    Calendar Overflow Issue [solved]
    12 Posts 2 Posters 8.5k Views 1 Watching
      MechMatt
      I know this has been brought up before and is currently being looked at by moment.js people but I thought I could post this as a new topic so anyone that was able to find a solution or temporary work-around could help.
      The calendar module has an overflow issue with the dates which displays as follows:
      0_1462841690531_upload-185fc410-a598-4791-bab1-9c1f710cf57e
      If anyone has any thoughts on this it would be greatly appreciated. Thanks!
      • MichMichM Offline
        MichMich
        The only current ‘solution’ is using the 24 hour notation. I really hope Moment.js will save this bug asap. Rewriting all of this in a custom date formatter would be an ridiculous amount of work.
          MechMatt @MichMich
          @MichMich how do you change the calendar to 24 hr? When i set the timeformat variable to 24 it only changes the clock and weather modules.
          • MichMichM Offline
            MichMich
            I’m sorry … just checked: the time format of the clock is tied to the language (locale). There currently is no way to change the time format of the calendar.
              MechMatt @MichMich
              @MichMich ok. Its also worth noting that I do not have the overflow issue with the clock module in 12 hr format as others have reported. My overflow issue only affects the calendar module.
              MichMichM 1 Reply Last reply Reply Quote 0
              • MichMichM Offline
                MichMich @MechMatt
                @MechMatt That’s correct. The clock and weather currently have a hot fix in place. (Something which is more difficult for the calendar.)
                • MichMichM Offline
                  MichMich
                  I just pushed a possible fix for this issue. Could you give it a try?
                  (more info: https://github.com/MichMich/MagicMirror/issues/181)
                    MechMatt
                    awesome! I loaded it up and so far its looking good (been about an hour so far and usually the overflow problem happens within a few mins). I will leave it on for a while longer and report back if any issues come up.
                    • MichMichM Offline
                      MichMich @MechMatt
                      @MechMatt good to hear!
                      • MichMichM Offline
                        MichMich
                        @MechMatt: any news regarding the overflow. Is it solved?
                          MechMatt @MichMich
                          @MichMich Its been on for 24 hours and still looking good!
                          • MichMichM Offline
                            MichMich
                            Thanks. I’ve closed the issue.
