Display Help
Ah, well, I don’t use either of those modules but plenty of people do. You can do a search on the forum and/or post a new question and I’m sure you’ll get some help.
Glad you solved the display issue
@Mykle1 yeahe im still digging around for the alexa issue and did post in a thread about the sensor. so far everything else is running great with no issues. i do have one question though. does it matter where in the string of module code you add certain modules. like would they cause the entire mirror to not load if there is a problem with a module in the middle of the them or does it not matter?
It can matter. If a troublesome module loads early it can cause problems with the modules that load later in the sequence
@Mykle1 ok thats what i was wonder, if it would be best to add new modules at the end of the pre loaded modules in the config or not
Well, as long as you add one at a time you will always know which is causing the problem. Correct that problem before adding another
