    Failure of v2.2.0
    15 Posts 7 Posters 8.8k Views 5 Watching
      doubleT Module Developer
      “Crashed” like in not responding? Any error messages?
      • richland007R Offline
        richland007
        Hi you all i upgraded to V2.2.2 last night and all in all it went good the only initial problem was that it will abort due to local weather changes being not committed but i solved that with “git status” and after that “git reset --hard” on the MagicMirror directory as stated on the github notes.
        When i started the magic mirror however it through “npm start” (i dont use “pm2” ) i got a complete black screen (had to use ctrl-alt-del to kill electron to get out of it as ctrl-q will not do anything) and on the terminal i could see that MMM-Swipe was the culprit i commented out “MMM-Swipe” and the second issue was with “MMM-PIR-sensor” after commenting those 2 out everything else was working perfectly. The error was the same for both modules the expected 50 and got 54 or something to that nature i don’t remember the exact words but i have to re=crash it again when i get home.
        Does any one knows how to get rid of this issue which i am assuming should be easily fixed via commands without going the long route, and the only one i know, of deleting the modules and reinstalling them???
        thank you all any help will be greatly appreciated
        Denis
        • cruunnerrC Offline
          cruunnerr
          @richland007 said in Failure of v2.2.0:
          as i can read here a simple npm install in the modules folders should bring u to target :)
          richland007R 1 Reply Last reply Reply Quote 0
            richland007 @cruunnerr
            @cruunnerr you are the man that worked
            thank you
            • lavolp3L Offline
              lavolp3 Module Developer @carltonb
              @carltonb said in Failure of v2.2.0:
              Install went fine, but again crashed when I tried to use this command. It crashes at the same point every time. See the file generation after I start the installer in the first post.
              Where exactly does it crash? I can’t follow you. I also can’t find the error in the pasted code above.
              Does it just stop where the code stops and not go on?
              How to troubleshoot modules
              MMM-soccer v2, MMM-AVStock
