    MMM-FRITZ-Box-Callmonitor
    99 Posts 27 Posters 106.1k Views 26 Watching
      sdetweil @Ghost2000
      @Ghost2000 if you use pm2 u have to stop that instance before using npm start
      pm2 stop all
      • G Offline
        Ghost2000
        Where can I find this file?
          sdetweil @Ghost2000
          @Ghost2000 come on. in the module folder, there is a folder called translations
          • G Offline
            Ghost2000
            Great thanksworks. @sdetweil
            De, json has to look like this for everyone
              "title": "Eingehender Anruf",
              "noCall": "Keine kürzlichen Anrufe.",
              "calllist_parse_error": "Anrufliste unlesbar.",
              "phonebook_parse_error": "Telefonbuch unlesbar.",
              "vcf_parse_error": "vCard unlesbar.",
              "login_error": "Logindaten falsch?",
              "network_error": "FRITZ!Box nicht erreichbar.",
              "unknown_error": "Unbekannter Fehler."
            en.json
              "title": "Incoming Call",
              "noCall": "No recent calls.",
              "calllist_parse_error": "Can't parse calllist.",
              "phonebook_parse_error": "Can't parse phonebook.",
              "vcf_parse_error": "Can't parse vCard.",
              "login_error": "Login data wrong?",
              "network_error": "Could not reach FRITZ!Box.",
              "unknown_error": "Unknown error."
              sdetweil @Ghost2000
              @Ghost2000 in 2.14 it will not fail like this, but the translation file will not be loaded. an error message in the dev window will indicate what file failed.
              fix also available in the develop branch
              this issue is pinned to the top of the troubleshooting section currently
              https://forum.magicmirror.builders/category/10/troubleshooting
              • F Offline
                Foxy25
                First: everything works well, but i have some question about the devicefilter:
                What do I have to register exactly there?
                The Telephonnumber? The name of the “device”? The “intern number”?
                I know that this works like:
                the “devicefilter entry” filters, the incoming calls for this phonenumber, out.
                In my case we have 3 DECT-Phones and i want display only one from this devices on the MM-Screen when the call come in.
                Thank you all for your Support.
                Greetngs from Germany
                Foxy
                • L Offline
                  Laurids @Foxy25
                  @foxy25 Hi, after a new installation of MagicMirror I have problems with the callmonitor. The MM shows the number of incoming calls, but the list of missing calls is empty. When I set
                  showContactsStatus: true
                  ,then I only get two rotating arrows behind “no calls”, instead of the number of entrys of my phonebook.
                  I tried all the advices in this thread, but nothing works. In another thread I found, that it would be helpful to uninstall Python and install version 0.5.0. Can someone explain, how to do this?
                  Thanks and best regards
                    ShadowMG Project Sponsor
                    Hi, tried endlessly on a new installation to get calls showing again.
                    Current call works
                    I get the error of:
                    pi@WestMainServ100:~/MagicMirror/modules/MMM-FRITZ-Box-Callmonitor $ python fritz_access.py -p xxxxxx -u xxx -i 192.168.62.1
                    Traceback (most recent call last):
                      File "fritz_access.py", line 1, in <module>
                        import argparse, os, fritzconnection, urllib2, sys, json
                    ImportError: No module named fritzconnection
                    Changed the files node_helper.js, package.json and fritz_access.py.
                    This is my config.js part:
                                    //disabled: true,
                                    module: 'MMM-FRITZ-Box-Callmonitor',
                                    position: 'top_left',   // This can be any of the regions. Best results in left or right regions.
                                    header: "Letzte Anrufe", // This is optional
                                            user: "",
                                            password: "xxxxxx",
                                            deviceFilter: ["TelefoneWestFritzbox"],
                                            vCard: "/home/pi/MagicMirror/contacts.vcf",
                                            maximumCallDistance: 3000,
                                            maximumCalls: 5,
                                            fritzIP: "192.168.62.1",
                    And the MMM-FRITZ-Box-Callmonitor.js:
                            // Default module config.
                            defaults: {
                                    numberFontSize: 30,
                                    vCard: true,
                                    fritzPort: 1012,
                                    minimumCallLength: 0,
                                    maximumCallDistance: 60,
                                    maximumCalls: 5,
                                    fade: true,
                                    debug: false,
                                    fadePoint: 0.25,
                                    username: "",
                                    password: "xxxxx",
                                    reloadContactsInterval: 30, // 30 minutes, set to 0 to disable
                                    deviceFilter: ["TelefoneWestFritzbox"], // [] means no filtering
                    I installed different versions of fritzconnect. No clue what to do next…
                    Thank you, Matthias
                      requiemmg @ShadowMG
                      @shadowmg
                      Just did a fresh install today. Installed MMM-FRRITZ-Box-Callmonitor, did npm install and installed fritzconnection.
                      Also installed fritzconnection.
                      pi@smartmirror:~/MagicMirror/modules/MMM-FRITZ-Box-Callmonitor $ fritzconnection
                      fritzconnection v1.8.0
                      FRITZ!Box 6591 Cable at http://169.254.1.1
                      FRITZ!OS: 7.29
                      But when I use
                      python fritz_access.py -u user -p pass -i 192.168.0.1
                      i get
                      Any idea on how to fix this? @paviro @sdetweil?
                        sdetweil @requiemmg
                        @requiemmg u need the python library for fritzconnection, whatever that is. separate install
                        • 6
                        • 7
                        • 8
                        • 9
                        • 10
                        • 9 / 10
