    Mirror turning black after a while
    45 Posts 16 Posters 41.7k Views 15 Watching
    • ChrisC Offline
      Chris
      I think it would come from one of your modules because I do not encounter the problem since I put my mirror with my usual modules. if that helps you, it happened to me when I tried to install and set up the MMM-Assistant.
      Regards,
        prysme01
        Hello, After upgrading MM to 2.2.0 and also upgrading my debian, I am also facing this issue of random black screen. PI is still up and I can log in and restart mm. Really annoying issue.
          retroflex Project Sponsor Module Developer @bimalnair
          @bimalnair Have you tried to find out which module is causing problems for you yet?
          I have finally got a dev log file from the error… As it’s not timestamped, it’s hard to draw any conclusions. But this is one of the lasts logs, which presumably is when the mirror goes black:
          [5966:0125/191204:FATAL:memory_linux.cc(35)] Out of memory.
          #0 0x0000012a3bb0
          #1 0x0000012b4406
          #2 0x0000012c8ae6
          #3 0x000000d8bb1c
          #4 0x000000d8ba9e operator new()
          #5 0x0000012b9ee0
          #6 0x0000012b94ce
          #7 0x0000012ba204
          #8 0x0000012cb2c6
          #9 0x0000012b89f6
          #10 0x000000b58d18
          #11 0x000000a34c38
          #12 0x000000a35a80
          #13 0x000000a349c2
          #14 0x00000221e2fa main
          #15 0x000074c0f294 __libc_start_main
          I did not check which process is eating all the memory though. That will be the next step.
          Other than that I can see in the log that I lost internet connection a couple of times:
          fatal: unable to access 'https://github.com/MichMich/MagicMirror.git/': Could not resolve host: github.com
          TypeError: Cannot read property 'feed' of undefined
              at ClientRequest. (/home/pi/MagicMirror/modules/MMM-Skolmaten/node_helper.js:45:20)
          And a lot of these logs, which I guess is ok:
          Reusing 14 cached departure(s) for module: MMM-ResRobot
          Any bright ideas? :)
          • cruunnerrC Offline
            cruunnerr
            @retroflex
            the wifi on the RPi 3 is not the best. So i installed an automatically wifi_rebooter here. U could try that as well: http://alexba.in/blog/2015/01/14/automatically-reconnecting-wifi-on-a-raspberrypi/
            in my case my Pi pings my router address every 3 minutes and when it cannot reach it, it reboots it’s wifi itself.
            For your other problem u could try “nmon”.
            sudo apt-get install nmon
            start it by simply typing nmon
            when it starts u can type letters to choose what u want it to show. with “t, l, m, c” it will show u “top processes”, “long therm CPU usage”, “memory usage” and “actual CPU usage”
              Mykle1 Project Sponsor Module Developer @cruunnerr
              @cruunnerr
              I agree. nmon is a very useful tool for diagnosing Pi cpu and memory issues.
              https://forum.magicmirror.builders/topic/4684/electron-cpu-usage/11
                retroflex Project Sponsor Module Developer @Mykle1
                @Mykle1 @cruunnerr Thanks. Nmon is a great tip. I can clearly see that I have a CPU issue beside the memory leak. CPU for electron process is at 100% all the time. Currently at 30% mem, but I guess this will increase over time. Will check later.
                PID USER      PR  NI    VIRT    RES    SHR S  %CPU %MEM     TIME+ COMMAND
                1146 pi        20   0  700648 300408  47112 R 100.0 31.6 215:22.52 electron
                I’ve read the CPU usage thread and can conclude that I use electron v1.4.15 and MM v2.2.0. Mykle1, the thread said to use an older MM version, but I guess the new one should work ok too? Since electron was forced to the older version in the new release?
                Now all I have to do is check each module I run and check CPU and mem for each :)
                  My problem was MMM-ResRobot. I deactivated it and kept all other modules and now CPU is at 2% and memory stable over time at around 10%. Not sure if the MM/electron/ResRobot update caused the problem, but it worked ok before. Strange…
                  Mykle1M F 2 Replies Last reply Reply Quote 1
                    Mykle1 Project Sponsor Module Developer @retroflex
                    @retroflex said in Mirror turning black after a while:
                    That’s great news, mate! I did that testing months ago to determine what was causing the CPU spikes. It was rather rewarding to have discovered the cause. They gave me an award. :-)
                    Peace!
                      schlachtkreuzer6
                      I got the same problem with an TV, around 6 to 9h it went black and I had to restart MM
                        cyberdie
                        Same problem here.
                        After some hours the creen goes black.
                        Pi Zero and “node serveronly”
                          retroflex Project Sponsor Module Developer @cyberdie
                          @cyberdie @schlachtkreuzer6 It seems to be related to a certain module. Most likely it is a memory leak you have too. Try to find out by disabling modules until it works.
                          It would be good to find the root cause to this though as many have problems. But that is a bit out of my expertise.
                            Binog
                            me too,… still while after while,… guess have that problem since version 2.0.0 but not sure,. cause update everything regularly,…
                              schlachtkreuzer6 @retroflex
                              @retroflex probably we need some code to clear the ram periodically. I think my problem module is the MMM-Globe. But I will have to test it. (about 10 modules… So one module per day… Uff that’s a looooong way.
                                cruunnerr
                                make two or three per day ;)
                                than it goes faster
                                  Maybe this can be the cause?
                                  https://github.com/electron/electron/issues/11739
                                    schlachtkreuzer6 @cruunnerr
                                    @cruunnerr
                                    I’m working 🙄 didn’t test anything yet 😅
                                    • F Offline
                                      FredJ @retroflex
                                      @retroflex I also got the same issue. MMM-resrobot or something it depends on looks to be causing this. Has anyone found a workaround? Resrobot is one of the main reasons I have the mirror so not really happy about disableing it.
                                        @Alvinger Do you know what could be the problem with ResRobot here?
                                          Alvinger @retroflex
                                          @retroflex I can’t think of anythong off hand.
                                          I am running an older version of MM myself so haven’t researched the electron issues.
                                          Can anyone confirm that the issue started with the new MM version?
                                          As I am running my magic mirror on an original Pi 1 with 256MB RAM with no issues whatsoever I am a bit surprised that the module should cause this.
                                          Edit: MMM-ResRobot has but one dependency and that is the unirest module.
                                          Which version of ResRobot are you running? I did a rewrite to reduce the number of updates w while ago.
                                            cyberdie
                                            @alvinger In my case, the problem started after last MM update.
                                            R A 2 Replies Last reply Reply Quote 0
                                            • 2 / 3
