    Mirror turning black after a while
    45 Posts 16 Posters 37.9k Views 15 Watching
      retroflex Project Sponsor Module Developer @Chris
      @Chris
      Did you have the same error on the old version or did it appear with the latest?
        doubleT Module Developer
        Is there any kind of “sleep” mode on the system itself?
        The node log probably doesn’t detect what’s going on but maybe the console log would show (unfortunately, it’s reset when the browser window is refreshed). I’d start MM in dev mode and wait for the crash, then check the browser’s console log.
          retroflex Project Sponsor Module Developer @doubleT
          @doubleT Thanks for the tip! I will try dev mode and report back.
          • ChrisC Offline
            Chris @Chris
            @retroflex said in Mirror turning black after a while:
            @Chris
            Hello,
            it is true that this is happening since the last version.
            I did not pay much attention to this because it was during an attempt to install a module that caused me a lot of trouble. I thought it was just that.
            As I told you, it’s still very episodic, it must have been more than two days since it did not happen.
            Regards,
              bimalnair
              Hello All, is this issue fixed? I still have this issue and I get back the screen only by ctrl + R. I am experiencing this issue only after the recent update.
                retroflex Project Sponsor Module Developer @bimalnair
                @bimalnair I haven’t done any more research. But now I have started in dev mode and will see if the console log says anything useful. But it usually takes some hours before my freezes, so I will know later today (hopefully).
                Another test is to remove module by module to see if a certain module is causing problems. Or the opposite, start with only one module and see if it will freeze. Can you check which modules we share? Maybe we can narrow it down a bit.
                  bimalnair
                  I am using the following modules
                  default/alert
                  default/clock
                  default/calendar
                  default/currentweather
                  default/weatherforecast
                  default/newsfeed
                  default/compliments
                  MMM-ShipmentTracking
                  MMM-Traffic
                  MMM-ImagesPhotos
                  MMM-dht22
                  Will try disabling each module
                  • ChrisC Offline
                    Chris
                    Hello,
                    I think it would come from one of your modules because I do not encounter the problem since I put my mirror with my usual modules. if that helps you, it happened to me when I tried to install and set up the MMM-Assistant.
                    Regards,
                    • P Offline
                      prysme01
                      Hello, After upgrading MM to 2.2.0 and also upgrading my debian, I am also facing this issue of random black screen. PI is still up and I can log in and restart mm. Really annoying issue.
                        @bimalnair Have you tried to find out which module is causing problems for you yet?
                        I have finally got a dev log file from the error… As it’s not timestamped, it’s hard to draw any conclusions. But this is one of the lasts logs, which presumably is when the mirror goes black:
                        [5966:0125/191204:FATAL:memory_linux.cc(35)] Out of memory.
                        #0 0x0000012a3bb0
                        #1 0x0000012b4406
                        #2 0x0000012c8ae6
                        #3 0x000000d8bb1c
                        #4 0x000000d8ba9e operator new()
                        #5 0x0000012b9ee0
                        #6 0x0000012b94ce
                        #7 0x0000012ba204
                        #8 0x0000012cb2c6
                        #9 0x0000012b89f6
                        #10 0x000000b58d18
                        #11 0x000000a34c38
                        #12 0x000000a35a80
                        #13 0x000000a349c2
                        #14 0x00000221e2fa main
                        #15 0x000074c0f294 __libc_start_main
                        I did not check which process is eating all the memory though. That will be the next step.
                        Other than that I can see in the log that I lost internet connection a couple of times:
                        fatal: unable to access 'https://github.com/MichMich/MagicMirror.git/': Could not resolve host: github.com
                        TypeError: Cannot read property 'feed' of undefined
                            at ClientRequest. (/home/pi/MagicMirror/modules/MMM-Skolmaten/node_helper.js:45:20)
                        And a lot of these logs, which I guess is ok:
                        Reusing 14 cached departure(s) for module: MMM-ResRobot
                        Any bright ideas? :)
                        • 5 / 5
