    MMM-Fuel
    fuel pricegas stationpetrol stationvoice-controltankerkoenigspritpreisrechnernsw
    178 Posts 48 Posters 569.6k Views 48 Watching
      Daugenix @Daugenix
      @Daugenix said in MMM-Fuel:
      Can I only show 3 specific gas stations?
      The gas stations that are displayed to me, I never go there
      Statement:
      max: 3
      is not what I mean.
      • strawberry 3.141S Offline
        strawberry 3.141 Project Sponsor Module Developer @Daugenix
        @Daugenix this is currently not implemented as most providers give not many results back
          Version 2.0.1
          Fixed: Ellipsis rendering in nunjuck template with config option shortenText active
          [card:fewieden/MMM-Fuel]
            db1mso
              anno1972
              Hi all
              tankerkoenig does not provide API keys anomore - as far as I see there is no free provider anymore.
              How will this module run in future?
              Cheers
              Andy
              FoziF cowboysdudeC 2 Replies Last reply Reply Quote 0
              • FoziF Offline
                Fozi Project Sponsor @anno1972
                @anno1972 you can still register for a API key
                https://creativecommons.tankerkoenig.de/ —> API-key
                  anno1972 @Fozi
                  @Fozi thanks - by fault I used the wrong link to the Tankerkönig Monitor where registration wasn’t possible
                  Happy New Year
                  • cowboysdudeC Offline
                    cowboysdude Module Developer @anno1972
                    @anno1972 NO api, no work.
                    It can be done … I did it for the US but no clue about outside the country…
                      Stefan_TR96
                      Hi, since I updated MagicMirror I have a Problem running MMM-Fuel. I’m using the Provider “Spritpreisrechner” and it’s only “Loading”.
                      npm start dev
                      puts out the error
                      TypeError: collection[type] is not iterable
                      at Object.getData (/home/pi/MagicMirror/modules/MMM-Fuel/apis/spritpreisrechner.js:141:41)
                      at process._tickCallback (internal/process/next_tick.js:68:7)
                      Anybody an idea what I can do to solve this problem?
                      Thanks S
                      cowboysdudeC S 2 Replies Last reply Reply Quote 0
                        cowboysdude Module Developer @Stefan_TR96
                        @Stefan_TR96 Data could have changed.
                          sdetweil @Stefan_TR96
                          @Stefan_TR96 did u run npm install in the module folders with a package.json file? u need to
                            Stefan_TR96 @sdetweil
                            @sdetweil said in MMM-Fuel:
                            tried to install it again and got following warning:
                            npm WARN stylelint-config-standard@16.0.0 requires a peer of stylelint@^7.8.0 but none is installed. You must install peer dependencies yourself.
                              @Stefan_TR96 that’s just a warning
                                Stefan_TR96
                                @cowboysdude if I type the generated url manually to the browser, I get the data
                                  @Stefan_TR96 >tried to install it again and got following warning:
                                  what is ‘it’…
                                  the module may need updating after MM was updated…
                                  do
                                  cd ~/MagicMirror/modules/MMM-Fuel
                                  npm install
                                    Stefan_TR96
                                    @sdetweil i did de install again (changed to MM-Fuel directory and did sudo npm install) as you wrote and got the warning i posted
                                      @Stefan_TR96 said in MMM-Fuel:
                                      sudo
                                      never sudo
                                        Stefan_TR96
                                        @sdetweil same results without sudo
                                          @Stefan_TR96 yes, does mm run? Do you get output?
                                            Stefan_TR96
                                            @sdetweil yes, mirror and all other modules are running without any errors … just mmm-fuel is displaying loading
                                            • 7 / 9
