    mp2 won"t start properly
    5 Posts 3 Posters 1.9k Views 3 Watching
    • D
      dnzio
      Hi I am noob on this project, I would like some help with this
      pi@mmanon:~ $ pm2 startup
      [PM2] Init System found: systemd
      [PM2] To setup the Startup Script, copy/paste the following command:
      sudo env PATH=$PATH:/usr/bin /usr/lib/node_modules/pm2/bin/pm2 startup systemd -u pi --hp /home/pi
      pi@mmanon:~ $
      Mykle1M Y 2 Replies Last reply Reply Quote 0
      • Mykle1M
        Mykle1 Project Sponsor Module Developer @dnzio
        @dnzio
        That would be pm2 start mm or pm2 start magicmirror
        https://github.com/MichMich/MagicMirror/wiki/Auto-Starting-MagicMirror
        • Y
          yawns Moderator @dnzio
          @dnzio
          Do, did you do what pm2 told you? Did you copy and paste this and ran it in shell?
          D 1 Reply Last reply Reply Quote 2
          • D
            dnzio @yawns
            @yawns I don’t know how to run and put it in shell. Can you help me? thank you.
            • Y
              @dnzio
              You start the shell/terminal/bash either directly on the pi, via ssh (putty for example) or via vnc and either type or copy paste the command
              Then you press enter
