    How to update the master branch?
    19 Posts 15 Posters 20.1k Views 12 Watching
    • N Offline
      navyvette87
      Thanks guys, I have one more to upgrade. And figure out why MMM-Traffic won’t upgrade, but I think you way around would help that to.
      MichMichM 1 Reply Last reply Reply Quote 0
      • MichMichM Offline
        MichMich @navyvette87
        cd ~/MagicMirror/modules/MMM-Traffic
        git pull
        Restart your MagicMirror and you should be good to go. ;)
        • E Offline
          E3V3A @ninjabreadman
          @ninjabreadman said in How to update the master branch?:
          @PaulB First, make a backup of your install with cp -r ~/MagicMirror ~/MM-Backup.
          Noo! Not a good idea if you’re running on a RPi with small SD card. That is a huge directory: du -sh ./ ~1.3GB, already for a quite small install. You might need that space for the update itself. Never good idea to max out your SD card.
          Rather use tar, and try one of these:
          cd ~
          # remove `v` flag to avoid huge verbose output
          tar --exclude={.git,node_modules} -zcvf MM_BAK.tgz ./MagicMirror
          tar --exclude='node_modules' --exclude='.git' -zcvf MM_BAK.tgz ./MagicMirror
          # This may require you to have the bash shell option globstar' set.
          # Check with: 'shopt -s globstar'
          tar --exclude='**/.git/*' --exclude='**/node_modules/*' -zcvf MM_BAK.tgz ./MagicMirror
          This will avoid getting the huge node_modules and .git directories.
          (You can always git init and reset your git origin url to git fetch from the resp directories if needed to re-instate.)
          “Everything I do (here) is for free – altruism is the way!”
          • strawberry 3.141S Offline
            if you are using mm as supposed to you only need to backup the config.js and custom.css
            N 1 Reply Last reply Reply Quote 1
            • N Offline
              ninjabreadman @strawberry 3.141
              @e3v3a I take your point; in my case I’m running a reasonable size card and Raspbian/MM are all that is on the card. I do also mention to delete MM-Backup when they’re done. I really just wanted to give them the extra insurance of a full backup. Good call on tar, but they then need to know how to unpack it.
              @strawberry-3.141 If you’re using git to stash changes, then you’ve clearly modified other files (IIRC, config.js and maybe custom.css are ignored). As above, I just wanted to give extra assurance that they had a full copy if anything went totally awry.
                Dicous
                Hallo,
                noob braucht hilfe =)
                Wie kann ich bei dieser Fehlermeldung updaten?
                pi@raspberrypi:~ $ cd ~/MagicMirror && git pull
                Aktualisiere 8010e62..60b9a5b
                error: Your local changes to the following files would be overwritten by merge:
                        modules/default/calendar/calendar.js
                        modules/default/compliments/compliments.js
                • F Offline
                  Frans @ninjabreadman
                  @ninjabreadman - I tried to update accordingly your reply but i’m stranded. After git stash the system tells me
                  pi@magicpi:~/MagicMirror $ git stash
                  *** Please tell me who you are.
                  Run
                    git config --global user.email "you@example.com"
                    git config --global user.name "Your Name"
                  to set your account's default identity.
                  Omit --global to set the identity only in this repository.
                  fatal: unable to auto-detect email address (got 'pi@magicpi.(none)')
                  Cannot save the current index state
                  I don’t know how to react on this, you?
                    sdetweil @Frans
                    @frans said in How to update the master branch?:
                    git config --global user.email “you@example.com”
                    git config --global user.name “Your Name”
                    type those commands, add your email and name
                    git doesn’t allow anonymous actions
                    F 1 Reply Last reply Reply Quote 1
                    • F Offline
                      Frans @sdetweil
                      @sdetweil said in How to update the master branch?:
                      Worked!! Thanks!
                        robiv8
                        Und was soll uns das sagen?
                        Any info about this error?
                        pi@WEG-Infopanel:~/MagicMirror $ git stash
                        package-lock.json: needs merge
                        vendor/package-lock.json: needs merge
                        package-lock.json: unmerged (928d17635a4aff632b96c3d78499948e24eb70be)
                        package-lock.json: unmerged (1e84cc321d5ecb4199add46a08bfd7f3446d9c11)
                        package-lock.json: unmerged (281f5adadabad8c0fa36c54a8b5c882b66e06722)
                        vendor/package-lock.json: unmerged (a326b4026808f4b1ab060fe3c12e385f82330759)
                        vendor/package-lock.json: unmerged (793948105835abe0d92caaf321cb78150cc983a4)
                        vendor/package-lock.json: unmerged (9ad15ee58a9adce0f84708789296d2ae2ec1e029)
                        fatal: git-write-tree: error building trees
                        Kann den aktuellen Zustand des Index nicht speichern
                          bhepler Module Developer @robiv8
                          @robiv8 - You can delete those files and then do another git pull. So:
                          rm package-lock.json
                          rm vendor/package-lock.json
                          git pull
                          npm install
                            shazam23 @ninjabreadman
                            @ninjabreadman I followed these steps and after running git stash apply I still get the “please commit changes” message…I’ve already backed up so unless the new update is thinking it also needs to be backed up I’m lost
                            • T Offline
                              tcsabina @shazam23
                              @shazam23
                              You have modified files that has not been ‘saved’ in the git database. Type ‘git status’, and it will list those changes.
                              After that you can decide what to do: keep the changes (in this case use ‘git commit’)
                              revert or discard the changes (in this case ‘git checkout’ is the command, if I am not mistaken)
                              Not sure what exactly you try to achieve, but for an update I would use a fresh directory instead. Just create a new one and clone into it…
