    MMM-ImageSlideshow need help adding an interesting feature
    imageslideshowmykle1newfeatureconfig.js
    4 Posts 2 Posters 2.5k Views 1 Watching
    • cjkj_06C
      cjkj_06
      Greetings !
      Very useful module by @MYKLE1
      It puts images on the mirror based on the path given
      Basically it works fine for me !!
      I want to add following feature
      -> Based on my calendar event, the module should choose which path to grab images from
      e.g. If my today’s event is “Jack’s birthday”, then it should pick images from the path: module/imageslideshow/Jack_Birthday
      in other cases, the module should pick images from designated default area
      Isn’t that interesting ? :)
      I am currently trying to edit top config.js file with something like this
      Obviously it is incorrect, but still putting it out
      if (calendar.event == "Holi") {
      	var imagePath  = "modules/MMM-ImageSlideshow/Holi";
      } else {
      	var imagePath = "modules/MMM-ImageSlideshow/exampleImages",
      Which is the variable of “calendar” module, which gets me the event name, and how to use that var on config.js file ?
      PS: I dont know javascript , but i know C, python etc
      Appreciate any help
      Chirantan
      • cowboysdudeC
        cowboysdude Module Developer
        Uh @Mykle1 didn’t write that one LOL
        But at any rate you could also do a switch statement like this:
        var text;
        var fruits = document.getElementById("myInput").value;
        switch(fruits) {
          case "Banana":
              text = "Banana is good!";
              break;
          case "Orange":
              text = "I am not a fan of orange.";
              break;
          case "Apple":
              text = "How you like them apples?";
              break;
          default:
              text = "I have never heard of that fruit...";
        cjkj_06C 1 Reply Last reply Reply Quote 0
        • cjkj_06C
          cjkj_06 @cowboysdude
          @cowboysdude
          True that, Thank you very much for replying
          Either if or switch, which variable from the default calendar module gives me the event name in text format ?
          and can I use that variable at config.js level ?
          Appreciate your time
          Chirantan
          • cowboysdudeC
            cowboysdude Module Developer @cjkj_06
            @cjkj_06 I’m not really sure. I have never used that module so I don’t know anything about it :)
            I would look inside it and replace txt with perhaps your dir for images… just a thought.
