    Really confused
    23 Posts 5 Posters 14.2k Views 4 Watching
      Duke86
      so I wanted to make this mirror for my mother as a Christmas present so I buy the mirror and the wood, Monitor. But… when I install my software on my raspberry pi 3 I wait half an hour and it said error(I am sorry but I don’t have the full error message). So I decide to download it again and I can’t I then follow “Mykle1” guide and I get the same message.
      Please help I am getting stressed
      If you want to know what I got my mother for Christmas It was mac(Apple laptop)
      </pi@raspberrypi:~ $ npm start
      npm ERR! Linux 4.9.59-v7+
      npm ERR! argv “/usr/bin/node” “/usr/bin/npm” “start”
      npm ERR! node v6.12.3
      npm ERR! npm v3.10.10
      npm ERR! path /home/pi/package.json
      npm ERR! code ENOENT
      npm ERR! errno -2
      npm ERR! syscall open
      npm ERR! enoent ENOENT: no such file or directory, open ‘/home/pi/package.json’
      npm ERR! enoent This is most likely not a problem with npm itself
      npm ERR! enoent and is related to npm not being able to find a file.
      npm ERR! enoent
      npm ERR! /home/pi/npm-debug.log
      pi@raspberrypi:~ $ ^C
      pi@raspberrypi:~ $>
        Mykle1 Project Sponsor Module Developer @Duke86
        @Duke86
        We would have to know the error message to attempt to help you. So, run the mirror and make note of the error message, in its entirety. Then post it here in a code block using the </> option above your message window
          Duke86
          npm ERR! errno -2
          npm ERR! enoent
          pi@raspberrypi:~ $
          Mykle1M N 2 Replies Last reply Reply Quote 0
            @Duke86
            You running npm start in the wrong directory.
            First enter cd MagicMirror and enter
            Then run npm start
            • N Offline
              ninjabreadman @Duke86
              @Duke86 Hi Duke, start with cd MagicMirror/ … you’re probably trying to start MM out of the wrong folder.
              Problem with config or JavaScript? Copy/paste it into JSHint.
              Check out the detailed walkthroughs on install, config, modules, etc.
                Duke86
                @Mykle1 said in Really confused:
                npm start
                pi@raspberrypi:~ $ cd MagicMirror
                magicmirror@2.2.2 start /home/pi/MagicMirror
                sh run-start.sh
                /home/pi/MagicMirror/node_modules/electron/index.js:9
                throw new Error(‘Electron failed to install correctly, please delete node_modules/’ + path.basename(__dirname) + ’ and try installing again’)
                Error: Electron failed to install correctly, please delete node_modules/electron and try installing again
                at Object. (/home/pi/MagicMirror/node_modules/electron/index.js:9:9)
                at Module._compile (module.js:570:32)
                at Object.Module._extensions…js (module.js:579:10)
                at Module.load (module.js:487:32)
                at tryModuleLoad (module.js:446:12)
                at Function.Module._load (module.js:438:3)
                at Module.require (module.js:497:17)
                at require (internal/module.js:20:19)
                at Object. (/home/pi/MagicMirror/node_modules/electron/cli.js:3:16)
                npm ERR! code ELIFECYCLE
                npm ERR! magicmirror@2.2.2 start: sh run-start.sh
                npm ERR! Exit status 1
                npm ERR!
                npm ERR! Failed at the magicmirror@2.2.2 start script ‘sh run-start.sh’.
                npm ERR! If you do, this is most likely a problem with the magicmirror package,
                npm ERR! not with npm itself.
                npm ERR! sh run-start.sh
                npm ERR! npm bugs magicmirror
                npm ERR! Or if that isn’t available, you can get their info via:
                npm ERR! npm owner ls magicmirror
                npm ERR! /home/pi/MagicMirror/npm-debug.log
                N Mykle1M 2 Replies Last reply Reply Quote 0
                • N Offline
                  @Duke86 said in Really confused:
                  Try rm -rf /home/pi/MagicMirror/node_modules/electron. Then run npm install electron.
                    The error message is telling you what you have to do. So, in your GUI, you can navigate to your MagicMirror/node_modules/ folder and delete the electron folder. Then open a terminal and cd MagicMirror and npm install
                      Duke86
                      I removed the folder and this happened
                      pi@raspberrypi:~/MagicMirror $ cd MagicMirror
                      bash: cd: MagicMirror: No such file or directory
                      pi@raspberrypi:~/MagicMirror $ nmp install
                      bash: nmp: command not found
                      pi@raspberrypi:~/MagicMirror $ ^C
                      D cruunnerrC 2 Replies Last reply Reply Quote 0
                        doubleT Module Developer @Duke86
                        You are already in the directory “MagicMirror”. cd (change directory to) can’t find the directory because you are already inside.
                        Just a typo, it’s “npm”, not “nmp”.
                          Duke86
                          npm ERR! errno -2
                          npm ERR! enoent
                          pi@raspberrypi:~ $
                            Sorry if this sounds a bit harsh, but to be honest, that’s an easy one that you can answer yourself with all the information you have in this thread already. You’re making the same mistake as yesterday.
                            Hint: Check where you are. Use “ls” (list content of current directory) and “cd”. Learn to read the path to know where you are.
                            • cruunnerrC Offline
                              cruunnerr @Duke86
                              u used “nmp install” instead of “npm install”
                              do exactly this:
                              cd
                              cd MagicMirror
                              npm install
                              wait for Installation complete. This will take a while. Just wait UNTIL u see the “pi@raspberrypi:” again and u are able to type new commands. Even if u can’t see an installation progress bar.
                              then type npm start or if u use ssh: DISPLAY=:0 npm start
                                Duke86
                                thanks you it has worked up until it said I need a config file
                                  I guess you have to create a config file. ;) Did you read the Readme @ https://github.com/MichMich/MagicMirror (scroll down a little)?
                                  The MagicMirror, as the readme points out, comes with a config example. Create a config file by copying the example file with this command:
                                  cp config/config.js.sample config/config.js Use this command from the MagicMirror folder!
                                  (The way this works is: copy | original/file.js | target/file.js)
                                    Duke86
                                    thanks, I think it works I will try now I really appreciate your help
                                    I will put the code down below
                                    pi@raspberrypi:~/MagicMirror $ npm run config:check
                                    magicmirror@2.2.2 config:check /home/pi/MagicMirror
                                    node tests/configs/check_config.js
                                    Checking file… /home/pi/MagicMirror/config/config.js
                                    Line 96 col 5 Label ‘file’ on statement.
                                    Line 96 col 5 Unexpected early end of program.
                                    Line 97 col 1 Unrecoverable syntax error. (100% scanned).
                                      Did you copy the config.js.example to config.js with the code above? Have you made any changes inside config.js yet?
                                      Can you cd into the config folder and tell us what ls (list) is showing?
                                        https://forum.magicmirror.builders/topic/4528/how-to-create-a-working-config-for-absolute-beginners
                                          Duke86
                                          follwed your guide still got the same messsage
                                            cruunnerr
                                            In the sample config there is no line 96 !!!
                                            don’t know what u did, but maybe u should read a little more accurate as doubleT said before. I don’t want to attack you.
                                            Just delete your config file, copy this here and rename it to “config.js” and put it in your config folder. This should work
