                                    I just released version 2.0.2
                                    Added
                                    • French Translations
                                    • Clarification for config option updateInterval in readme
                                    Changed
                                    • Dependency Update
                                    Removed
                                    • Github pages
                                    https://github.com/fewieden/MMM-fuel
                                    [card:fewieden/MMM-Fuel]
                                      Cetax @strawberry 3.141
                                      @strawberry-3-141 Hi,
                                      is there a way to hide the distance?
                                      Can you tell me where I can comment that out?
                                      Thank you for your help.
                                      greeting
                                      Stefan
                                      • strawberry 3.141S
                                        strawberry 3.141 Project Sponsor Module Developer @Cetax
                                        @Cetax add this in your custom.css file at ~/MagicMirror/css/custom.css
                                        .MMM-Fuel th:nth-child(3), .MMM-Fuel td:nth-child(3) {
                                            display: none;
                                          @strawberry-3-141 said in MMM-Fuel:
                                          display: none;
                                          Yeah… :ok_hand:
                                          thank u very much… Thats cool :thumbs_up:
                                          • strawberry 3.141S
                                            The map modal was broken for quite some time, I managed to make it work again and switched to MMM-Modal at the same time.
                                            [2.1.0]
                                            Changed
                                            • Using MMM-Modal to display modals like gas station and voice commands.
                                            https://github.com/fewieden/MMM-Fuel
                                            • 7 / 9
