    MMM-Fuel
    fuel pricegas stationpetrol stationvoice-controltankerkoenigspritpreisrechnernsw
    178 Posts 48 Posters 589.6k Views 48 Watching
      rakostamas @sdetweil
      1 verbose cli [ '/usr/bin/node', '/usr/bin/npm', 'start', 'dev' ]
      2 info using npm@6.6.0
      3 info using node@v9.11.2
      4 verbose stack Error: missing script: start
      4 verbose stack     at run (/usr/lib/node_modules/npm/lib/run-script.js:155:19)
      4 verbose stack     at /usr/lib/node_modules/npm/lib/run-script.js:63:5
      4 verbose stack     at /usr/lib/node_modules/npm/node_modules/read-package-json/read-json.js:115:5
      4 verbose stack     at /usr/lib/node_modules/npm/node_modules/read-package-json/read-json.js:418:5
      4 verbose stack     at checkBinReferences_ (/usr/lib/node_modules/npm/node_modules/read-package-json/read-json.js:373:45)
      4 verbose stack     at final (/usr/lib/node_modules/npm/node_modules/read-package-json/read-json.js:416:3)
      4 verbose stack     at then (/usr/lib/node_modules/npm/node_modules/read-package-json/read-json.js:160:5)
      4 verbose stack     at /usr/lib/node_modules/npm/node_modules/read-package-json/read-json.js:364:12
      4 verbose stack     at /usr/lib/node_modules/npm/node_modules/graceful-fs/graceful-fs.js:90:16
      4 verbose stack     at FSReqWrap.readFileAfterClose [as oncomplete] (fs.js:525:3)
      5 verbose cwd /home/pi/MagicMirror/modules/MMM-Fuel
      6 verbose Linux 4.14.79-v7+
      7 verbose argv "/usr/bin/node" "/usr/bin/npm" "start" "dev"
      8 verbose node v9.11.2
      9 verbose npm  v6.6.0
      10 error missing script: start
      11 verbose exit [ 1, true ]
      S strawberry 3.141S 2 Replies Last reply
        sdetweil @rakostamas
        @rakostamas said in MMM-Fuel:
        please do
        then
        npm start dev
          rakostamas
          Yes I got errors.
          GET http://localhost:8080/modules/MMM-Fuel//MMM-Fuel.js net : : ERR_CACHE_READ_FAILURE
          Error on loading script: modules/MMM-Fuel//MMM-Fuel.js
            sorry, I do not know why reading from the local disk would fail with cache read failure error
            • strawberry 3.141S
              strawberry 3.141 Project Sponsor Module Developer @rakostamas
              @rakostamas as @sdetweil already mentioned you need to start the mirror not the module.
              cd ~/MagicMirror && npm start dev
              R 1 Reply Last reply
                rakostamas @strawberry 3.141
                @strawberry-3-141
                yes, I have opened it, and I got the errors what I wrote in my last comment
                • strawberry 3.141S
                  @rakostamas did you check that the file exists? Maybe something went wrong during the cloning of the module
                  • V
                    VanDerPol
                    hello
                    I have the same problem like rakostamas.
                    As headline there stands Spritpreise und below there stands loading.
                    I am from Austria and I use provider Spritpreisrechner.
                    Unfortunately I can’t find the mistake. Could you please help me?
                    Sorry My english is not the yellow from the egg :)
                    My Config:
                                         module: "MMM-Fuel",
                                                 lat: 48.527710,
                                                 lng: 16.361530,
                                                 radius: 15,
                                                 max: 5,
                                                 map_api_key: false,
                                                 zoom: 12,
                                                 width: 600,
                                                 height: 600,
                                                 colored: true,
                                                 open: false,
                                                 shortenText: false,
                                                 showAddress: true,
                                                 showOpenOnly: false,
                                                 iconHeader: true,
                                                 rotate: true,
                                                 types: ['diesel'],
                                                 sortBy: 'diesel',
                                                 rotateInterval: 60 * 1000, // every minute
                                                 updateInterval: 15 * 60 * 1000, // every 15 minutes
                                                 provider: 'spritpreisrechner',
                                                 toFixed: false
                    • strawberry 3.141S
                      I just merged a new version of this module into master.
                      New: Support for gas stations in new south wales australia
                      Changed: I rewrote most of the module, make sure you also install the dependencies after the update.
                      [card:fewieden/MMM-Fuel]
                        Daugenix
                        Can I only show 3 specific gas stations?
                        The gas stations that are displayed to me, I never go there
                        D 1 Reply Last reply
                          Daugenix @Daugenix
                          @Daugenix said in MMM-Fuel:
                          Statement:
                          max: 3
                          is not what I mean.
                          • strawberry 3.141S
                            strawberry 3.141 Project Sponsor Module Developer @Daugenix
                            @Daugenix this is currently not implemented as most providers give not many results back
                            • strawberry 3.141S
                              Version 2.0.1
                              Fixed: Ellipsis rendering in nunjuck template with config option shortenText active
                                db1mso
                                • A
                                  anno1972
                                  Hi all
                                  tankerkoenig does not provide API keys anomore - as far as I see there is no free provider anymore.
                                  How will this module run in future?
                                  Cheers
                                  Andy
                                  FoziF cowboysdudeC 2 Replies Last reply
                                  • FoziF
                                    Fozi Project Sponsor @anno1972
                                    @anno1972 you can still register for a API key
                                    https://creativecommons.tankerkoenig.de/ —> API-key
                                    A 1 Reply Last reply
                                    • A
                                      anno1972 @Fozi
                                      @Fozi thanks - by fault I used the wrong link to the Tankerkönig Monitor where registration wasn’t possible
                                      Happy New Year
                                      • cowboysdudeC
                                        cowboysdude Module Developer @anno1972
                                        @anno1972 NO api, no work.
                                        It can be done … I did it for the US but no clue about outside the country…
                                          Stefan_TR96
                                          Hi, since I updated MagicMirror I have a Problem running MMM-Fuel. I’m using the Provider “Spritpreisrechner” and it’s only “Loading”.
                                          npm start dev
                                          puts out the error
                                          TypeError: collection[type] is not iterable
                                          at Object.getData (/home/pi/MagicMirror/modules/MMM-Fuel/apis/spritpreisrechner.js:141:41)
                                          at process._tickCallback (internal/process/next_tick.js:68:7)
                                          Anybody an idea what I can do to solve this problem?
                                          Thanks S
                                          cowboysdudeC S 2 Replies Last reply
                                          • cowboysdudeC
                                            cowboysdude Module Developer @Stefan_TR96
                                            @Stefan_TR96 Data could have changed.
                                            • 7 / 9
