    MMM-FRITZ-Box-Callmonitor
    99 Posts 27 Posters 115.4k Views 26 Watching
      requiemmg @sdetweil
      @sdetweil Thanks, yes, this has been installed with sudo apt-get install python-dev libxml2-dev libxslt1-dev zlib1g-dev && sudo pip install fritzconnection as stated on the plugins’ page (https://github.com/paviro/MMM-FRITZ-Box-Callmonitor) and https://pypi.org/project/fritzconnection/
      And as stated above: When I call fritzconnection from shell, it works. But when I call the script used by the plugin, it fails on the import of the library and I have no idea why.
        sdetweil @requiemmg
        @requiemmg said in MMM-FRITZ-Box-Callmonitor:
        typically this fails cause the python ‘virtual environment’ is not setup correctly
        https://www.tutorialspoint.com/python/python_environment.htm
        usually that means the shell started from code (not UI) startup script (usually ~/.bashrc, for bash ) doesn’t set the PATH correctly
          requiemmg @sdetweil
          @sdetweil Tried to fix this with
          export PATH=“$PATH:/usr/local/bin/fritzconnection”
          and
          export PATH=“$PATH:/usr/local/bin/python”
          to no avail…error stays the same
            sdetweil @requiemmg
            @requiemmg where?
              requiemmg
              from where I executed this command? from the modules’ directory.
              The module is working if I use the .vcf method. But not if I want to log in via the module to fetch the latest calls.
                sdetweil @requiemmg
                i don’t know what that means, but I assume that the module will exec or spawn the script somehow
                and THAT is where the path needs to be set , at the time of exec/spawn
                  requiemmg @sdetweil
                  @sdetweil When I put it in the script in the first line, it will thow an invalid syntax error. Sorry, I guess I have to stick with the current functionality, I have no programming skills.
                  Thanks for your help.
                    sdetweil @requiemmg
                    @requiemmg no… it would be in the module code that launches the script
                      requiemmg @sdetweil
                      @sdetweil Thanks. That’s way beyond my abilities.
                      • 6
                      • 7
                      • 8
                      • 9
                      • 10
                      • 10 / 10
