    MMM-Fuel
    fuel pricegas stationpetrol stationvoice-controltankerkoenigspritpreisrechnernsw
    178 Posts 48 Posters 589.7k Views 48 Watching
      db1mso
      • A
        anno1972
        Hi all
        tankerkoenig does not provide API keys anomore - as far as I see there is no free provider anymore.
        How will this module run in future?
        Cheers
        Andy
        FoziF cowboysdudeC 2 Replies Last reply
        • FoziF
          Fozi Project Sponsor @anno1972
          @anno1972 you can still register for a API key
          https://creativecommons.tankerkoenig.de/ —> API-key
          A 1 Reply Last reply
          • A
            anno1972 @Fozi
            @Fozi thanks - by fault I used the wrong link to the Tankerkönig Monitor where registration wasn’t possible
            Happy New Year
            • cowboysdudeC
              cowboysdude Module Developer @anno1972
              @anno1972 NO api, no work.
              It can be done … I did it for the US but no clue about outside the country…
                Stefan_TR96
                Hi, since I updated MagicMirror I have a Problem running MMM-Fuel. I’m using the Provider “Spritpreisrechner” and it’s only “Loading”.
                npm start dev
                puts out the error
                TypeError: collection[type] is not iterable
                at Object.getData (/home/pi/MagicMirror/modules/MMM-Fuel/apis/spritpreisrechner.js:141:41)
                at process._tickCallback (internal/process/next_tick.js:68:7)
                Anybody an idea what I can do to solve this problem?
                Thanks S
                cowboysdudeC S 2 Replies Last reply
                • cowboysdudeC
                  cowboysdude Module Developer @Stefan_TR96
                  @Stefan_TR96 Data could have changed.
                    sdetweil @Stefan_TR96
                    @Stefan_TR96 did u run npm install in the module folders with a package.json file? u need to
                      Stefan_TR96 @sdetweil
                      @sdetweil said in MMM-Fuel:
                      tried to install it again and got following warning:
                      npm WARN stylelint-config-standard@16.0.0 requires a peer of stylelint@^7.8.0 but none is installed. You must install peer dependencies yourself.
                        @Stefan_TR96 that’s just a warning
                          Stefan_TR96
                          @cowboysdude if I type the generated url manually to the browser, I get the data
                            @Stefan_TR96 >tried to install it again and got following warning:
                            what is ‘it’…
                            the module may need updating after MM was updated…
                            do
                            cd ~/MagicMirror/modules/MMM-Fuel
                            npm install
                              Stefan_TR96
                              @sdetweil i did de install again (changed to MM-Fuel directory and did sudo npm install) as you wrote and got the warning i posted
                                @Stefan_TR96 said in MMM-Fuel:
                                sudo
                                never sudo
                                  Stefan_TR96
                                  @sdetweil same results without sudo
                                    @Stefan_TR96 yes, does mm run? Do you get output?
                                      Stefan_TR96
                                      @sdetweil yes, mirror and all other modules are running without any errors … just mmm-fuel is displaying loading
                                        @Stefan_TR96 open the developers window, ctrl-shift-i on the keyboard, select the console tab and scroll up to see any errors.
                                        You can filter by module, by placing part of the module name in the filter field.
                                          Stefan_TR96
                                          is there any possibility to control this without a physical keybord? I’m just able to connect via Remote desktop or ssh? Thx for your help, I’m a complete beginner
                                          • strawberry 3.141S
                                            I just released version 2.0.2
                                            Added
                                            • French Translations
                                            • Clarification for config option updateInterval in readme
                                            Changed
                                            • Dependency Update
                                            Removed
                                            • Github pages
                                            https://github.com/fewieden/MMM-fuel
                                            [card:fewieden/MMM-Fuel]
                                            C 1 Reply Last reply
                                            • 7 / 9
