    Not sure what doing wrong :( adding modules
    modulesaddinghelp
    6 Posts 4 Posters 3.0k Views 3 Watching
      jamietd
      HI,
      ALways having trouble adding modules and not sure how to add the config items?> as soon as i seem to do anything i get error no config file
      for instance this is my current one that worked until i added uptime robot and now doesn’t… tried adding a few modules but most of the time end up removing them
      here is my config file if anybody can see whats up?
      thanks in advance :
      language: "en",
      	timeFormat: 24,
      	units: "metric",
      			module: "alert",
      			module: "updatenotification",
      			position: "top_bar"
      			module: 'uptimerobot',
      			position: 'top_right',
      			useColors: true
      			api_key:'u505342-b40737465f0eada9bb8a',
      			module: "clock",
      			position: "top_left"
      			module: 'MMM-Globe',
      			position: 'lower_third',
      			style: 'geoColor',
      			imageSize: 400,
      			ownImagePath:'',
      			updateInterval: 10*60*1000
      			header: "UK Holidays",
      						symbol: "calendar-check-o ",
      						url: "webcal://www.calendarlabs.com/ical-calendar/ics/75/UK_Holidays.ics"
      			module: "compliments",
      			position: "lower_third"
      			module: "currentweather",
      				locationID: "2514169",  //ID from http://www.openweathermap.org/help/city_list.txt
      				appid: "825910983bae6910153f11c5"
      			module: "weatherforecast",
      			header: "Weather Forecast",
      				appid: "825910983bae6979766611c5"
      			module: "newsfeed",
      			position: "bottom_bar",
      				feeds: [
      						title: "BBC UK",
      						url: "http://feeds.bbci.co.uk/news/video_and_audio/news_front_page/rss.xml?edition=uk"
      				showSourceTitle: true,
      				showPublishDate: true
      		    module: 'MMM-Hue',
      		    config:{
                      bridgeip: "192.168.1.4",
      		        userid: "V1mkM0KAT2qi2Z0LUIET-UFp47GZpxJyJB1R58j0",
                      colour: true
        You had a bunch of syntax problems. Missing } , and ;
        You can compare yours to this if you like, but this should work for you.
        var config = {
        	port: 8080,
        language: "en",
        	timeFormat: 24,
        	units: "metric",
        			module: "alert",
        			position: "top_bar"
        			useColors: true
        			module: "clock",
        			style: 'geoColor',
        			imageSize: 400,
        			ownImagePath:'',
        			module: "newsfeed",
        				feeds: [
        						title: "BBC UK",
        		    module: 'MMM-Hue',
        		    config:{
                        colour: true
        For future reference, this should help you add modules.
        https://forum.magicmirror.builders/topic/4231/how-to-add-modules-for-absolute-beginners
        • P Offline
          pinsdorf Module Developer
          One syntax error I spot is in uptimeroot module. The curly bracket of config: is not matched. @Mykle1 writes there is even more which I don’t spot immediately.
            	useColors: true
          In such cases it is good to do a syntax check of the config. Please run npm check:config to do so. You’ll get a detailed statement of what is wrong where syntactically. The reference @Mykle1 gives above is a must read. It shows an example of what the syntax check provides you.
          If a syntax check does not solve the issue, I’d comment out all modules but one and start the mirror. Use /* commented out module */ to make multi-line comments. If start-up works, you add the next module and restart. Repeat this until start-up fails which means you’ve found a(!) module that causes the issue. Please note that there might be more than one wrong module.
          If you have the module, copy the desired config elsewhere and redo the module’s configuration with the simplest possible config, which you often find in the ReadMe file of the same module.
          Good hunt.
          cruunnerrC 1 Reply Last reply Reply Quote 1
          • cruunnerrC Offline
            cruunnerr @pinsdorf
            @pinsdorf said in Not sure what doing wrong :( adding modules:
            module: ‘uptimerobot’,
            position: ‘top_right’,
            useColors: true
            api_key:‘u505342-b40737465f0eada9bb8a’,
            Missing comma behind the “true”.
            Must look like this:
            		useColors: true,
            Just a copy/paste failure from Mykle ;)
              Mykle1 Project Sponsor Module Developer @cruunnerr
              @cruunnerr said in Not sure what doing wrong :( adding modules:
              Nope, I missed that one. Nice catch! :-)
                jamietd
                Wow what a great forum!!
                thanks for the help… really is appreciated :)
                Will try now
