    MMM-FRITZ-Box-Callmonitor
    99 Posts 27 Posters 126.2k Views 26 Watching
      darklight89
      Hi guys,
      how can I hide the call history, since the Fritz-Boxes Callmonitor seems to be deactivated in OS 7 and I want to keep at least the alert pop-up.
        randpop
        Re: MMM-FRITZ-Box-Callmonitor
        Hi all,
        i cannot get the module up and running.
        I’ve tried all the above solutions and nothing really worked.
        We got 2 FritzBoxes at work. One is our router (7590) and the other one (6490) is used as a cable modem and for the telephone connections.
        Callerid and TR-064 access are activated on the 6490 and it is running with OS 6.50. The user i created has access to the FritzBox and has all the necessary rights.
        I’ve tried a CallerMonitor App on macOS and it worked fine.
        This is my config:
                                module: 'MMM-FRITZ-Box-Callmonitor',
                                position: 'bottom_left',
                                header: "Anrufe",
                                password: "PASSWORD",
                                username: "USERNAME",
                                fritzIP: "130.180.xx.xx",
                                reloadContactsInterval: 1,
                                vCard: false
        When i test the connection with:
        python fritz_access.py -p PASSWORD -u USER -i 130.180.xx.xx
        i get this:
          File "fritz_access.py", line 77, in
            main(args)
          File "fritz_access.py", line 63, in main
            handle.download_phone_book()
          File "fritz_access.py", line 22, in download_phone_book
            result = self.fc.call_action("X_AVM-DE_OnTel", "GetPhonebookList")
          File "/usr/local/lib/python2.7/dist-packages/fritzconnection/fritzconnection.py", line 406, in call_action
            return action.execute(**kwargs)
          File "/usr/local/lib/python2.7/dist-packages/fritzconnection/fritzconnection.py", line 130, in execute
            result = self.parse_response(response.content)
          File "/usr/local/lib/python2.7/dist-packages/fritzconnection/fritzconnection.py", line 142, in parse_response
            root = etree.fromstring(response)
          File "src/lxml/etree.pyx", line 3222, in lxml.etree.fromstring
          File "src/lxml/parser.pxi", line 1877, in lxml.etree._parseMemoryDocument
          File "src/lxml/parser.pxi", line 1765, in lxml.etree._parseDoc
          File "src/lxml/parser.pxi", line 1127, in lxml.etree._BaseParser._parseDoc
          File "src/lxml/parser.pxi", line 601, in lxml.etree._ParserContext._handleParseResultDoc
          File "src/lxml/parser.pxi", line 711, in lxml.etree._handleParseResult
          File "src/lxml/parser.pxi", line 640, in lxml.etree._raiseParseError
          File "", line 1
        lxml.etree.XMLSyntaxError: Opening and ending tag mismatch: HR line 1 and BODY, line 1, column 180
        All phonebook entries are in the formats 004902211234567 or 02211234567.
        The callermonitor seems to work as it shows incoming numbers but the recent calls and phonebook function are broken.
        Anyone has any thoughts about that? Any kind of solution
        Best,
          rabbit83ka @randpop
          Hi @randpop,
          I’m running this plugin together with the fix by wunderbear and a Unitymedia-Fritzbox 6490 with FritzOS 7.02
          fritz_access.py does also work an gives a reasonable output.
          Regards
          • L Offline
            Laurids
            Hi all,
            this is my first post, so please be patient with me ;)
            I´m trying to use MMM-FRITZ-Box-Callmonitor, but I have some problems, although I followed nearly every hint in this discussion.
            • When someone is calling, I can see his number but not his name on the screen.
            • The latest calls only were shown when I don´t config password and username. Why is that?
            • when I test the connection with:
            python fritz_access.py -p PASSWORD -u USER -i xxx.xxxx.xx.xx
            I retrieve all the data from my Fritzbox, so the connection should not be the problem.
            At least I tried the recommended fix of wunderbear, but after a reboot I only get a black screen (with the cursor top-left) after starting the MagicMirror. What is the reason and how can I solve these problems? I don´t want to start all other again :weary_face:
            I hope, that someone can help me to fix my problems.
            Thanks and regards
            Laurids
              Baschti @Laurids
              @Laurids Did you solve the Problem? Same here!
                requiemmg
                I cannot get the module to work with my FB6590 Cable on FritzOS 7.19.
                CallMonitor is switched on.
                When I try to access it with python fritz_access-py -p PASS -u USER -i IP I get the following:
                My “real” phonebook is a Google phonebook which is automatically imported by the FB, I do not use (and do not want to use) the internal phonebook.
                Also, no recent calls are being shown.
                {"content": "<?xml version=\"1.0\" encoding=\"UTF-8\"?> <phonebooks> <!-- id:0 , name: Telefonbuch --> <phonebook owner=\"0\" name=\"Telefonbuch\"> <timestamp>948668907</timestamp> <!-- number of contacts 12 --> <contact> <category>0</category> <person> <realName>Alle (Rundruf)</realName> </person> <uniqueid>11</uniqueid> <telephony> <services> </services> <!-- numbers:1--> <number type=\"intern\" vanity=\"\" prio=\"1\" >**9</number> <!-- idx:0 --> <!-- ringtoneidx:nil --> </telephony> </contact> <contact> <category>0</category> <person> <realName>Anrufbeantworter</realName> </person> <uniqueid>12</uniqueid> <telephony> <services> </services> <!-- numbers:2--> <number type=\"intern\" vanity=\"\" prio=\"1\" >**600</number> <number type=\"memo\" vanity=\"\" prio=\"\" >**605</number> <!-- idx:1 --> <!-- ringtoneidx:nil --> </telephony> </contact> <contact> <category>0</category> <person> <realName>AVM Ansage (HD)</realName> </person> <uniqueid>22</uniqueid> <telephony> <services> </services> <!-- numbers:1--> <number type=\"work\" quickdial=\"99\" vanity=\"\" prio=\"1\" >500@hd-telefonie.avm.de</number> <!-- idx:0 --> <!-- ringtoneidx:nil --> </telephony> </contact> <contact> <category>0</category> <person> <realName>B\u00fcro</realName> </person> <uniqueid>13</uniqueid> <telephony> <services> </services> <!-- numbers:1--> <number type=\"intern\" vanity=\"\" prio=\"1\" >**611</number> <!-- idx:2 --> <!-- ringtoneidx:nil --> </telephony> </contact> <contact> <category>0</category> <person> <realName>Fax</realName> </person> <uniqueid>14</uniqueid> <telephony> <services> </services> <!-- numbers:1--> <number type=\"intern\" vanity=\"\" prio=\"1\" >**2</number> <!-- idx:3 --> <!-- ringtoneidx:nil --> </telephony> </contact> <contact> <category>0</category> <person> <realName>FRITZ!App Fon (Samsung SM-G965F)</realName> </person> <uniqueid>27</uniqueid> <telephony> <services> </services> <!-- numbers:1--> <number type=\"intern\" vanity=\"\" prio=\"1\" >**620</number> <!-- idx:4 --> <!-- ringtoneidx:nil --> </telephony> </contact> <contact> <category>0</category> <person> <realName>ISDN/DECT Rundruf</realName> </person> <uniqueid>16</uniqueid> <telephony> <services> </services> <!-- numbers:1--> <number type=\"\" vanity=\"\" prio=\"1\" >**50</number> <!-- idx:5 --> <!-- ringtoneidx:nil --> </telephony> </contact> <contact> <category>0</category> <person> <realName>K\u00fcche</realName> </person> <uniqueid>17</uniqueid> <telephony> <services> </services> <!-- numbers:1--> <number type=\"intern\" vanity=\"\" prio=\"1\" >**610</number> <!-- idx:6 --> <!-- ringtoneidx:nil --> </telephony> </contact> <contact> <category>0</category> <person> <realName>Schlafen</realName> </person> <uniqueid>18</uniqueid> <telephony> <services> </services> <!-- numbers:1--> <number type=\"intern\" vanity=\"\" prio=\"1\" >**612</number> <!-- idx:7 --> <!-- ringtoneidx:nil --> </telephony> </contact> <contact> <category>0</category> <person> <realName>Wecker 1</realName> </person> <uniqueid>19</uniqueid> <telephony> <services> </services> <!-- numbers:1--> <number type=\"\" vanity=\"\" prio=\"1\" >**41</number> <!-- idx:8 --> <!-- ringtoneidx:nil --> </telephony> </contact> <contact> <category>0</category> <person> <realName>Wecker 2</realName> </person> <uniqueid>20</uniqueid> <telephony> <services> </services> <!-- numbers:1--> <number type=\"\" vanity=\"\" prio=\"1\" >**42</number> <!-- idx:9 --> <!-- ringtoneidx:nil --> </telephony> </contact> <contact> <category>0</category> <person> <realName>Wecker 3</realName> </person> <uniqueid>21</uniqueid> <telephony> <services> </services> <!-- numbers:1--> <number type=\"\" vanity=\"\" prio=\"1\" >**43</number> <!-- idx:10 --> <!-- ringtoneidx:nil --> </telephony> </contact> </phonebook></phonebooks> ", "filename": "data/pbook_0.xml"}
                  File "fritz_access.py", line 77, in <module>
                    main(args)
                  File "fritz_access.py", line 29, in download_phone_book
                    self.forward_file(result_phonebook["NewPhonebookURL"], filename)
                KeyError: 'NewPhonebookURL'
                Incoming calls are being displayed with the number on the screen, but are not shown in the recent calls list.
                Edit: It works when I use a .vcf file, but I’d really like to use my builtin phonebook and also grab recent calls.
                  requiemmg
                  In case you haven’t noticed, @paviro is looking for a maintainer for this module.
                  https://github.com/paviro/MMM-FRITZ-Box-Callmonitor/issues/40
                  Would love to see this working!
                    requiemmg
                    So far, no maintainer.
                    Anyone else noticing that the module is not working with FRITZ!OS 7.20 anymore? (FB6590 Cable here, was working with the betas).
                    • Sandy2503S Offline
                      Sandy2503
                      @requiemmg
                      Today a made a fresh installation on my Pi4 with the latest Buster and MagicMirror 2.12
                      I installed the modules FRITZBox-Callmonitor & Current Call
                      in the root:
                      sudo apt-get install python-dev libxml2-dev libxslt1-dev zlib1g-dev && sudo pip install fritzconnection
                      and i fix the files from this Post -->
                      https://github.com/paviro/MMM-FRITZ-Box-Callmonitor/pull/35/commits/3f23f12d72d751567df67aebe33e1263be26bf81
                      and it works very well in combination with my Fritzbox 7590 running on 7.20
                      Best Regards
                      • G Offline
                        Ghost2000 @Sandy2503
                        @Sandy2503
                        My screen is black after installing it.
                        In the browser he shows me this error.
                        Uncaught SyntaxError: Unexpected token / in JSON at position 79
                        at JSON.parse ()
                        at XMLHttpRequest.xhr.onreadystatechange (translator.js:22)
                        (index):1 Unchecked runtime.lastError: The message port closed before a response was received.
                          sdetweil @Ghost2000
                          @Ghost2000 looking at it again that is the translation error I sent you
                          https://github.com/paviro/MMM-FRITZ-Box-Callmonitor/blob/master/translations/de.json
                          edit out the comment line, not allowed in json file
                          • G Offline
                            Ghost2000
                            you are the best , i have it
                            changed don´t work :(
                              sdetweil @Ghost2000
                              @Ghost2000 need more info than “don’t work”
                              • G Offline
                                Ghost2000
                                1 verbose cli [ '/usr/bin/node', '/usr/bin/npm', 'start' ]
                                2 info using npm@6.14.6
                                3 info using node@v10.22.1
                                5 info lifecycle magicmirror@2.13.0~prestart: magicmirror@2.13.0
                                6 info lifecycle magicmirror@2.13.0~start: magicmirror@2.13.0
                                7 verbose lifecycle magicmirror@2.13.0~start: unsafe-perm in lifecycle true
                                8 verbose lifecycle magicmirror@2.13.0~start: PATH: /usr/lib/node_modules/npm/node_modules/npm-lifecycle/node-gyp-bin:/home/pi/MagicMirror/node_modules/.bin:/home/pi/.local/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bi$
                                9 verbose lifecycle magicmirror@2.13.0~start: CWD: /home/pi/MagicMirror
                                10 silly lifecycle magicmirror@2.13.0~start: Args: [ '-c',
                                10 silly lifecycle   'DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js' ]
                                11 silly lifecycle magicmirror@2.13.0~start: Returned: code: 1  signal: null
                                12 info lifecycle magicmirror@2.13.0~start: Failed to exec start script
                                13 verbose stack Error: magicmirror@2.13.0 start: `DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js`
                                13 verbose stack Exit status 1
                                13 verbose stack     at EventEmitter.<anonymous> (/usr/lib/node_modules/npm/node_modules/npm-lifecycle/index.js:332:16)
                                13 verbose stack     at EventEmitter.emit (events.js:198:13)
                                13 verbose stack     at ChildProcess.<anonymous> (/usr/lib/node_modules/npm/node_modules/npm-lifecycle/lib/spawn.js:55:14)
                                13 verbose stack     at ChildProcess.emit (events.js:198:13)
                                13 verbose stack     at maybeClose (internal/child_process.js:982:16)
                                13 verbose stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:259:5)
                                14 verbose pkgid magicmirror@2.13.0
                                15 verbose cwd /home/pi/MagicMirror
                                16 verbose Linux 5.4.51-v7l+
                                17 verbose argv "/usr/bin/node" "/usr/bin/npm" "start"
                                18 verbose node v10.22.1
                                19 verbose npm  v6.14.6
                                20 error code ELIFECYCLE
                                21 error errno 1
                                22 error magicmirror@2.13.0 start: `DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js`
                                22 error Exit status 1
                                23 error Failed at the magicmirror@2.13.0 start script.
                                23 error This is probably not a problem with npm. There is likely additional logging output above.
                                24 verbose exit [ 1, true ]
                                Browser Log:
                                (index):5 Uncaught SyntaxError: Unexpected token / in JSON at position 79
                                    at JSON.parse (<anonymous>)
                                Dev Log
                                 npm start dev
                                > magicmirror@2.13.0 start /home/pi/MagicMirror
                                > DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js "dev"
                                [2020-10-14 14:23:35.170] [LOG]    Starting MagicMirror: v2.13.0
                                [2020-10-14 14:23:35.178] [LOG]    Loading config ...
                                [2020-10-14 14:23:35.184] [LOG]    Loading module helpers ...
                                [2020-10-14 14:23:35.187] [LOG]    No helper found for module: alert.
                                [2020-10-14 14:23:35.231] [LOG]    Initializing new module helper ...
                                [2020-10-14 14:23:35.232] [LOG]    Module helper loaded: updatenotification
                                [2020-10-14 14:23:35.234] [LOG]    No helper found for module: MMM-Globe.
                                [2020-10-14 14:23:35.235] [LOG]    No helper found for module: MMM-Carousel.
                                [2020-10-14 14:23:35.236] [LOG]    No helper found for module: clock.
                                [2020-10-14 14:23:35.422] [LOG]    Initializing new module helper ...
                                [2020-10-14 14:23:35.422] [LOG]    Module helper loaded: MMM-FRITZ-Box-Callmonitor
                                [2020-10-14 14:23:36.306] [LOG]    Initializing new module helper ...
                                [2020-10-14 14:23:36.306] [LOG]    Module helper loaded: MMM-awesome-alexa
                                [2020-10-14 14:23:36.307] [LOG]    No helper found for module: iFrame.
                                [2020-10-14 14:23:36.664] [LOG]    Initializing new module helper ...
                                [2020-10-14 14:23:36.665] [LOG]    Module helper loaded: MMM-NowPlayingOnSpotify
                                [2020-10-14 14:23:37.016] [LOG]    Initializing new module helper ...
                                [2020-10-14 14:23:37.017] [LOG]    Module helper loaded: calendar
                                [2020-10-14 14:23:37.018] [LOG]    Initializing new module helper ...
                                [2020-10-14 14:23:37.019] [LOG]    Module helper loaded: MMM-OnScreenMenu
                                [2020-10-14 14:23:37.019] [LOG]    No helper found for module: compliments.
                                [2020-10-14 14:23:37.158] [LOG]    Initializing new module helper ...
                                [2020-10-14 14:23:37.159] [LOG]    Module helper loaded: internet-monitor
                                [2020-10-14 14:23:37.440] [LOG]    Initializing new module helper ...
                                [2020-10-14 14:23:37.441] [LOG]    Module helper loaded: MMM-DWD-WarnWeather
                                [2020-10-14 14:23:37.442] [LOG]    No helper found for module: MMM-windy.
                                [2020-10-14 14:23:37.442] [LOG]    No helper found for module: currentweather.
                                [2020-10-14 14:23:37.571] [LOG]    Initializing new module helper ...
                                [2020-10-14 14:23:37.571] [LOG]    Module helper loaded: MMM-Remote-Control
                                [2020-10-14 14:23:37.572] [LOG]    No helper found for module: weatherforecast.
                                [2020-10-14 14:23:37.573] [LOG]    Initializing new module helper ...
                                [2020-10-14 14:23:37.574] [LOG]    Module helper loaded: MMM-SmartTouch
                                [2020-10-14 14:23:37.594] [LOG]    Initializing new module helper ...
                                [2020-10-14 14:23:37.594] [LOG]    Module helper loaded: newsfeed
                                [2020-10-14 14:23:37.595] [LOG]    All module helpers loaded.
                                [2020-10-14 14:23:37.692] [LOG]    Starting server on port 8080 ...
                                [2020-10-14 14:23:37.694] [INFO]   You're using a full whitelist configuration to allow for all IPs
                                [2020-10-14 14:23:37.700] [LOG]    Server started ...
                                [2020-10-14 14:23:37.701] [LOG]    Connecting socket for: updatenotification
                                [2020-10-14 14:23:37.702] [LOG]    Connecting socket for: MMM-FRITZ-Box-Callmonitor
                                [2020-10-14 14:23:37.703] [LOG]    Starting module: MMM-FRITZ-Box-Callmonitor
                                [2020-10-14 14:23:37.704] [LOG]    Connecting socket for: MMM-awesome-alexa
                                [2020-10-14 14:23:37.705] [LOG]    Connecting socket for: MMM-NowPlayingOnSpotify
                                [2020-10-14 14:23:37.706] [LOG]    Connecting socket for: calendar
                                [2020-10-14 14:23:37.706] [LOG]    Starting node helper for: calendar
                                [2020-10-14 14:23:37.707] [LOG]    Connecting socket for: MMM-OnScreenMenu
                                [2020-10-14 14:23:37.708] [LOG]    Connecting socket for: internet-monitor
                                [2020-10-14 14:23:37.709] [LOG]    internet-monitor helper started ...
                                [2020-10-14 14:23:37.709] [LOG]    Connecting socket for: MMM-DWD-WarnWeather
                                [2020-10-14 14:23:37.710] [LOG]    MMM-DWD-WarnWeather helper started...
                                [2020-10-14 14:23:37.710] [LOG]    Connecting socket for: MMM-Remote-Control
                                [2020-10-14 14:23:37.711] [LOG]    Starting node helper for: MMM-Remote-Control
                                [2020-10-14 14:23:37.717] [LOG]    Connecting socket for: MMM-SmartTouch
                                [2020-10-14 14:23:37.718] [LOG]    Connecting socket for: newsfeed
                                [2020-10-14 14:23:37.718] [LOG]    Starting node helper for: newsfeed
                                [2020-10-14 14:23:37.719] [LOG]    Sockets connected & modules started ...
                                [2020-10-14 14:23:37.726] [ERROR]  Whoops! There was an uncaught exception...
                                [2020-10-14 14:23:37.727] [ERROR]  Error: listen EADDRINUSE: address already in use 0.0.0.0:8080
                                    at Server.setupListenHandle [as _listen2] (net.js:1226:14)
                                    at listenInCluster (net.js:1274:12)
                                    at doListen (net.js:1413:7)
                                    at processTicksAndRejections (internal/process/task_queues.js:84:9) {
                                  code: 'EADDRINUSE',
                                  errno: 'EADDRINUSE',
                                  syscall: 'listen',
                                  address: '0.0.0.0',
                                  port: 8080
                                [2020-10-14 14:23:37.732] [ERROR]  MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                                [2020-10-14 14:23:37.733] [ERROR]  If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                                [2020-10-14 14:23:37.808] [LOG]    Launching application.
                                  sdetweil @Ghost2000
                                  @Ghost2000 there are two files that need to be fixed. de and en.json
                                  you must remove the comment line.
                                  put the json file contents in one of the online validators to test your edit
                                    sdetweil @Ghost2000
                                    @Ghost2000 if you use pm2 u have to stop that instance before using npm start
                                    pm2 stop all
                                    • G Offline
                                      Ghost2000
                                      Where can I find this file?
                                        sdetweil @Ghost2000
                                        @Ghost2000 come on. in the module folder, there is a folder called translations
                                        • G Offline
                                          Ghost2000
                                          Great thanksworks. @sdetweil
                                          De, json has to look like this for everyone
                                            "title": "Eingehender Anruf",
                                            "noCall": "Keine kürzlichen Anrufe.",
                                            "calllist_parse_error": "Anrufliste unlesbar.",
                                            "phonebook_parse_error": "Telefonbuch unlesbar.",
                                            "vcf_parse_error": "vCard unlesbar.",
                                            "login_error": "Logindaten falsch?",
                                            "network_error": "FRITZ!Box nicht erreichbar.",
                                            "unknown_error": "Unbekannter Fehler."
                                          en.json
                                            "title": "Incoming Call",
                                            "noCall": "No recent calls.",
                                            "calllist_parse_error": "Can't parse calllist.",
                                            "phonebook_parse_error": "Can't parse phonebook.",
                                            "vcf_parse_error": "Can't parse vCard.",
                                            "login_error": "Login data wrong?",
                                            "network_error": "Could not reach FRITZ!Box.",
                                            "unknown_error": "Unknown error."
                                            sdetweil @Ghost2000
                                            @Ghost2000 in 2.14 it will not fail like this, but the translation file will not be loaded. an error message in the dev window will indicate what file failed.
                                            fix also available in the develop branch
                                            this issue is pinned to the top of the troubleshooting section currently
                                            https://forum.magicmirror.builders/category/10/troubleshooting
                                            • 4 / 5
