    How to update the master branch?
    19 Posts 15 Posters 20.2k Views 12 Watching
    • MichMichM
      MichMich @navyvette87
      cd ~/MagicMirror/modules/MMM-Traffic
      git pull
      Restart your MagicMirror and you should be good to go. ;)
      • E
        E3V3A @ninjabreadman
        @ninjabreadman said in How to update the master branch?:
        @PaulB First, make a backup of your install with cp -r ~/MagicMirror ~/MM-Backup.
        Noo! Not a good idea if you’re running on a RPi with small SD card. That is a huge directory: du -sh ./ ~1.3GB, already for a quite small install. You might need that space for the update itself. Never good idea to max out your SD card.
        Rather use tar, and try one of these:
        cd ~
        # remove `v` flag to avoid huge verbose output
        tar --exclude={.git,node_modules} -zcvf MM_BAK.tgz ./MagicMirror
        tar --exclude='node_modules' --exclude='.git' -zcvf MM_BAK.tgz ./MagicMirror
        # This may require you to have the bash shell option globstar' set.
        # Check with: 'shopt -s globstar'
        tar --exclude='**/.git/*' --exclude='**/node_modules/*' -zcvf MM_BAK.tgz ./MagicMirror
        This will avoid getting the huge node_modules and .git directories.
        (You can always git init and reset your git origin url to git fetch from the resp directories if needed to re-instate.)
        “Everything I do (here) is for free – altruism is the way!”
        • strawberry 3.141S
          if you are using mm as supposed to you only need to backup the config.js and custom.css
          N 1 Reply Last reply Reply Quote 1
          • N
            ninjabreadman @strawberry 3.141
            @e3v3a I take your point; in my case I’m running a reasonable size card and Raspbian/MM are all that is on the card. I do also mention to delete MM-Backup when they’re done. I really just wanted to give them the extra insurance of a full backup. Good call on tar, but they then need to know how to unpack it.
            @strawberry-3.141 If you’re using git to stash changes, then you’ve clearly modified other files (IIRC, config.js and maybe custom.css are ignored). As above, I just wanted to give extra assurance that they had a full copy if anything went totally awry.
              Dicous
              Hallo,
              noob braucht hilfe =)
              Wie kann ich bei dieser Fehlermeldung updaten?
              pi@raspberrypi:~ $ cd ~/MagicMirror && git pull
              Aktualisiere 8010e62..60b9a5b
              error: Your local changes to the following files would be overwritten by merge:
                      modules/default/calendar/calendar.js
                      modules/default/compliments/compliments.js
              • F
                Frans @ninjabreadman
                @ninjabreadman - I tried to update accordingly your reply but i’m stranded. After git stash the system tells me
                pi@magicpi:~/MagicMirror $ git stash
                *** Please tell me who you are.
                Run
                  git config --global user.email "you@example.com"
                  git config --global user.name "Your Name"
                to set your account's default identity.
                Omit --global to set the identity only in this repository.
                fatal: unable to auto-detect email address (got 'pi@magicpi.(none)')
                Cannot save the current index state
                I don’t know how to react on this, you?
                  sdetweil @Frans
                  @frans said in How to update the master branch?:
                  git config --global user.email “you@example.com”
                  git config --global user.name “Your Name”
                  type those commands, add your email and name
                  git doesn’t allow anonymous actions
                  F 1 Reply Last reply Reply Quote 1
                  • F
                    Frans @sdetweil
                    @sdetweil said in How to update the master branch?:
                    Worked!! Thanks!
                      robiv8
                      Und was soll uns das sagen?
                      Any info about this error?
                      pi@WEG-Infopanel:~/MagicMirror $ git stash
                      package-lock.json: needs merge
                      vendor/package-lock.json: needs merge
                      package-lock.json: unmerged (928d17635a4aff632b96c3d78499948e24eb70be)
                      package-lock.json: unmerged (1e84cc321d5ecb4199add46a08bfd7f3446d9c11)
                      package-lock.json: unmerged (281f5adadabad8c0fa36c54a8b5c882b66e06722)
                      vendor/package-lock.json: unmerged (a326b4026808f4b1ab060fe3c12e385f82330759)
                      vendor/package-lock.json: unmerged (793948105835abe0d92caaf321cb78150cc983a4)
                      vendor/package-lock.json: unmerged (9ad15ee58a9adce0f84708789296d2ae2ec1e029)
                      fatal: git-write-tree: error building trees
                      Kann den aktuellen Zustand des Index nicht speichern
                        bhepler Module Developer @robiv8
                        @robiv8 - You can delete those files and then do another git pull. So:
                        rm package-lock.json
                        rm vendor/package-lock.json
                        git pull
                        npm install
                          shazam23 @ninjabreadman
                          @ninjabreadman I followed these steps and after running git stash apply I still get the “please commit changes” message…I’ve already backed up so unless the new update is thinking it also needs to be backed up I’m lost
                          • T
                            tcsabina @shazam23
                            @shazam23
                            You have modified files that has not been ‘saved’ in the git database. Type ‘git status’, and it will list those changes.
                            After that you can decide what to do: keep the changes (in this case use ‘git commit’)
                            revert or discard the changes (in this case ‘git checkout’ is the command, if I am not mistaken)
                            Not sure what exactly you try to achieve, but for an update I would use a fresh directory instead. Just create a new one and clone into it…
