    How to update the master branch?
    19 Posts 15 Posters 18.3k Views 12 Watching
    • N Offline
      ninjabreadman @strawberry 3.141
      @e3v3a I take your point; in my case I’m running a reasonable size card and Raspbian/MM are all that is on the card. I do also mention to delete MM-Backup when they’re done. I really just wanted to give them the extra insurance of a full backup. Good call on tar, but they then need to know how to unpack it.
      @strawberry-3.141 If you’re using git to stash changes, then you’ve clearly modified other files (IIRC, config.js and maybe custom.css are ignored). As above, I just wanted to give extra assurance that they had a full copy if anything went totally awry.
      Problem with config or JavaScript? Copy/paste it into JSHint.
      Check out the detailed walkthroughs on install, config, modules, etc.
        Dicous
        Hallo,
        noob braucht hilfe =)
        Wie kann ich bei dieser Fehlermeldung updaten?
        pi@raspberrypi:~ $ cd ~/MagicMirror && git pull
        Aktualisiere 8010e62..60b9a5b
        error: Your local changes to the following files would be overwritten by merge:
                modules/default/calendar/calendar.js
                modules/default/compliments/compliments.js
        • F Offline
          Frans @ninjabreadman
          @ninjabreadman - I tried to update accordingly your reply but i’m stranded. After git stash the system tells me
          pi@magicpi:~/MagicMirror $ git stash
          *** Please tell me who you are.
          Run
            git config --global user.email "you@example.com"
            git config --global user.name "Your Name"
          to set your account's default identity.
          Omit --global to set the identity only in this repository.
          fatal: unable to auto-detect email address (got 'pi@magicpi.(none)')
          Cannot save the current index state
          I don’t know how to react on this, you?
            sdetweil @Frans
            @frans said in How to update the master branch?:
            git config --global user.email “you@example.com”
            git config --global user.name “Your Name”
            type those commands, add your email and name
            git doesn’t allow anonymous actions
            F 1 Reply Last reply Reply Quote 1
            • F Offline
              Frans @sdetweil
              @sdetweil said in How to update the master branch?:
              Worked!! Thanks!
                robiv8
                Und was soll uns das sagen?
                Any info about this error?
                pi@WEG-Infopanel:~/MagicMirror $ git stash
                package-lock.json: needs merge
                vendor/package-lock.json: needs merge
                package-lock.json: unmerged (928d17635a4aff632b96c3d78499948e24eb70be)
                package-lock.json: unmerged (1e84cc321d5ecb4199add46a08bfd7f3446d9c11)
                package-lock.json: unmerged (281f5adadabad8c0fa36c54a8b5c882b66e06722)
                vendor/package-lock.json: unmerged (a326b4026808f4b1ab060fe3c12e385f82330759)
                vendor/package-lock.json: unmerged (793948105835abe0d92caaf321cb78150cc983a4)
                vendor/package-lock.json: unmerged (9ad15ee58a9adce0f84708789296d2ae2ec1e029)
                fatal: git-write-tree: error building trees
                Kann den aktuellen Zustand des Index nicht speichern
                • bheplerB Offline
                  bhepler Module Developer @robiv8
                  @robiv8 - You can delete those files and then do another git pull. So:
                  cd ~/MagicMirror
                  rm package-lock.json
                  rm vendor/package-lock.json
                  git pull
                  npm install
                    shazam23 @ninjabreadman
                    @ninjabreadman I followed these steps and after running git stash apply I still get the “please commit changes” message…I’ve already backed up so unless the new update is thinking it also needs to be backed up I’m lost
                    • T Offline
                      tcsabina @shazam23
                      @shazam23
                      You have modified files that has not been ‘saved’ in the git database. Type ‘git status’, and it will list those changes.
                      After that you can decide what to do: keep the changes (in this case use ‘git commit’)
                      revert or discard the changes (in this case ‘git checkout’ is the command, if I am not mistaken)
                      Not sure what exactly you try to achieve, but for an update I would use a fresh directory instead. Just create a new one and clone into it…
