    MMM-FRITZ-Box-Callmonitor
    99 Posts 27 Posters 123.3k Views 26 Watching
    • O Offline
      ostfilinchen @kwaeksler
      @kwaeksler if you start the mirror with pm2, what says the pm2 logs mm?
      • K Offline
        kwaeksler @ostfilinchen
        @ostfilinchen said in MMM-FRITZ-Box-Callmonitor:
        in mm-error-0.log i searched for “callmonitor” and got this error:
        TypeError: path must be a string or Buffer
        at TypeError (native)
        at Object.fs.readFile (fs.js:303:11)
        at Object.fs.readFile (ELECTRON_ASAR.js:451:25)
        at Object.parseVcardFile (/home/pi/MagicMirror/modules/MMM-FRITZ-Box-Callmonitor/node_modules/vcard-json/lib/vcard-json.js:65:6)
        at Class.parseVcardFile (/home/pi/MagicMirror/modules/MMM-FRITZ-Box-Callmonitor/node_helper.js:107:9)
        at Class.socketNotificationReceived (/home/pi/MagicMirror/modules/MMM-FRITZ-Box-Callmonitor/node_helper.js:56:10)
        at Socket. (/home/pi/MagicMirror/modules/node_modules/node_helper/index.js:98:10)
        at emitTwo (events.js:106:13)
        at Socket.emit (events.js:191:7)
        at Socket.onevent (/home/pi/MagicMirror/node_modules/socket.io/lib/socket.js:335:8)
        Missing error handler on socket.
        • O Offline
          @kwaeksler it looks, that u have activate the vCard option. Is that right? If no… Do u had installed the latest Version of this module?
          • K Offline
            @ostfilinchen
            i tried the vCard option first, but actually it should be disabled…
            i think so. with git pull in “/MagicMirror/modules/MMM-FRITZ-Box-Callmonitor” i get “Already up-to-date”.
            • O Offline
              @kwaeksler can u Check this config:
                  module: 'MMM-FRITZ-Box-Callmonitor',
                  position: 'top_left',  // This can be any of the regions. Best results in left or right regions.
                  header: "kürzliche Anrufe", // This is optional
              			maximumCallDistance: 7200,
              			username: "benutzer",
              			password: "passwort,
              			showContactsStatus: true,
              			//vCard: true
              			//maximumCalls: 10
              Y K 2 Replies Last reply Reply Quote 0
              • Y Offline
                yawns Moderator @ostfilinchen
                @ostfilinchen
                There is a " missing after passwort
                • K Offline
                  @ostfilinchen my current config looks like this:
                          position: 'top_right',
                          header: "Anrufliste",
                  			username: "***********",
                  			password: "********************",
                  			vCard: false
                  i think it looks good?
                  • O Offline
                    @kwaeksler yes. It looks good. Is the Module now working?
                    • K Offline
                      @ostfilinchen No :-(
                      i still get a small warning sign and an “unknown error”
                      the incoming call shows me a number, not a name.
                      • O Offline
                        @kwaeksler puh… now I have no ideas. You have create an User and password in the fritz.box?
                        And… Do u have Updated your rpi?
                        sudo apt-get update
                        sudo apt-get dist-upgrade
                        sudo reboot
                        If After this the Module doesn’t work open an issue on github.
                          boardnick
                          Hello everybody,
                          first of all @ostfilinchen: Thank you for your great support!
                          I just want to tell you, that kwaeksler is not the only one facing this problem.
                          Exactly this problem also appears on my MagicMirror installation.
                          Currently i have no possibility to check anything regarding my MagicMirror installation, but as soon as i have time (this weekend) i’m going to catch some more information that may be helpful for you (firmware version FritzBox, config MagicMirror, …).
                          I already tried
                          sudo apt-get update
                          sudo reboot
                          without succes.
                          Additionally i’m going to try
                          sudo apt-get update
                          sudo reboot
                          Best regards
                          Aaron
                          • K Offline
                            @ostfilinchen
                            Yes, i updated the pi yesterday with:
                            sudo apt-get update
                            sudo reboot
                            after a long time of waiting the same warning sign :-(
                            • O Offline
                              @kwaeksler which nodejs Version Do u have? You can Check this with nodejs -v
                              My Version is 7.4.0
                              Maybe it’s a good idea to update this with
                              curl -sL https://deb.nodesource.com/setup_7x | sudo -E bash -
                              sudo apt-get install -y nodejs
                              sudo npm install -g npm
                              • K Offline
                                @ostfilinchen i had the nodejs Version 6.9.4.
                                So i updated the version with:
                                curl -sL https://deb.nodesource.com/setup_7.x | sudo -E bash -
                                Now i have Version v7.4.0 but still the same error like before :-(
                                O J 2 Replies Last reply Reply Quote 0
                                • O Offline
                                  @kwaeksler do you really have Version 7.4.0? in some cases you must execute the command sudo npm install -g npm two times.
                                  if you’re sure that u have v7.4.0 and the module doesn’t work, please delete the Folder of the module (MMM-FRITZ-Box-Callmonitor) and reinstall again.
                                    Jopyth Moderator @kwaeksler
                                    @kwaeksler Also, is there any new output in the logs?
                                    Helpful sticky: How to troubleshoot
                                      boardnick
                                      Hi alltogether,
                                      as suggested by ostfilinchen i updated nodejs with the same commands as kwaekler: Also without success :-(
                                      In addition and also suggested by ostfilinchen i removed the module folder and reinstalled the module again: Also without success :-(
                                      @Jopyth (btw: Thank you for supporting us!):
                                      mm-error-0.log tells me the following
                                      MMM-FRITZ-Box-Callmonitor error while accessing FRITZ!Box:
                                      Traceback (most recent call last):
                                        File "/home/pi/MagicMirror/modules/MMM-FRITZ-Box-Callmonitor/fritz_access.py", line 1, in
                                          import argparse, os, fritzconnection, urllib2, sys, json
                                        File "/usr/local/lib/python2.7/dist-packages/fritzconnection/__init__.py", line 3, in
                                          from .fritzconnection import (
                                        File "/usr/local/lib/python2.7/dist-packages/fritzconnection/fritzconnection.py", line 39, in
                                          from lxml import etree
                                      ImportError: No module named lxml
                                      As promissed before just some additional environmental informations from my side:
                                      • Fritz!Box Fon WLAN 7390 (UI) with Fritz!OS, Version 06.51
                                      • Raspberry Pi 2 Model B V1.1, OS: 2016-11-25-raspbian-jessie-lite
                                      • Nodejs version 7.4.0
                                      • extract from config-.js regarding the module:
                                      			position: 'top_right',  // This can be any of the regions. Best results in left or right regions.
                                      			header: "Kürzliche Anrufe", // This is optional
                                      				fritzIP: '10.0.1.1',
                                      				username: 'magicmirror',
                                      				password: '**********',
                                      				reloadContactsInterval: 5,
                                      				debug: true,
                                      • O Offline
                                        ostfilinchen @boardnick
                                        @boardnick can u Login to the fritz.box with the User MagicMirror and the password?
                                          boardnick
                                          @ostfilinchen yes i’m able to login using this user / password.
                                            Jopyth Moderator @boardnick
                                            @boardnick From your logs I read, that lxml is not installed, did you execute step 3 of the installation?
                                            Edit: Did anything during execution of this command go wrong? sudo apt-get install python-dev libxml2-dev libxslt1-dev zlib1g-dev && sudo pip install fritzconnection
                                            • 2 / 5
