    MMM-FRITZ-Box-Callmonitor
    99 Posts 27 Posters 115.1k Views 26 Watching
    • H Offline
      Hellfire666
      my problem has vanished. I have reinstalled the module and did
      npm install
      twice, now it is working.
        domi256
        Hey i got a Problem with this module,
        I installed it from the instructions, and added this to config.js:
        			module: "MMM-FRITZ-Box-Callmonitor",
        			header: "Recent calls",
        				username: "raspi",
        				password: "domi1234",
        				maximumCallDistance: 7200,
        				showContactsStatus: true
        If i want to start it via npm start, i get an error Message like this:
        pi@mirror:~/MagicMirror $ npm start
        > magicmirror@2.1.1 start /home/pi/MagicMirror
        > sh run-start.sh
        Starting MagicMirror: v2.1.1
        Loading config ...
        Loading module helpers ...
        Module helper loaded: ping
        WARNING! Could not load config file. Starting with default configuration. Error found: Error: Cannot find module 'node-fritzbox-callmonitor'
        App threw an error during load
            at Module._resolveFilename (module.js:470:15)
            at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/electron/dist/resources/electron.asar/common/reset-search-paths.js:35:12)
            at Function.Module._load (module.js:418:25)
            at Module.require (module.js:498:17)
            at require (internal/module.js:20:19)
            at Object. (/home/pi/MagicMirror/modules/MMM-FRITZ-Box-Callmonitor/node_helper.js:4:21)
            at Object. (/home/pi/MagicMirror/modules/MMM-FRITZ-Box-Callmonitor/node_helper.js:259:3)
            at Module._compile (module.js:571:32)
            at Object.Module._extensions..js (module.js:580:10)
            at Module.load (module.js:488:32)
        { Error: Cannot find module 'node-fritzbox-callmonitor'
            at Module.load (module.js:488:32) code: 'MODULE_NOT_FOUND' }
        Launching application.
        Can someone help me please? :(
        Thank you verry much
        strawberry 3.141S yawnsY 2 Replies Last reply Reply Quote 0
        • strawberry 3.141S Offline
          strawberry 3.141 Project Sponsor Module Developer @domi256
          @domi256 looks like you didnt install the dependencies with npm install in /home/pi/MagicMirror/modules/MMM-FRITZ-Box-Callmonitor
          • yawnsY Offline
            yawns Moderator @domi256
            This post is deleted!
            • garblefluxG Offline
              garbleflux Project Sponsor @Jopyth
              @Jopyth I also have trouble with this module: Once I get a call, a window pops up and shows me the number. So far all o.k. But the recent call list is still empty.
              Maybe it depends on my Fritz!box configuration: I use for security a password to
              have access to the Fritz!box. in the configuration options for the MMM-Callmonitor I do not see an command to handle this password. Is it necessary to remove it?
              Regards Mike
              Sandy2503S 1 Reply Last reply Reply Quote 0
              • Sandy2503S Offline
                Sandy2503 @garbleflux
                @garbleflux - try to create a useraccount on the fritzbox (with name and password). ths works very well with my 7490 …
                garblefluxG 1 Reply Last reply Reply Quote 0
                  garbleflux Project Sponsor @Sandy2503
                  @Sandy2503 thank you for your kind reply. I already did create a useraccount. But with this data (User: raspi, password: xxxxxxxx) I do not have an access. So it is neccessary to disable the general Fritz!box password? Regards Mike
                    Sandy2503
                    Have you edit the fritz.box config ? I mean like in post #1.
                      rf0620
                      Like some other people here I wasn’t able to to read out the content of any phonebook from fritzbox. Only phone numbers were presented.
                      Also the command line didn’t work:
                      “python fritz_access.py -p password -u user -i ip-of-fritzbox”
                      Traceback (most recent call last):
                      File “fritz_access.py”, line 77, in
                      main(args)
                      File “fritz_access.py”, line 63, in main
                      handle.download_phone_book()
                      File “fritz_access.py”, line 22, in download_phone_book
                      result = self.fc.call_action(“X_AVM-DE_OnTel”, “GetPhonebookList”)
                      File “/usr/local/lib/python2.7/dist-packages/fritzconnection/fritzconnection.py”, line 405, in call_action
                      action = self._get_action(service_name, action_name)
                      File “/usr/local/lib/python2.7/dist-packages/fritzconnection/fritzconnection.py”, line 378, in _get_action
                      raise ServiceError('Unknown Service: ’ + service_name)
                      fritzconnection.fritzconnection.ServiceError: Unknown Service: X_AVM-DE_OnTel:1
                      Today I found a very simple answer: The used protocol TR-064 wasn’t activated on my fritz box!
                      According to this site I had to enable support for it. It worked for my FBF 7390 immediately. This setting has a different location than user mangament on current firmware versions.
                      2 1 Reply Last reply Reply Quote 2
                      • Z Offline
                        Zinkeler
                        Hello,
                        can someone tell me if it´s possible to sort the Output?
                        E.g. i see a call 3 days ago in the first line, then a call from 2 hours ago (second line), a call 2 day ago in 3rd line,…
                        I would like to see the youngest in the first line and the oldest in the last line.
                        Thanks for hints.
                        • 6
                        • 7
                        • 8
                        • 9
                        • 10
                        • 6 / 10
