    MMM-FRITZ-Box-Callmonitor
    99 Posts 27 Posters 127.6k Views 26 Watching
      barnosch
      @paviro
      i have the problem currently that
      MMM-FRITZ-Box-Callmonitor is not working anymore.
      So the overlay when someone calls is not showing anymore.
      The current call works without problems.
      Nothing was changed. No idea what happened.
      Fritzbox settings wasn’t changed nor a firmware upgrade was done
      What do i need to check?
      • 2 Offline
        2fingers @rf0620
        @rf0620 i have tried to install the module and i had unnbekannte fehler (unknown issue) error . i followd all the steps but i have another error now:
        pi@raspberrypi:~ $ sudo pip install fritzconnection --upgrade
        Requirement already up-to-date: fritzconnection in /usr/local/lib/python2.7/dist-packages
        Collecting requests>=2.2.0 (from fritzconnection)
        Downloading requests-2.18.4-py2.py3-none-any.whl (88kB)
        100% |████████████████████████████████| 92kB 763kB/s
        Collecting lxml>=3.2.5 (from fritzconnection)
        Using cached lxml-4.1.1.tar.gz
        Collecting urllib3=1.21.1 (from requests>=2.2.0->fritzconnection)
        Downloading urllib3-1.22-py2.py3-none-any.whl (132kB)
        100% |████████████████████████████████| 133kB 880kB/s
        Collecting idna=2.5 (from requests>=2.2.0->fritzconnection)
        Downloading idna-2.6-py2.py3-none-any.whl (56kB)
        100% |████████████████████████████████| 61kB 1.5MB/s
        Collecting chardet=3.0.2 (from requests>=2.2.0->fritzconnection)
        Downloading chardet-3.0.4-py2.py3-none-any.whl (133kB)
        100% |████████████████████████████████| 143kB 983kB/s
        Collecting certifi>=2017.4.17 (from requests>=2.2.0->fritzconnection)
        Downloading certifi-2017.11.5-py2.py3-none-any.whl (330kB)
        100% |████████████████████████████████| 337kB 629kB/s
        Building wheels for collected packages: lxml
        Running setup.py bdist_wheel for lxml … /^error
        Failed building wheel for lxml
        Running setup.py clean for lxml
        Failed to build lxml
        Installing collected packages: urllib3, idna, chardet, certifi, requests, lxml
        Found existing installation: urllib3 1.19.1
        Not uninstalling urllib3 at /usr/lib/python2.7/dist-packages, outside environment /usr
        Found existing installation: idna 2.2
        Not uninstalling idna at /usr/lib/python2.7/dist-packages, outside environment /usr
        Found existing installation: chardet 2.3.0
        Not uninstalling chardet at /usr/lib/python2.7/dist-packages, outside environment /usr
        Found existing installation: requests 2.12.4
        Not uninstalling requests at /usr/lib/python2.7/dist-packages, outside environment /usr
        Found existing installation: lxml 3.7.1
        Not uninstalling lxml at /usr/lib/python2.7/dist-packages, outside environment /usr
        Running setup.py install for lxml … |^canceled
        Can’t rollback lxml, nothing uninstalled.
        Operation cancelled by user
        • C Offline
          Cyberdyne
          Please read this befor you update your Fritzbox with a new FritzOS!
          I upgraded my Fritzbox 6490 to the new FritzOS 7 and the callmonitor stoped working. I tried to but I could not reactivate the callmonitor. Nothing seemed to work and I thought I did something wrong. I contacted AVM to help and got a realy bad answer: They told me that AVM has removed the callmonitor functionality. I asked them how I could downgrade the OS to get the functionality back but they told me that there is no downgrade option. They also told me that they are going to remove the callmonitor functionality from all of their routers OSs.
          Warning to everyone: If you want to keep on using the callmonitor do not install FritzOS updates without checking if the new OS still supports the callmonitor. I would aks AVM befor updating.
          I am not sure if it helps but maybe everyone should write them an email and ask to keep or bring back this feature?!
          With this plugin I now can only see incomming calls (only the number) but no list with history of calls anymore. :o(
          • Sandy2503S Offline
            Sandy2503
            @Cyberdyne - Hmmmm thats strange. I am using a 7590 with the actual AVM OS7.01 from 20th September (and early Beta Versions) and the Call Monitor and Current Call works (with the 7590 and 7490) very well …
            Sandy2503
            • C Offline
              Cyberdyne
              I can only say what AVM has told me. Callmonitor is removed from the 6490 with the OS 7.0 and they also told me that they will remove it from all other boxes as well. They did not tell me in which version on which box. Hete are some emals:
              "Sie schildern, dass Sie den Callmonitor nicht mehr aktivieren können und möchten wissen, wieso dies der Fall ist. Ich bedauere diesen Umstand und nehme mich gerne der Sache an.
              Der Callmonitor wird mittlerweile nicht mehr von den FRITZ!Boxen unterstützt. Wenn Sie mit mitteilen, was genau Sie vorhaben, kann ich Ihnen ggf. Alternativen aufzeigen. "
              "Sie möchten wissen, bei welchen FRITZ!OS der Callmonitor noch unterstützt wird und wie Sie Ihre FRITZ!Box 6490 entsprechend downgraden können. Gerne beantworte ich Ihnen Ihre Frage.
              Ab welchen FRITZ!OS der Collmonitor nicht mehr unterstützt wurde, kann ich Ihnen nicht sagen, da dieser aufgrund der unterschiedlichen FRITZ!OS der verschiedenen FRITZ!Box-Modellen sukzessiv geschehen ist.
              Ein Downgrade von dem FRITZ!OS bei FRITZ!Box Cable ist leider nicht möglich."
              Just be carefull and better ask befor you make an other update if you want to keep on using the callmonitor! It does not work here anymore and no way back. :(
                darklight89
                Hi guys,
                how can I hide the call history, since the Fritz-Boxes Callmonitor seems to be deactivated in OS 7 and I want to keep at least the alert pop-up.
                  randpop
                  Re: MMM-FRITZ-Box-Callmonitor
                  Hi all,
                  i cannot get the module up and running.
                  I’ve tried all the above solutions and nothing really worked.
                  We got 2 FritzBoxes at work. One is our router (7590) and the other one (6490) is used as a cable modem and for the telephone connections.
                  Callerid and TR-064 access are activated on the 6490 and it is running with OS 6.50. The user i created has access to the FritzBox and has all the necessary rights.
                  I’ve tried a CallerMonitor App on macOS and it worked fine.
                  This is my config:
                                          module: 'MMM-FRITZ-Box-Callmonitor',
                                          position: 'bottom_left',
                                          header: "Anrufe",
                                          password: "PASSWORD",
                                          username: "USERNAME",
                                          fritzIP: "130.180.xx.xx",
                                          reloadContactsInterval: 1,
                                          vCard: false
                  When i test the connection with:
                  python fritz_access.py -p PASSWORD -u USER -i 130.180.xx.xx
                  i get this:
                  Traceback (most recent call last):
                    File "fritz_access.py", line 77, in
                      main(args)
                    File "fritz_access.py", line 63, in main
                      handle.download_phone_book()
                    File "fritz_access.py", line 22, in download_phone_book
                      result = self.fc.call_action("X_AVM-DE_OnTel", "GetPhonebookList")
                    File "/usr/local/lib/python2.7/dist-packages/fritzconnection/fritzconnection.py", line 406, in call_action
                      return action.execute(**kwargs)
                    File "/usr/local/lib/python2.7/dist-packages/fritzconnection/fritzconnection.py", line 130, in execute
                      result = self.parse_response(response.content)
                    File "/usr/local/lib/python2.7/dist-packages/fritzconnection/fritzconnection.py", line 142, in parse_response
                      root = etree.fromstring(response)
                    File "src/lxml/etree.pyx", line 3222, in lxml.etree.fromstring
                    File "src/lxml/parser.pxi", line 1877, in lxml.etree._parseMemoryDocument
                    File "src/lxml/parser.pxi", line 1765, in lxml.etree._parseDoc
                    File "src/lxml/parser.pxi", line 1127, in lxml.etree._BaseParser._parseDoc
                    File "src/lxml/parser.pxi", line 601, in lxml.etree._ParserContext._handleParseResultDoc
                    File "src/lxml/parser.pxi", line 711, in lxml.etree._handleParseResult
                    File "src/lxml/parser.pxi", line 640, in lxml.etree._raiseParseError
                    File "", line 1
                  lxml.etree.XMLSyntaxError: Opening and ending tag mismatch: HR line 1 and BODY, line 1, column 180
                  All phonebook entries are in the formats 004902211234567 or 02211234567.
                  The callermonitor seems to work as it shows incoming numbers but the recent calls and phonebook function are broken.
                  Anyone has any thoughts about that? Any kind of solution
                  Best,
                    rabbit83ka @randpop
                    Hi @randpop,
                    I’m running this plugin together with the fix by wunderbear and a Unitymedia-Fritzbox 6490 with FritzOS 7.02
                    fritz_access.py does also work an gives a reasonable output.
                    Regards
                    • L Offline
                      Laurids
                      Hi all,
                      this is my first post, so please be patient with me ;)
                      I´m trying to use MMM-FRITZ-Box-Callmonitor, but I have some problems, although I followed nearly every hint in this discussion.
                      • When someone is calling, I can see his number but not his name on the screen.
                      • The latest calls only were shown when I don´t config password and username. Why is that?
                      • when I test the connection with:
                      python fritz_access.py -p PASSWORD -u USER -i xxx.xxxx.xx.xx
                      I retrieve all the data from my Fritzbox, so the connection should not be the problem.
                      At least I tried the recommended fix of wunderbear, but after a reboot I only get a black screen (with the cursor top-left) after starting the MagicMirror. What is the reason and how can I solve these problems? I don´t want to start all other again :weary_face:
                      I hope, that someone can help me to fix my problems.
                      Thanks and regards
                      Laurids
                        Baschti @Laurids
                        @Laurids Did you solve the Problem? Same here!
                          requiemmg
                          I cannot get the module to work with my FB6590 Cable on FritzOS 7.19.
                          CallMonitor is switched on.
                          When I try to access it with python fritz_access-py -p PASS -u USER -i IP I get the following:
                          My “real” phonebook is a Google phonebook which is automatically imported by the FB, I do not use (and do not want to use) the internal phonebook.
                          Also, no recent calls are being shown.
                          {"content": "<?xml version=\"1.0\" encoding=\"UTF-8\"?> <phonebooks> <!-- id:0 , name: Telefonbuch --> <phonebook owner=\"0\" name=\"Telefonbuch\"> <timestamp>948668907</timestamp> <!-- number of contacts 12 --> <contact> <category>0</category> <person> <realName>Alle (Rundruf)</realName> </person> <uniqueid>11</uniqueid> <telephony> <services> </services> <!-- numbers:1--> <number type=\"intern\" vanity=\"\" prio=\"1\" >**9</number> <!-- idx:0 --> <!-- ringtoneidx:nil --> </telephony> </contact> <contact> <category>0</category> <person> <realName>Anrufbeantworter</realName> </person> <uniqueid>12</uniqueid> <telephony> <services> </services> <!-- numbers:2--> <number type=\"intern\" vanity=\"\" prio=\"1\" >**600</number> <number type=\"memo\" vanity=\"\" prio=\"\" >**605</number> <!-- idx:1 --> <!-- ringtoneidx:nil --> </telephony> </contact> <contact> <category>0</category> <person> <realName>AVM Ansage (HD)</realName> </person> <uniqueid>22</uniqueid> <telephony> <services> </services> <!-- numbers:1--> <number type=\"work\" quickdial=\"99\" vanity=\"\" prio=\"1\" >500@hd-telefonie.avm.de</number> <!-- idx:0 --> <!-- ringtoneidx:nil --> </telephony> </contact> <contact> <category>0</category> <person> <realName>B\u00fcro</realName> </person> <uniqueid>13</uniqueid> <telephony> <services> </services> <!-- numbers:1--> <number type=\"intern\" vanity=\"\" prio=\"1\" >**611</number> <!-- idx:2 --> <!-- ringtoneidx:nil --> </telephony> </contact> <contact> <category>0</category> <person> <realName>Fax</realName> </person> <uniqueid>14</uniqueid> <telephony> <services> </services> <!-- numbers:1--> <number type=\"intern\" vanity=\"\" prio=\"1\" >**2</number> <!-- idx:3 --> <!-- ringtoneidx:nil --> </telephony> </contact> <contact> <category>0</category> <person> <realName>FRITZ!App Fon (Samsung SM-G965F)</realName> </person> <uniqueid>27</uniqueid> <telephony> <services> </services> <!-- numbers:1--> <number type=\"intern\" vanity=\"\" prio=\"1\" >**620</number> <!-- idx:4 --> <!-- ringtoneidx:nil --> </telephony> </contact> <contact> <category>0</category> <person> <realName>ISDN/DECT Rundruf</realName> </person> <uniqueid>16</uniqueid> <telephony> <services> </services> <!-- numbers:1--> <number type=\"\" vanity=\"\" prio=\"1\" >**50</number> <!-- idx:5 --> <!-- ringtoneidx:nil --> </telephony> </contact> <contact> <category>0</category> <person> <realName>K\u00fcche</realName> </person> <uniqueid>17</uniqueid> <telephony> <services> </services> <!-- numbers:1--> <number type=\"intern\" vanity=\"\" prio=\"1\" >**610</number> <!-- idx:6 --> <!-- ringtoneidx:nil --> </telephony> </contact> <contact> <category>0</category> <person> <realName>Schlafen</realName> </person> <uniqueid>18</uniqueid> <telephony> <services> </services> <!-- numbers:1--> <number type=\"intern\" vanity=\"\" prio=\"1\" >**612</number> <!-- idx:7 --> <!-- ringtoneidx:nil --> </telephony> </contact> <contact> <category>0</category> <person> <realName>Wecker 1</realName> </person> <uniqueid>19</uniqueid> <telephony> <services> </services> <!-- numbers:1--> <number type=\"\" vanity=\"\" prio=\"1\" >**41</number> <!-- idx:8 --> <!-- ringtoneidx:nil --> </telephony> </contact> <contact> <category>0</category> <person> <realName>Wecker 2</realName> </person> <uniqueid>20</uniqueid> <telephony> <services> </services> <!-- numbers:1--> <number type=\"\" vanity=\"\" prio=\"1\" >**42</number> <!-- idx:9 --> <!-- ringtoneidx:nil --> </telephony> </contact> <contact> <category>0</category> <person> <realName>Wecker 3</realName> </person> <uniqueid>21</uniqueid> <telephony> <services> </services> <!-- numbers:1--> <number type=\"\" vanity=\"\" prio=\"1\" >**43</number> <!-- idx:10 --> <!-- ringtoneidx:nil --> </telephony> </contact> </phonebook></phonebooks> ", "filename": "data/pbook_0.xml"}
                            File "fritz_access.py", line 77, in <module>
                              main(args)
                            File "fritz_access.py", line 29, in download_phone_book
                              self.forward_file(result_phonebook["NewPhonebookURL"], filename)
                          KeyError: 'NewPhonebookURL'
                          Incoming calls are being displayed with the number on the screen, but are not shown in the recent calls list.
                          Edit: It works when I use a .vcf file, but I’d really like to use my builtin phonebook and also grab recent calls.
                            requiemmg
                            In case you haven’t noticed, @paviro is looking for a maintainer for this module.
                            https://github.com/paviro/MMM-FRITZ-Box-Callmonitor/issues/40
                            Would love to see this working!
                              requiemmg
                              So far, no maintainer.
                              Anyone else noticing that the module is not working with FRITZ!OS 7.20 anymore? (FB6590 Cable here, was working with the betas).
                                Sandy2503
                                @requiemmg
                                Today a made a fresh installation on my Pi4 with the latest Buster and MagicMirror 2.12
                                I installed the modules FRITZBox-Callmonitor & Current Call
                                in the root:
                                sudo apt-get install python-dev libxml2-dev libxslt1-dev zlib1g-dev && sudo pip install fritzconnection
                                and i fix the files from this Post -->
                                https://github.com/paviro/MMM-FRITZ-Box-Callmonitor/pull/35/commits/3f23f12d72d751567df67aebe33e1263be26bf81
                                and it works very well in combination with my Fritzbox 7590 running on 7.20
                                Best Regards
                                • G Offline
                                  Ghost2000 @Sandy2503
                                  @Sandy2503
                                  My screen is black after installing it.
                                  In the browser he shows me this error.
                                  Uncaught SyntaxError: Unexpected token / in JSON at position 79
                                  at JSON.parse ()
                                  at XMLHttpRequest.xhr.onreadystatechange (translator.js:22)
                                  (index):1 Unchecked runtime.lastError: The message port closed before a response was received.
                                    sdetweil @Ghost2000
                                    @Ghost2000 looking at it again that is the translation error I sent you
                                    https://github.com/paviro/MMM-FRITZ-Box-Callmonitor/blob/master/translations/de.json
                                    edit out the comment line, not allowed in json file
                                    • G Offline
                                      Ghost2000
                                      you are the best , i have it
                                      changed don´t work :(
                                        sdetweil @Ghost2000
                                        @Ghost2000 need more info than “don’t work”
                                        • G Offline
                                          Ghost2000
                                          1 verbose cli [ '/usr/bin/node', '/usr/bin/npm', 'start' ]
                                          2 info using npm@6.14.6
                                          3 info using node@v10.22.1
                                          5 info lifecycle magicmirror@2.13.0~prestart: magicmirror@2.13.0
                                          6 info lifecycle magicmirror@2.13.0~start: magicmirror@2.13.0
                                          7 verbose lifecycle magicmirror@2.13.0~start: unsafe-perm in lifecycle true
                                          8 verbose lifecycle magicmirror@2.13.0~start: PATH: /usr/lib/node_modules/npm/node_modules/npm-lifecycle/node-gyp-bin:/home/pi/MagicMirror/node_modules/.bin:/home/pi/.local/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bi$
                                          9 verbose lifecycle magicmirror@2.13.0~start: CWD: /home/pi/MagicMirror
                                          10 silly lifecycle magicmirror@2.13.0~start: Args: [ '-c',
                                          10 silly lifecycle   'DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js' ]
                                          11 silly lifecycle magicmirror@2.13.0~start: Returned: code: 1  signal: null
                                          12 info lifecycle magicmirror@2.13.0~start: Failed to exec start script
                                          13 verbose stack Error: magicmirror@2.13.0 start: `DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js`
                                          13 verbose stack Exit status 1
                                          13 verbose stack     at EventEmitter.<anonymous> (/usr/lib/node_modules/npm/node_modules/npm-lifecycle/index.js:332:16)
                                          13 verbose stack     at EventEmitter.emit (events.js:198:13)
                                          13 verbose stack     at ChildProcess.<anonymous> (/usr/lib/node_modules/npm/node_modules/npm-lifecycle/lib/spawn.js:55:14)
                                          13 verbose stack     at ChildProcess.emit (events.js:198:13)
                                          13 verbose stack     at maybeClose (internal/child_process.js:982:16)
                                          13 verbose stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:259:5)
                                          14 verbose pkgid magicmirror@2.13.0
                                          15 verbose cwd /home/pi/MagicMirror
                                          16 verbose Linux 5.4.51-v7l+
                                          17 verbose argv "/usr/bin/node" "/usr/bin/npm" "start"
                                          18 verbose node v10.22.1
                                          19 verbose npm  v6.14.6
                                          20 error code ELIFECYCLE
                                          21 error errno 1
                                          22 error magicmirror@2.13.0 start: `DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js`
                                          22 error Exit status 1
                                          23 error Failed at the magicmirror@2.13.0 start script.
                                          23 error This is probably not a problem with npm. There is likely additional logging output above.
                                          24 verbose exit [ 1, true ]
                                          Browser Log:
                                          (index):5 Uncaught SyntaxError: Unexpected token / in JSON at position 79
                                              at JSON.parse (<anonymous>)
                                          Dev Log
                                           npm start dev
                                          > magicmirror@2.13.0 start /home/pi/MagicMirror
                                          > DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js "dev"
                                          [2020-10-14 14:23:35.170] [LOG]    Starting MagicMirror: v2.13.0
                                          [2020-10-14 14:23:35.178] [LOG]    Loading config ...
                                          [2020-10-14 14:23:35.184] [LOG]    Loading module helpers ...
                                          [2020-10-14 14:23:35.187] [LOG]    No helper found for module: alert.
                                          [2020-10-14 14:23:35.231] [LOG]    Initializing new module helper ...
                                          [2020-10-14 14:23:35.232] [LOG]    Module helper loaded: updatenotification
                                          [2020-10-14 14:23:35.234] [LOG]    No helper found for module: MMM-Globe.
                                          [2020-10-14 14:23:35.235] [LOG]    No helper found for module: MMM-Carousel.
                                          [2020-10-14 14:23:35.236] [LOG]    No helper found for module: clock.
                                          [2020-10-14 14:23:35.422] [LOG]    Initializing new module helper ...
                                          [2020-10-14 14:23:35.422] [LOG]    Module helper loaded: MMM-FRITZ-Box-Callmonitor
                                          [2020-10-14 14:23:36.306] [LOG]    Initializing new module helper ...
                                          [2020-10-14 14:23:36.306] [LOG]    Module helper loaded: MMM-awesome-alexa
                                          [2020-10-14 14:23:36.307] [LOG]    No helper found for module: iFrame.
                                          [2020-10-14 14:23:36.664] [LOG]    Initializing new module helper ...
                                          [2020-10-14 14:23:36.665] [LOG]    Module helper loaded: MMM-NowPlayingOnSpotify
                                          [2020-10-14 14:23:37.016] [LOG]    Initializing new module helper ...
                                          [2020-10-14 14:23:37.017] [LOG]    Module helper loaded: calendar
                                          [2020-10-14 14:23:37.018] [LOG]    Initializing new module helper ...
                                          [2020-10-14 14:23:37.019] [LOG]    Module helper loaded: MMM-OnScreenMenu
                                          [2020-10-14 14:23:37.019] [LOG]    No helper found for module: compliments.
                                          [2020-10-14 14:23:37.158] [LOG]    Initializing new module helper ...
                                          [2020-10-14 14:23:37.159] [LOG]    Module helper loaded: internet-monitor
                                          [2020-10-14 14:23:37.440] [LOG]    Initializing new module helper ...
                                          [2020-10-14 14:23:37.441] [LOG]    Module helper loaded: MMM-DWD-WarnWeather
                                          [2020-10-14 14:23:37.442] [LOG]    No helper found for module: MMM-windy.
                                          [2020-10-14 14:23:37.442] [LOG]    No helper found for module: currentweather.
                                          [2020-10-14 14:23:37.571] [LOG]    Initializing new module helper ...
                                          [2020-10-14 14:23:37.571] [LOG]    Module helper loaded: MMM-Remote-Control
                                          [2020-10-14 14:23:37.572] [LOG]    No helper found for module: weatherforecast.
                                          [2020-10-14 14:23:37.573] [LOG]    Initializing new module helper ...
                                          [2020-10-14 14:23:37.574] [LOG]    Module helper loaded: MMM-SmartTouch
                                          [2020-10-14 14:23:37.594] [LOG]    Initializing new module helper ...
                                          [2020-10-14 14:23:37.594] [LOG]    Module helper loaded: newsfeed
                                          [2020-10-14 14:23:37.595] [LOG]    All module helpers loaded.
                                          [2020-10-14 14:23:37.692] [LOG]    Starting server on port 8080 ...
                                          [2020-10-14 14:23:37.694] [INFO]   You're using a full whitelist configuration to allow for all IPs
                                          [2020-10-14 14:23:37.700] [LOG]    Server started ...
                                          [2020-10-14 14:23:37.701] [LOG]    Connecting socket for: updatenotification
                                          [2020-10-14 14:23:37.702] [LOG]    Connecting socket for: MMM-FRITZ-Box-Callmonitor
                                          [2020-10-14 14:23:37.703] [LOG]    Starting module: MMM-FRITZ-Box-Callmonitor
                                          [2020-10-14 14:23:37.704] [LOG]    Connecting socket for: MMM-awesome-alexa
                                          [2020-10-14 14:23:37.705] [LOG]    Connecting socket for: MMM-NowPlayingOnSpotify
                                          [2020-10-14 14:23:37.706] [LOG]    Connecting socket for: calendar
                                          [2020-10-14 14:23:37.706] [LOG]    Starting node helper for: calendar
                                          [2020-10-14 14:23:37.707] [LOG]    Connecting socket for: MMM-OnScreenMenu
                                          [2020-10-14 14:23:37.708] [LOG]    Connecting socket for: internet-monitor
                                          [2020-10-14 14:23:37.709] [LOG]    internet-monitor helper started ...
                                          [2020-10-14 14:23:37.709] [LOG]    Connecting socket for: MMM-DWD-WarnWeather
                                          [2020-10-14 14:23:37.710] [LOG]    MMM-DWD-WarnWeather helper started...
                                          [2020-10-14 14:23:37.710] [LOG]    Connecting socket for: MMM-Remote-Control
                                          [2020-10-14 14:23:37.711] [LOG]    Starting node helper for: MMM-Remote-Control
                                          [2020-10-14 14:23:37.717] [LOG]    Connecting socket for: MMM-SmartTouch
                                          [2020-10-14 14:23:37.718] [LOG]    Connecting socket for: newsfeed
                                          [2020-10-14 14:23:37.718] [LOG]    Starting node helper for: newsfeed
                                          [2020-10-14 14:23:37.719] [LOG]    Sockets connected & modules started ...
                                          [2020-10-14 14:23:37.726] [ERROR]  Whoops! There was an uncaught exception...
                                          [2020-10-14 14:23:37.727] [ERROR]  Error: listen EADDRINUSE: address already in use 0.0.0.0:8080
                                              at Server.setupListenHandle [as _listen2] (net.js:1226:14)
                                              at listenInCluster (net.js:1274:12)
                                              at doListen (net.js:1413:7)
                                              at processTicksAndRejections (internal/process/task_queues.js:84:9) {
                                            code: 'EADDRINUSE',
                                            errno: 'EADDRINUSE',
                                            syscall: 'listen',
                                            address: '0.0.0.0',
                                            port: 8080
                                          [2020-10-14 14:23:37.732] [ERROR]  MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                                          [2020-10-14 14:23:37.733] [ERROR]  If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                                          [2020-10-14 14:23:37.808] [LOG]    Launching application.
                                            sdetweil @Ghost2000
                                            @Ghost2000 there are two files that need to be fixed. de and en.json
                                            you must remove the comment line.
                                            put the json file contents in one of the online validators to test your edit
                                            • 4 / 5
