    Mirror turning black after a while
    45 Posts 16 Posters 43.1k Views 15 Watching
      retroflex Project Sponsor Module Developer @Chris
      @Chris
      Did you have the same error on the old version or did it appear with the latest?
        doubleT Module Developer
        Is there any kind of “sleep” mode on the system itself?
        The node log probably doesn’t detect what’s going on but maybe the console log would show (unfortunately, it’s reset when the browser window is refreshed). I’d start MM in dev mode and wait for the crash, then check the browser’s console log.
        R 1 Reply Last reply
          retroflex Project Sponsor Module Developer @doubleT
          @doubleT Thanks for the tip! I will try dev mode and report back.
          • ChrisC
            Chris @Chris
            @retroflex said in Mirror turning black after a while:
            @Chris
            it is true that this is happening since the last version.
            I did not pay much attention to this because it was during an attempt to install a module that caused me a lot of trouble. I thought it was just that.
            As I told you, it’s still very episodic, it must have been more than two days since it did not happen.
            Regards,
              bimalnair
              Hello All, is this issue fixed? I still have this issue and I get back the screen only by ctrl + R. I am experiencing this issue only after the recent update.
                retroflex Project Sponsor Module Developer @bimalnair
                @bimalnair I haven’t done any more research. But now I have started in dev mode and will see if the console log says anything useful. But it usually takes some hours before my freezes, so I will know later today (hopefully).
                Another test is to remove module by module to see if a certain module is causing problems. Or the opposite, start with only one module and see if it will freeze. Can you check which modules we share? Maybe we can narrow it down a bit.
                  bimalnair
                  I am using the following modules
                  default/alert
                  default/clock
                  default/calendar
                  default/currentweather
                  default/weatherforecast
                  default/newsfeed
                  default/compliments
                  MMM-ShipmentTracking
                  MMM-Traffic
                  MMM-ImagesPhotos
                  MMM-dht22
                  Will try disabling each module
                  • ChrisC
                    Chris
                    I think it would come from one of your modules because I do not encounter the problem since I put my mirror with my usual modules. if that helps you, it happened to me when I tried to install and set up the MMM-Assistant.
                    Regards,
                      prysme01
                      Hello, After upgrading MM to 2.2.0 and also upgrading my debian, I am also facing this issue of random black screen. PI is still up and I can log in and restart mm. Really annoying issue.
                        @bimalnair Have you tried to find out which module is causing problems for you yet?
                        I have finally got a dev log file from the error… As it’s not timestamped, it’s hard to draw any conclusions. But this is one of the lasts logs, which presumably is when the mirror goes black:
                        [5966:0125/191204:FATAL:memory_linux.cc(35)] Out of memory.
                        #0 0x0000012a3bb0
                        #1 0x0000012b4406
                        #2 0x0000012c8ae6
                        #3 0x000000d8bb1c
                        #4 0x000000d8ba9e operator new()
                        #5 0x0000012b9ee0
                        #6 0x0000012b94ce
                        #7 0x0000012ba204
                        #8 0x0000012cb2c6
                        #9 0x0000012b89f6
                        #10 0x000000b58d18
                        #11 0x000000a34c38
                        #12 0x000000a35a80
                        #13 0x000000a349c2
                        #14 0x00000221e2fa main
                        #15 0x000074c0f294 __libc_start_main
                        I did not check which process is eating all the memory though. That will be the next step.
                        Other than that I can see in the log that I lost internet connection a couple of times:
                        fatal: unable to access 'https://github.com/MichMich/MagicMirror.git/': Could not resolve host: github.com
                        TypeError: Cannot read property 'feed' of undefined
                            at ClientRequest. (/home/pi/MagicMirror/modules/MMM-Skolmaten/node_helper.js:45:20)
                        And a lot of these logs, which I guess is ok:
                        Reusing 14 cached departure(s) for module: MMM-ResRobot
                        Any bright ideas? :)
                        • cruunnerrC
                          cruunnerr
                          @retroflex
                          the wifi on the RPi 3 is not the best. So i installed an automatically wifi_rebooter here. U could try that as well: http://alexba.in/blog/2015/01/14/automatically-reconnecting-wifi-on-a-raspberrypi/
                          in my case my Pi pings my router address every 3 minutes and when it cannot reach it, it reboots it’s wifi itself.
                          For your other problem u could try “nmon”.
                          sudo apt-get install nmon
                          start it by simply typing nmon
                          when it starts u can type letters to choose what u want it to show. with “t, l, m, c” it will show u “top processes”, “long therm CPU usage”, “memory usage” and “actual CPU usage”
                          Mykle1M 1 Reply Last reply
                          • Mykle1M
                            Mykle1 Project Sponsor Module Developer @cruunnerr
                            @cruunnerr
                            I agree. nmon is a very useful tool for diagnosing Pi cpu and memory issues.
                            https://forum.magicmirror.builders/topic/4684/electron-cpu-usage/11
                              retroflex Project Sponsor Module Developer @Mykle1
                              @Mykle1 @cruunnerr Thanks. Nmon is a great tip. I can clearly see that I have a CPU issue beside the memory leak. CPU for electron process is at 100% all the time. Currently at 30% mem, but I guess this will increase over time. Will check later.
                              PID USER      PR  NI    VIRT    RES    SHR S  %CPU %MEM     TIME+ COMMAND
                              1146 pi        20   0  700648 300408  47112 R 100.0 31.6 215:22.52 electron
                              I’ve read the CPU usage thread and can conclude that I use electron v1.4.15 and MM v2.2.0. Mykle1, the thread said to use an older MM version, but I guess the new one should work ok too? Since electron was forced to the older version in the new release?
                              Now all I have to do is check each module I run and check CPU and mem for each :)
                                My problem was MMM-ResRobot. I deactivated it and kept all other modules and now CPU is at 2% and memory stable over time at around 10%. Not sure if the MM/electron/ResRobot update caused the problem, but it worked ok before. Strange…
                                Mykle1M F 2 Replies Last reply
                                • Mykle1M
                                  Mykle1 Project Sponsor Module Developer @retroflex
                                  That’s great news, mate! I did that testing months ago to determine what was causing the CPU spikes. It was rather rewarding to have discovered the cause. They gave me an award. :-)
                                  Peace!
                                  • schlachtkreuzer6S
                                    schlachtkreuzer6
                                    I got the same problem with an TV, around 6 to 9h it went black and I had to restart MM
                                      cyberdie
                                      Same problem here.
                                      After some hours the creen goes black.
                                      Pi Zero and “node serveronly”
                                        retroflex Project Sponsor Module Developer @cyberdie
                                        @cyberdie @schlachtkreuzer6 It seems to be related to a certain module. Most likely it is a memory leak you have too. Try to find out by disabling modules until it works.
                                        It would be good to find the root cause to this though as many have problems. But that is a bit out of my expertise.
                                        schlachtkreuzer6S 1 Reply Last reply
                                          Binog
                                          me too,… still while after while,… guess have that problem since version 2.0.0 but not sure,. cause update everything regularly,…
                                          • schlachtkreuzer6S
                                            schlachtkreuzer6 @retroflex
                                            @retroflex probably we need some code to clear the ram periodically. I think my problem module is the MMM-Globe. But I will have to test it. (about 10 modules… So one module per day… Uff that’s a looooong way.
