    Is node_helper really required?
    4 Posts 2 Posters 2.5k Views 2 Watching
    • E Offline
      E3V3A
      I see a lot of people putting: const NodeHelper = require("node_helper"); in their node_helper.js file. Is this right or even necessary?
      It doesn’t make much sense to state that a file require itself! And if it is referring to MM’s internal node_helper, then shouldn’t the MM core be made to recognize this by itself?
      I’m asking, because doing that, make your npm-check always complain about node_helper not being installed or missing.
      "Everything I do (here) is for free – altruism is the way!"
      MMM-FlightsAbove, MMM-Tabulator, MMM-Assistant (co-maintainer)
      • E Offline
        E3V3A
        It is not, and should not, AFAICT.
        • strawberry 3.141S Offline
          strawberry 3.141 Project Sponsor Module Developer @E3V3A
          @E3V3A that is not true.
          A node helper is not required for a module, but if a module has a nodehelper this statement required, because it imports this file into your node helper https://github.com/MichMich/MagicMirror/blob/master/modules/node_modules/node_helper/index.js
          E 1 Reply Last reply Reply Quote 1
          • E Offline
            E3V3A @strawberry 3.141
            @strawberry-3.141 Oh!? That is funny, because I removed it, and there is no change in anything, module ran fine without it. Perhaps because I’m not using most of the content from that file, while the rest is already defined?
