    Hello-Lucy
    Scheduled Pinned Locked Moved Fun & Games
    285 Posts 27 Posters 679.5k Views 27 Watching
      Mykle1 Project Sponsor Module Developer @Anthony
      @anthony
      Are you using a Pi? The Pi may struggle with this because of 1) The use of a usb microphone and 2) The amount and type of modules you are using
        Anthony Project Sponsor @Mykle1
        @mykle1
        Yes, I am using a rpi 3b+. I know that I must be patient during commands because of the usb mic but the problem is that I have to say my keyword more than 10 times to start flashing the mic icon. After that all modules show/hide quite well and quick. Basically I did a fresh install of raspbian and MM on new 32GB SD card, hoping that it will work better but I have the same problem. It just doesn’t hear the keyword. Also I would like to ask you if it is possible the Say, ‘Hello Lucy’ message.
          mash55
          check the logs… they should give you an idea what happened. What I was confronted with was a) missing variables (LD_LIBRARY_PATH= and PKG_CONFIG_PATH=). They should be added by the installation script (assuming you chose the automatic install.
          After solving this issue I had b) a DEVICE BUSY due to the fact that pulseaudio was already ‘sitting’ on my microphone.
            @anthony said in Hello-Lucy:
            I would guess that is due to the Pi’s performance and the latency introduced by the use of your USB mic. Also, a vocal accent while speaking English commands to Lucy seem to be a problem. I’ve a friend in Norway who speaks English very well but Lucy has a problem with his Norwegian accent.
            With that said, I can’t help you with performance issues other than to suggest limiting or eliminating those modules that have high resource demands.
            I don’t understand the question, I’m sorry.
              @mykle1 said in Hello-Lucy:
              Sorry I didn’t write it right. I would like to ask you if it is possible to change the Say, ‘Hello Lucy’ message to something mine. As for the mic’s latency I will buy a better one and see the difference. Thank you for your tips and “Hello Lucy” :winking_face:
                sdetweil @Anthony
                @anthony yes, Hello_Lucy is a customized MMM-Voice… in the MMM-Voice readme it says
                Config Options
                Option	Default	Description
                microphone	REQUIRED	Id of microphone shown in the installer.
                keyword	'MAGIC MIRROR'	Keyword the mirror starts to listen. IMPORTANT: Only UPPERCASE Letters
                timeout	15	time the keyword should be active without saying something
                  Anthony Project Sponsor @sdetweil
                  This is the keyword. I already have changed that. I want to change the message which appears when MM starts. Now it say: Say ‘Hello Lucy’. I want to change it to Say, ‘Magic Mirror’.
                  S M Mykle1M 3 Replies Last reply Reply Quote 0
                    sdetweil @Anthony
                    @anthony I use Hello Lucy and don’t see that… do you have EasyPics installed too? I do not.
                      mash55 @Anthony
                      @anthony change
                       mode: 'Say, "Hello Lucy"',
                      in MMM-voice.js
                        Anthony Project Sponsor @mash55
                        @mash55
                        I have already tried that but the message remains the same in the screen.
                        • 16
                        • 17
                        • 18
                        • 19
                        • 20
                        • 28
                        • 29
                        • 18 / 29
