    MMM-FRITZ-Box-Callmonitor
    99 Posts 27 Posters 132.6k Views 26 Watching
      2fingers @rf0620
      @rf0620 i have tried to install the module and i had unnbekannte fehler (unknown issue) error . i followd all the steps but i have another error now:
      pi@raspberrypi:~ $ sudo pip install fritzconnection --upgrade
      Requirement already up-to-date: fritzconnection in /usr/local/lib/python2.7/dist-packages
      Collecting requests>=2.2.0 (from fritzconnection)
      Downloading requests-2.18.4-py2.py3-none-any.whl (88kB)
      100% |████████████████████████████████| 92kB 763kB/s
      Collecting lxml>=3.2.5 (from fritzconnection)
      Using cached lxml-4.1.1.tar.gz
      Collecting urllib3=1.21.1 (from requests>=2.2.0->fritzconnection)
      Downloading urllib3-1.22-py2.py3-none-any.whl (132kB)
      100% |████████████████████████████████| 133kB 880kB/s
      Collecting idna=2.5 (from requests>=2.2.0->fritzconnection)
      Downloading idna-2.6-py2.py3-none-any.whl (56kB)
      100% |████████████████████████████████| 61kB 1.5MB/s
      Collecting chardet=3.0.2 (from requests>=2.2.0->fritzconnection)
      Downloading chardet-3.0.4-py2.py3-none-any.whl (133kB)
      100% |████████████████████████████████| 143kB 983kB/s
      Collecting certifi>=2017.4.17 (from requests>=2.2.0->fritzconnection)
      Downloading certifi-2017.11.5-py2.py3-none-any.whl (330kB)
      100% |████████████████████████████████| 337kB 629kB/s
      Building wheels for collected packages: lxml
      Running setup.py bdist_wheel for lxml … /^error
      Failed building wheel for lxml
      Running setup.py clean for lxml
      Failed to build lxml
      Installing collected packages: urllib3, idna, chardet, certifi, requests, lxml
      Found existing installation: urllib3 1.19.1
      Not uninstalling urllib3 at /usr/lib/python2.7/dist-packages, outside environment /usr
      Found existing installation: idna 2.2
      Not uninstalling idna at /usr/lib/python2.7/dist-packages, outside environment /usr
      Found existing installation: chardet 2.3.0
      Not uninstalling chardet at /usr/lib/python2.7/dist-packages, outside environment /usr
      Found existing installation: requests 2.12.4
      Not uninstalling requests at /usr/lib/python2.7/dist-packages, outside environment /usr
      Found existing installation: lxml 3.7.1
      Not uninstalling lxml at /usr/lib/python2.7/dist-packages, outside environment /usr
      Running setup.py install for lxml … |^canceled
      Can’t rollback lxml, nothing uninstalled.
      Operation cancelled by user
        Cyberdyne
        Please read this befor you update your Fritzbox with a new FritzOS!
        I upgraded my Fritzbox 6490 to the new FritzOS 7 and the callmonitor stoped working. I tried to but I could not reactivate the callmonitor. Nothing seemed to work and I thought I did something wrong. I contacted AVM to help and got a realy bad answer: They told me that AVM has removed the callmonitor functionality. I asked them how I could downgrade the OS to get the functionality back but they told me that there is no downgrade option. They also told me that they are going to remove the callmonitor functionality from all of their routers OSs.
        Warning to everyone: If you want to keep on using the callmonitor do not install FritzOS updates without checking if the new OS still supports the callmonitor. I would aks AVM befor updating.
        I am not sure if it helps but maybe everyone should write them an email and ask to keep or bring back this feature?!
        With this plugin I now can only see incomming calls (only the number) but no list with history of calls anymore. :o(
        • Sandy2503S
          Sandy2503
          @Cyberdyne - Hmmmm thats strange. I am using a 7590 with the actual AVM OS7.01 from 20th September (and early Beta Versions) and the Call Monitor and Current Call works (with the 7590 and 7490) very well …
          Sandy2503
            Cyberdyne
            I can only say what AVM has told me. Callmonitor is removed from the 6490 with the OS 7.0 and they also told me that they will remove it from all other boxes as well. They did not tell me in which version on which box. Hete are some emals:
            "Sie schildern, dass Sie den Callmonitor nicht mehr aktivieren können und möchten wissen, wieso dies der Fall ist. Ich bedauere diesen Umstand und nehme mich gerne der Sache an.
            Der Callmonitor wird mittlerweile nicht mehr von den FRITZ!Boxen unterstützt. Wenn Sie mit mitteilen, was genau Sie vorhaben, kann ich Ihnen ggf. Alternativen aufzeigen. "
            "Sie möchten wissen, bei welchen FRITZ!OS der Callmonitor noch unterstützt wird und wie Sie Ihre FRITZ!Box 6490 entsprechend downgraden können. Gerne beantworte ich Ihnen Ihre Frage.
            Ab welchen FRITZ!OS der Collmonitor nicht mehr unterstützt wurde, kann ich Ihnen nicht sagen, da dieser aufgrund der unterschiedlichen FRITZ!OS der verschiedenen FRITZ!Box-Modellen sukzessiv geschehen ist.
            Ein Downgrade von dem FRITZ!OS bei FRITZ!Box Cable ist leider nicht möglich."
            Just be carefull and better ask befor you make an other update if you want to keep on using the callmonitor! It does not work here anymore and no way back. :(
              darklight89
              Hi guys,
              how can I hide the call history, since the Fritz-Boxes Callmonitor seems to be deactivated in OS 7 and I want to keep at least the alert pop-up.
                randpop
                Re: MMM-FRITZ-Box-Callmonitor
                Hi all,
                i cannot get the module up and running.
                I’ve tried all the above solutions and nothing really worked.
                We got 2 FritzBoxes at work. One is our router (7590) and the other one (6490) is used as a cable modem and for the telephone connections.
                Callerid and TR-064 access are activated on the 6490 and it is running with OS 6.50. The user i created has access to the FritzBox and has all the necessary rights.
                I’ve tried a CallerMonitor App on macOS and it worked fine.
                This is my config:
                                        module: 'MMM-FRITZ-Box-Callmonitor',
                                        position: 'bottom_left',
                                        header: "Anrufe",
                                        password: "PASSWORD",
                                        username: "USERNAME",
                                        fritzIP: "130.180.xx.xx",
                                        reloadContactsInterval: 1,
                                        vCard: false
                When i test the connection with:
                python fritz_access.py -p PASSWORD -u USER -i 130.180.xx.xx
                i get this:
                  File "fritz_access.py", line 77, in
                    main(args)
                  File "fritz_access.py", line 63, in main
                    handle.download_phone_book()
                  File "fritz_access.py", line 22, in download_phone_book
                    result = self.fc.call_action("X_AVM-DE_OnTel", "GetPhonebookList")
                  File "/usr/local/lib/python2.7/dist-packages/fritzconnection/fritzconnection.py", line 406, in call_action
                    return action.execute(**kwargs)
                  File "/usr/local/lib/python2.7/dist-packages/fritzconnection/fritzconnection.py", line 130, in execute
                    result = self.parse_response(response.content)
                  File "/usr/local/lib/python2.7/dist-packages/fritzconnection/fritzconnection.py", line 142, in parse_response
                    root = etree.fromstring(response)
                  File "src/lxml/etree.pyx", line 3222, in lxml.etree.fromstring
                  File "src/lxml/parser.pxi", line 1877, in lxml.etree._parseMemoryDocument
                  File "src/lxml/parser.pxi", line 1765, in lxml.etree._parseDoc
                  File "src/lxml/parser.pxi", line 1127, in lxml.etree._BaseParser._parseDoc
                  File "src/lxml/parser.pxi", line 601, in lxml.etree._ParserContext._handleParseResultDoc
                  File "src/lxml/parser.pxi", line 711, in lxml.etree._handleParseResult
                  File "src/lxml/parser.pxi", line 640, in lxml.etree._raiseParseError
                  File "", line 1
                lxml.etree.XMLSyntaxError: Opening and ending tag mismatch: HR line 1 and BODY, line 1, column 180
                All phonebook entries are in the formats 004902211234567 or 02211234567.
                The callermonitor seems to work as it shows incoming numbers but the recent calls and phonebook function are broken.
                Anyone has any thoughts about that? Any kind of solution
                Best,
                R 1 Reply Last reply
                  rabbit83ka @randpop
                  Hi @randpop,
                  I’m running this plugin together with the fix by wunderbear and a Unitymedia-Fritzbox 6490 with FritzOS 7.02
                  fritz_access.py does also work an gives a reasonable output.
                  Regards
                  • L
                    Laurids
                    Hi all,
                    this is my first post, so please be patient with me ;)
                    I´m trying to use MMM-FRITZ-Box-Callmonitor, but I have some problems, although I followed nearly every hint in this discussion.
                    • When someone is calling, I can see his number but not his name on the screen.
                    • The latest calls only were shown when I don´t config password and username. Why is that?
                    • when I test the connection with:
                    python fritz_access.py -p PASSWORD -u USER -i xxx.xxxx.xx.xx
                    I retrieve all the data from my Fritzbox, so the connection should not be the problem.
                    At least I tried the recommended fix of wunderbear, but after a reboot I only get a black screen (with the cursor top-left) after starting the MagicMirror. What is the reason and how can I solve these problems? I don´t want to start all other again :weary_face:
                    I hope, that someone can help me to fix my problems.
                    Thanks and regards
                    Laurids
                    B 1 Reply Last reply
                      Baschti @Laurids
                      @Laurids Did you solve the Problem? Same here!
                        requiemmg
                        I cannot get the module to work with my FB6590 Cable on FritzOS 7.19.
                        CallMonitor is switched on.
                        When I try to access it with python fritz_access-py -p PASS -u USER -i IP I get the following:
                        My “real” phonebook is a Google phonebook which is automatically imported by the FB, I do not use (and do not want to use) the internal phonebook.
                        Also, no recent calls are being shown.
                        {"content": "<?xml version=\"1.0\" encoding=\"UTF-8\"?> <phonebooks> <!-- id:0 , name: Telefonbuch --> <phonebook owner=\"0\" name=\"Telefonbuch\"> <timestamp>948668907</timestamp> <!-- number of contacts 12 --> <contact> <category>0</category> <person> <realName>Alle (Rundruf)</realName> </person> <uniqueid>11</uniqueid> <telephony> <services> </services> <!-- numbers:1--> <number type=\"intern\" vanity=\"\" prio=\"1\" >**9</number> <!-- idx:0 --> <!-- ringtoneidx:nil --> </telephony> </contact> <contact> <category>0</category> <person> <realName>Anrufbeantworter</realName> </person> <uniqueid>12</uniqueid> <telephony> <services> </services> <!-- numbers:2--> <number type=\"intern\" vanity=\"\" prio=\"1\" >**600</number> <number type=\"memo\" vanity=\"\" prio=\"\" >**605</number> <!-- idx:1 --> <!-- ringtoneidx:nil --> </telephony> </contact> <contact> <category>0</category> <person> <realName>AVM Ansage (HD)</realName> </person> <uniqueid>22</uniqueid> <telephony> <services> </services> <!-- numbers:1--> <number type=\"work\" quickdial=\"99\" vanity=\"\" prio=\"1\" >500@hd-telefonie.avm.de</number> <!-- idx:0 --> <!-- ringtoneidx:nil --> </telephony> </contact> <contact> <category>0</category> <person> <realName>B\u00fcro</realName> </person> <uniqueid>13</uniqueid> <telephony> <services> </services> <!-- numbers:1--> <number type=\"intern\" vanity=\"\" prio=\"1\" >**611</number> <!-- idx:2 --> <!-- ringtoneidx:nil --> </telephony> </contact> <contact> <category>0</category> <person> <realName>Fax</realName> </person> <uniqueid>14</uniqueid> <telephony> <services> </services> <!-- numbers:1--> <number type=\"intern\" vanity=\"\" prio=\"1\" >**2</number> <!-- idx:3 --> <!-- ringtoneidx:nil --> </telephony> </contact> <contact> <category>0</category> <person> <realName>FRITZ!App Fon (Samsung SM-G965F)</realName> </person> <uniqueid>27</uniqueid> <telephony> <services> </services> <!-- numbers:1--> <number type=\"intern\" vanity=\"\" prio=\"1\" >**620</number> <!-- idx:4 --> <!-- ringtoneidx:nil --> </telephony> </contact> <contact> <category>0</category> <person> <realName>ISDN/DECT Rundruf</realName> </person> <uniqueid>16</uniqueid> <telephony> <services> </services> <!-- numbers:1--> <number type=\"\" vanity=\"\" prio=\"1\" >**50</number> <!-- idx:5 --> <!-- ringtoneidx:nil --> </telephony> </contact> <contact> <category>0</category> <person> <realName>K\u00fcche</realName> </person> <uniqueid>17</uniqueid> <telephony> <services> </services> <!-- numbers:1--> <number type=\"intern\" vanity=\"\" prio=\"1\" >**610</number> <!-- idx:6 --> <!-- ringtoneidx:nil --> </telephony> </contact> <contact> <category>0</category> <person> <realName>Schlafen</realName> </person> <uniqueid>18</uniqueid> <telephony> <services> </services> <!-- numbers:1--> <number type=\"intern\" vanity=\"\" prio=\"1\" >**612</number> <!-- idx:7 --> <!-- ringtoneidx:nil --> </telephony> </contact> <contact> <category>0</category> <person> <realName>Wecker 1</realName> </person> <uniqueid>19</uniqueid> <telephony> <services> </services> <!-- numbers:1--> <number type=\"\" vanity=\"\" prio=\"1\" >**41</number> <!-- idx:8 --> <!-- ringtoneidx:nil --> </telephony> </contact> <contact> <category>0</category> <person> <realName>Wecker 2</realName> </person> <uniqueid>20</uniqueid> <telephony> <services> </services> <!-- numbers:1--> <number type=\"\" vanity=\"\" prio=\"1\" >**42</number> <!-- idx:9 --> <!-- ringtoneidx:nil --> </telephony> </contact> <contact> <category>0</category> <person> <realName>Wecker 3</realName> </person> <uniqueid>21</uniqueid> <telephony> <services> </services> <!-- numbers:1--> <number type=\"\" vanity=\"\" prio=\"1\" >**43</number> <!-- idx:10 --> <!-- ringtoneidx:nil --> </telephony> </contact> </phonebook></phonebooks> ", "filename": "data/pbook_0.xml"}
                          File "fritz_access.py", line 77, in <module>
                            main(args)
                          File "fritz_access.py", line 29, in download_phone_book
                            self.forward_file(result_phonebook["NewPhonebookURL"], filename)
                        KeyError: 'NewPhonebookURL'
                        Incoming calls are being displayed with the number on the screen, but are not shown in the recent calls list.
                        Edit: It works when I use a .vcf file, but I’d really like to use my builtin phonebook and also grab recent calls.
                          requiemmg
                          In case you haven’t noticed, @paviro is looking for a maintainer for this module.
                          https://github.com/paviro/MMM-FRITZ-Box-Callmonitor/issues/40
                          Would love to see this working!
                            requiemmg
                            So far, no maintainer.
                            Anyone else noticing that the module is not working with FRITZ!OS 7.20 anymore? (FB6590 Cable here, was working with the betas).
                            • Sandy2503S
                              Sandy2503
                              @requiemmg
                              Today a made a fresh installation on my Pi4 with the latest Buster and MagicMirror 2.12
                              I installed the modules FRITZBox-Callmonitor & Current Call
                              in the root:
                              sudo apt-get install python-dev libxml2-dev libxslt1-dev zlib1g-dev && sudo pip install fritzconnection
                              and i fix the files from this Post -->
                              https://github.com/paviro/MMM-FRITZ-Box-Callmonitor/pull/35/commits/3f23f12d72d751567df67aebe33e1263be26bf81
                              and it works very well in combination with my Fritzbox 7590 running on 7.20
                              Best Regards
                              G 1 Reply Last reply
                              • G
                                Ghost2000 @Sandy2503
                                @Sandy2503
                                My screen is black after installing it.
                                In the browser he shows me this error.
                                Uncaught SyntaxError: Unexpected token / in JSON at position 79
                                at JSON.parse ()
                                at XMLHttpRequest.xhr.onreadystatechange (translator.js:22)
                                (index):1 Unchecked runtime.lastError: The message port closed before a response was received.
                                  sdetweil @Ghost2000
                                  @Ghost2000 looking at it again that is the translation error I sent you
                                  https://github.com/paviro/MMM-FRITZ-Box-Callmonitor/blob/master/translations/de.json
                                  edit out the comment line, not allowed in json file
                                  • G
                                    Ghost2000
                                    you are the best , i have it
                                    changed don´t work :(
                                      sdetweil @Ghost2000
                                      @Ghost2000 need more info than “don’t work”
                                      • G
                                        Ghost2000
                                        1 verbose cli [ '/usr/bin/node', '/usr/bin/npm', 'start' ]
                                        2 info using npm@6.14.6
                                        3 info using node@v10.22.1
                                        5 info lifecycle magicmirror@2.13.0~prestart: magicmirror@2.13.0
                                        6 info lifecycle magicmirror@2.13.0~start: magicmirror@2.13.0
                                        7 verbose lifecycle magicmirror@2.13.0~start: unsafe-perm in lifecycle true
                                        8 verbose lifecycle magicmirror@2.13.0~start: PATH: /usr/lib/node_modules/npm/node_modules/npm-lifecycle/node-gyp-bin:/home/pi/MagicMirror/node_modules/.bin:/home/pi/.local/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bi$
                                        9 verbose lifecycle magicmirror@2.13.0~start: CWD: /home/pi/MagicMirror
                                        10 silly lifecycle magicmirror@2.13.0~start: Args: [ '-c',
                                        10 silly lifecycle   'DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js' ]
                                        11 silly lifecycle magicmirror@2.13.0~start: Returned: code: 1  signal: null
                                        12 info lifecycle magicmirror@2.13.0~start: Failed to exec start script
                                        13 verbose stack Error: magicmirror@2.13.0 start: `DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js`
                                        13 verbose stack Exit status 1
                                        13 verbose stack     at EventEmitter.<anonymous> (/usr/lib/node_modules/npm/node_modules/npm-lifecycle/index.js:332:16)
                                        13 verbose stack     at EventEmitter.emit (events.js:198:13)
                                        13 verbose stack     at ChildProcess.<anonymous> (/usr/lib/node_modules/npm/node_modules/npm-lifecycle/lib/spawn.js:55:14)
                                        13 verbose stack     at ChildProcess.emit (events.js:198:13)
                                        13 verbose stack     at maybeClose (internal/child_process.js:982:16)
                                        13 verbose stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:259:5)
                                        14 verbose pkgid magicmirror@2.13.0
                                        15 verbose cwd /home/pi/MagicMirror
                                        16 verbose Linux 5.4.51-v7l+
                                        17 verbose argv "/usr/bin/node" "/usr/bin/npm" "start"
                                        18 verbose node v10.22.1
                                        19 verbose npm  v6.14.6
                                        20 error code ELIFECYCLE
                                        21 error errno 1
                                        22 error magicmirror@2.13.0 start: `DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js`
                                        22 error Exit status 1
                                        23 error Failed at the magicmirror@2.13.0 start script.
                                        23 error This is probably not a problem with npm. There is likely additional logging output above.
                                        24 verbose exit [ 1, true ]
                                        Browser Log:
                                        (index):5 Uncaught SyntaxError: Unexpected token / in JSON at position 79
                                            at JSON.parse (<anonymous>)
                                        Dev Log
                                         npm start dev
                                        > magicmirror@2.13.0 start /home/pi/MagicMirror
                                        > DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js "dev"
                                        [2020-10-14 14:23:35.170] [LOG]    Starting MagicMirror: v2.13.0
                                        [2020-10-14 14:23:35.178] [LOG]    Loading config ...
                                        [2020-10-14 14:23:35.184] [LOG]    Loading module helpers ...
                                        [2020-10-14 14:23:35.187] [LOG]    No helper found for module: alert.
                                        [2020-10-14 14:23:35.231] [LOG]    Initializing new module helper ...
                                        [2020-10-14 14:23:35.232] [LOG]    Module helper loaded: updatenotification
                                        [2020-10-14 14:23:35.234] [LOG]    No helper found for module: MMM-Globe.
                                        [2020-10-14 14:23:35.235] [LOG]    No helper found for module: MMM-Carousel.
                                        [2020-10-14 14:23:35.236] [LOG]    No helper found for module: clock.
                                        [2020-10-14 14:23:35.422] [LOG]    Initializing new module helper ...
                                        [2020-10-14 14:23:35.422] [LOG]    Module helper loaded: MMM-FRITZ-Box-Callmonitor
                                        [2020-10-14 14:23:36.306] [LOG]    Initializing new module helper ...
                                        [2020-10-14 14:23:36.306] [LOG]    Module helper loaded: MMM-awesome-alexa
                                        [2020-10-14 14:23:36.307] [LOG]    No helper found for module: iFrame.
                                        [2020-10-14 14:23:36.664] [LOG]    Initializing new module helper ...
                                        [2020-10-14 14:23:36.665] [LOG]    Module helper loaded: MMM-NowPlayingOnSpotify
                                        [2020-10-14 14:23:37.016] [LOG]    Initializing new module helper ...
                                        [2020-10-14 14:23:37.017] [LOG]    Module helper loaded: calendar
                                        [2020-10-14 14:23:37.018] [LOG]    Initializing new module helper ...
                                        [2020-10-14 14:23:37.019] [LOG]    Module helper loaded: MMM-OnScreenMenu
                                        [2020-10-14 14:23:37.019] [LOG]    No helper found for module: compliments.
                                        [2020-10-14 14:23:37.158] [LOG]    Initializing new module helper ...
                                        [2020-10-14 14:23:37.159] [LOG]    Module helper loaded: internet-monitor
                                        [2020-10-14 14:23:37.440] [LOG]    Initializing new module helper ...
                                        [2020-10-14 14:23:37.441] [LOG]    Module helper loaded: MMM-DWD-WarnWeather
                                        [2020-10-14 14:23:37.442] [LOG]    No helper found for module: MMM-windy.
                                        [2020-10-14 14:23:37.442] [LOG]    No helper found for module: currentweather.
                                        [2020-10-14 14:23:37.571] [LOG]    Initializing new module helper ...
                                        [2020-10-14 14:23:37.571] [LOG]    Module helper loaded: MMM-Remote-Control
                                        [2020-10-14 14:23:37.572] [LOG]    No helper found for module: weatherforecast.
                                        [2020-10-14 14:23:37.573] [LOG]    Initializing new module helper ...
                                        [2020-10-14 14:23:37.574] [LOG]    Module helper loaded: MMM-SmartTouch
                                        [2020-10-14 14:23:37.594] [LOG]    Initializing new module helper ...
                                        [2020-10-14 14:23:37.594] [LOG]    Module helper loaded: newsfeed
                                        [2020-10-14 14:23:37.595] [LOG]    All module helpers loaded.
                                        [2020-10-14 14:23:37.692] [LOG]    Starting server on port 8080 ...
                                        [2020-10-14 14:23:37.694] [INFO]   You're using a full whitelist configuration to allow for all IPs
                                        [2020-10-14 14:23:37.700] [LOG]    Server started ...
                                        [2020-10-14 14:23:37.701] [LOG]    Connecting socket for: updatenotification
                                        [2020-10-14 14:23:37.702] [LOG]    Connecting socket for: MMM-FRITZ-Box-Callmonitor
                                        [2020-10-14 14:23:37.703] [LOG]    Starting module: MMM-FRITZ-Box-Callmonitor
                                        [2020-10-14 14:23:37.704] [LOG]    Connecting socket for: MMM-awesome-alexa
                                        [2020-10-14 14:23:37.705] [LOG]    Connecting socket for: MMM-NowPlayingOnSpotify
                                        [2020-10-14 14:23:37.706] [LOG]    Connecting socket for: calendar
                                        [2020-10-14 14:23:37.706] [LOG]    Starting node helper for: calendar
                                        [2020-10-14 14:23:37.707] [LOG]    Connecting socket for: MMM-OnScreenMenu
                                        [2020-10-14 14:23:37.708] [LOG]    Connecting socket for: internet-monitor
                                        [2020-10-14 14:23:37.709] [LOG]    internet-monitor helper started ...
                                        [2020-10-14 14:23:37.709] [LOG]    Connecting socket for: MMM-DWD-WarnWeather
                                        [2020-10-14 14:23:37.710] [LOG]    MMM-DWD-WarnWeather helper started...
                                        [2020-10-14 14:23:37.710] [LOG]    Connecting socket for: MMM-Remote-Control
                                        [2020-10-14 14:23:37.711] [LOG]    Starting node helper for: MMM-Remote-Control
                                        [2020-10-14 14:23:37.717] [LOG]    Connecting socket for: MMM-SmartTouch
                                        [2020-10-14 14:23:37.718] [LOG]    Connecting socket for: newsfeed
                                        [2020-10-14 14:23:37.718] [LOG]    Starting node helper for: newsfeed
                                        [2020-10-14 14:23:37.719] [LOG]    Sockets connected & modules started ...
                                        [2020-10-14 14:23:37.726] [ERROR]  Whoops! There was an uncaught exception...
                                        [2020-10-14 14:23:37.727] [ERROR]  Error: listen EADDRINUSE: address already in use 0.0.0.0:8080
                                            at Server.setupListenHandle [as _listen2] (net.js:1226:14)
                                            at listenInCluster (net.js:1274:12)
                                            at doListen (net.js:1413:7)
                                            at processTicksAndRejections (internal/process/task_queues.js:84:9) {
                                          code: 'EADDRINUSE',
                                          errno: 'EADDRINUSE',
                                          syscall: 'listen',
                                          address: '0.0.0.0',
                                          port: 8080
                                        [2020-10-14 14:23:37.732] [ERROR]  MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                                        [2020-10-14 14:23:37.733] [ERROR]  If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                                        [2020-10-14 14:23:37.808] [LOG]    Launching application.
                                        S 2 Replies Last reply
                                          sdetweil @Ghost2000
                                          @Ghost2000 there are two files that need to be fixed. de and en.json
                                          you must remove the comment line.
                                          put the json file contents in one of the online validators to test your edit
                                            sdetweil @Ghost2000
                                            @Ghost2000 if you use pm2 u have to stop that instance before using npm start
                                            pm2 stop all
                                            • 4 / 5
