    Paul's second mirror :)
    3 Posts 2 Posters 4.1k Views 2 Watching
    • P
      PaulB
      Dear fellow MM-builders,
      I would like to show you the build to my second MagicMirror.
      Unfortunately the glas broke during a move to another city, so I decided that it was time for a second try.
      This time I used following parts:
      • picture frame Ribba from IKEA 50cm*70cm
        –> it includes a neat passepartout which was useful to hide some of the cracks in the mirror
        -24" monitor Acer KA241bid
        –> a cheap monitor which is also very thin and has a HDMI output
      • then I 've cut some of the parts of my old mirror which weren’t cracked
        –> I used a glas cutting tool and watched a lot of DIY youtube videos on how to cut glas, because I not such a craftsman :-D
      • If you want a more cheap solution instead of buying an actual mirror, you can use the Polycarbonat plat which is included in the Ribba frame from IKEA and use silver reflection folie
      • a short HDMI cable
      • for wifi connection I used the CSL - 300 Mbit/s USB 2.0 WLAN
        –> you just have to install the software from CSL (raspberry Pi needs a LAN connection) after that its super easy :)
      • a wall mount
      • wood from the local store as well as screws
      • male to female wires
      • a DHT22-Sensor as well as a PIR sensor
      I was a lot of fun putting it all together and doing a little bit of programming by myself.
      As always, you guys helped me a lot in doing so!
      Thank you very much :)
      • lavolp3L
        lavolp3 Module Developer
        Great work Paul!
        Good idea building it with a ribba and passepartout!
        2 questions:
        • How does it look from the side / how is it mounted.
        • And where is your PIR sensor?
        How to troubleshoot modules
        MMM-soccer v2, MMM-AVStock
        • P
          PaulB
          @lavolp3
          It it mounted on the wall via a wall mount which is connected to the screen.
          The whole frame is connected to the screen through a frame made of wood.
          The DHT-22 as well as the PIR Sensor are located on the right, right behind the frame.
          I did not find a good solution on how to “hide” the PIR Sensor, so I though I should hide it a little bit.
