    MMM-FRITZ-Box-Callmonitor
    99 Posts 27 Posters 132.5k Views 26 Watching
    • K
      kwaeksler @ostfilinchen
      @ostfilinchen my current config looks like this:
              module: 'MMM-FRITZ-Box-Callmonitor',
              position: 'top_right',
              header: "Anrufliste",
              	maximumCallDistance: 7200,
      			username: "***********",
      			password: "********************",
      			showContactsStatus: true,
      			vCard: false
      i think it looks good?
      O 1 Reply Last reply
      • O
        ostfilinchen @kwaeksler
        @kwaeksler yes. It looks good. Is the Module now working?
        K 1 Reply Last reply
        • K
          @ostfilinchen No :-(
          i still get a small warning sign and an “unknown error”
          the incoming call shows me a number, not a name.
          • O
            @kwaeksler puh… now I have no ideas. You have create an User and password in the fritz.box?
            And… Do u have Updated your rpi?
            sudo apt-get update
            sudo apt-get dist-upgrade
            sudo reboot
            If After this the Module doesn’t work open an issue on github.
            • boardnickB
              boardnick
              Hello everybody,
              first of all @ostfilinchen: Thank you for your great support!
              I just want to tell you, that kwaeksler is not the only one facing this problem.
              Exactly this problem also appears on my MagicMirror installation.
              Currently i have no possibility to check anything regarding my MagicMirror installation, but as soon as i have time (this weekend) i’m going to catch some more information that may be helpful for you (firmware version FritzBox, config MagicMirror, …).
              I already tried
              sudo apt-get update
              sudo reboot
              without succes.
              Additionally i’m going to try
              sudo apt-get update
              sudo reboot
              Best regards
              Aaron
              • K
                @ostfilinchen
                Yes, i updated the pi yesterday with:
                sudo apt-get update
                sudo reboot
                after a long time of waiting the same warning sign :-(
                • O
                  @kwaeksler which nodejs Version Do u have? You can Check this with nodejs -v
                  My Version is 7.4.0
                  Maybe it’s a good idea to update this with
                  curl -sL https://deb.nodesource.com/setup_7x | sudo -E bash -
                  sudo apt-get install -y nodejs
                  sudo npm install -g npm
                  • K
                    @ostfilinchen i had the nodejs Version 6.9.4.
                    So i updated the version with:
                    curl -sL https://deb.nodesource.com/setup_7.x | sudo -E bash -
                    Now i have Version v7.4.0 but still the same error like before :-(
                    O J 2 Replies Last reply
                    • O
                      @kwaeksler do you really have Version 7.4.0? in some cases you must execute the command sudo npm install -g npm two times.
                      if you’re sure that u have v7.4.0 and the module doesn’t work, please delete the Folder of the module (MMM-FRITZ-Box-Callmonitor) and reinstall again.
                        Jopyth Moderator @kwaeksler
                        @kwaeksler Also, is there any new output in the logs?
                        • boardnickB
                          boardnick
                          Hi alltogether,
                          as suggested by ostfilinchen i updated nodejs with the same commands as kwaekler: Also without success :-(
                          In addition and also suggested by ostfilinchen i removed the module folder and reinstalled the module again: Also without success :-(
                          @Jopyth (btw: Thank you for supporting us!):
                          mm-error-0.log tells me the following
                          MMM-FRITZ-Box-Callmonitor error while accessing FRITZ!Box:
                            File "/home/pi/MagicMirror/modules/MMM-FRITZ-Box-Callmonitor/fritz_access.py", line 1, in
                              import argparse, os, fritzconnection, urllib2, sys, json
                            File "/usr/local/lib/python2.7/dist-packages/fritzconnection/__init__.py", line 3, in
                              from .fritzconnection import (
                            File "/usr/local/lib/python2.7/dist-packages/fritzconnection/fritzconnection.py", line 39, in
                              from lxml import etree
                          ImportError: No module named lxml
                          As promissed before just some additional environmental informations from my side:
                          • Fritz!Box Fon WLAN 7390 (UI) with Fritz!OS, Version 06.51
                          • Raspberry Pi 2 Model B V1.1, OS: 2016-11-25-raspbian-jessie-lite
                          • Nodejs version 7.4.0
                          • extract from config-.js regarding the module:
                          			position: 'top_right',  // This can be any of the regions. Best results in left or right regions.
                          			header: "Kürzliche Anrufe", // This is optional
                          				fritzIP: '10.0.1.1',
                          				username: 'magicmirror',
                          				password: '**********',
                          				reloadContactsInterval: 5,
                          				debug: true,
                          • O
                            ostfilinchen @boardnick
                            @boardnick can u Login to the fritz.box with the User MagicMirror and the password?
                            • boardnickB
                              boardnick
                              @ostfilinchen yes i’m able to login using this user / password.
                                Jopyth Moderator @boardnick
                                @boardnick From your logs I read, that lxml is not installed, did you execute step 3 of the installation?
                                Edit: Did anything during execution of this command go wrong? sudo apt-get install python-dev libxml2-dev libxslt1-dev zlib1g-dev && sudo pip install fritzconnection
                                • boardnickB
                                  boardnick
                                  @Jopyth Thank you for your respond!
                                  Yes, i executed step 3 of the installation. As far as a remember nothing did go wrong.
                                  Hoping that i did not damage anything i executed your listed command one by one once again:
                                  –> already latest version
                                  sudo apt-get install libxml2-dev
                                  sudo apt-get install libxslt1-dev
                                  sudo apt-get install zlib1g-dev
                                  –> Requirement already satisfied (use --upgrade to upgrade): fritzconnection in /usr/local/lib/python2.7/dist-packages
                                  Cleaning up…
                                  So for the last command i additionally executed
                                  sudo pip install fritzconnection --upgrade
                                  –> Requirement already up-to-date: fritzconnection in /usr/local/lib/python2.7/dist-packages
                                  Cleaning up…
                                  J 1 Reply Last reply
                                    @boardnick That is strange. Can you try calling the python connection script directly? For example, replace your password, user and IP in this command python fritz_access.py -p passwd -u user -i 192.168.FRITZ.BOX? Needs to be called from the MMM-FRITZ-Box-Callmonitor directory.
                                    • boardnickB
                                      boardnick
                                      @Jopyth i tried calling it directly and get the same result:
                                      0_1485275096473_upload-ad5969e4-3d7d-42b8-80c5-6f033ec526f4
                                        @boardnick Well the good news in that case is: You just need to fix this error, and it should work fine. Does this work? Or any of the things google spits out? If yes, please let me know, maybe the current way of installing lxml is not the best one.
                                        • boardnickB
                                          boardnick
                                          @Jopyth i’m trying to test the recommended links this weekend and give you a feedback afterwards.
                                          Thank you so far!
                                          • boardnickB
                                            boardnick
                                            Hi @Jopyth, Hi all,
                                            good news: It works after installing python-lxml as follows:
                                            sudo apt-get install python-lxml
                                            Thank you very much for your support and have a nice weekend!
                                            • 2 / 5
