    • Search
    City of Vienna - Public Transport Realtime Monitor
    Requests
    4534
    • C
      cpramhofer last edited by
      The City of Vienna is offering an API for its Realtime Monitor:
      https://www.data.gv.at/katalog/dataset/add66f20-d033-4eee-b9a0-47019828e698
      Would be nice to have a Monitor with Departuretimes for a defined Station like other Modules for other Cities.
      strawberry 3.141 1 Reply Last reply Reply Quote 0
      • B
        bobbob601 last edited by
        I just did a module for real time schedules for Paris transportation with the help of @strawberry-3-141.
        You just have to adapt this code if you want
        https://github.com/lgmorand/MMM-Ratp
        Would love to help you, but the documentation is in german und Ich habe alles vergessen 😢
        • strawberry 3.141
          strawberry 3.141 Project Sponsor Module Developer @cpramhofer last edited by
          @cpramhofer I applied for an API key, but still have to war for it, then I will have a look into it
          • C
            Hy Guys,
            thanks a lot for your help!
            i would do it for my own but i stoped programming since i left university 10 years ago and i currently don´t have the time to get used to json…
            greets from Vienna 😉
            • C
              Hi again 😉
              found the following:
              https://github.com/Metalab/oeffimonitor
              someone acutally did a lot of work on this in JS here on github. the point is to bring this into an MMM.
                spedja last edited by
                Hi people,
                i am also looking forward to this module.
                Here is another source, maybe can be useful:
                https://github.com/tom94zoe/magicMirror
                and to test API you can use:
                http://www.wienerlinien.at/ogd_realtime/monitor?rbl=4259&sender=GDxCvVKMAfrXja1F
                Search for RBL numbers:
                https://till.mabe.at/rbl/
                • strawberry 3.141
                  strawberry 3.141 Project Sponsor Module Developer last edited by
                  I had a first look into this, but I could’t find a documentation neither I got a api_key from them.
                  So I’m trying to get into this on my own, but therefore you guys need to test if the module is working for your needs. I will work on this tonight so propably you can test it today already
                  You can follow the developing process here when I have started
                  • C
                    Hi Strawberry,
                    Mayen this Uri helps:
                    I think the value After the Sender is the API key.
                    Thanks a lot for your help!!
                    • strawberry 3.141
                      maintenance on their API 😞
                      • C
                        Hi @strawberry-3-141!
                        Thanks a lot for work great work!
                        It doesn’t only work, it also looks fantastic!
                        if you are from vienna: the next beer is on me 😉
                        greets
                        Christoph
                        strawberry 3.141 1 Reply Last reply Reply Quote 1
