    Default Calender-absolute Date
    14 Posts 11 Posters 11.9k Views 10 Watching
      SimJim
      i got a Problem with the default calender module.
      I added my google calender and now i want the remaining time to be absolute.
      So i added timeFormat: 'absolute' but this dosent work…why?
      • KirAsh4K Offline
        KirAsh4 Moderator
        What’s the rest of the config block look like?
          SimJim
            deadherring
            I am having the same problem. However: the way I configured it, is I modified calendar.js in magicmirror/modules/default/calendar. There is a setting in that file timeformat:. It was set to relative and I modified it to absolute.
            Can someone please clarify if this is the proper way to configure this or does something have to be changed in config.js too?
            My calendar is still relative right now.
            Thanks!
            Nathan
            • L Offline
              Les
              I’m also having the same problem of absolute/relative dates. From the config file if it helps to troubleshoot…
                                  module: 'calendar',
                                  header: 'Calendar',
                                  position: 'top_left',
                                          maximumEntries: '6',
                                                          symbol: 'calendar-check-o ',
                                                          url: 'https://calendar.google.com....',
                                                          fade: 'false',
              • P Offline
                paulocarrasco
                I’m new to this MM but I had the same problem. The solution is placing the timeFormat: ‘absolute’ parameter before the "calendars: [ " line.
                I hope this helps.
                • L Offline
                  Les
                  Also the urgency variable. Default is set to 7 days, so only those items after 7 days are displayed in absolute. So I set my to 3 days, anything after that shows up as it should. So SimJim, you may want to check that variable. Even set it to 1 for testing :)
                    deadherring
                    I can’t get absolute dates working. Here’s the relevant part of my calandar.js file.
                    Anyone have any ideas?
                    Module.register(“calendar”,{
                    // Define module defaults
                    defaults: {
                    	maximumEntries: 10, // Total Maximum Entries
                    	maximumNumberOfDays: 365,
                    	displaySymbol: true,
                    	defaultSymbol: "calendar", // Fontawesome Symbol see http://fontawesome.io/cheatsheet/
                    	displayRepeatingCountTitle: false,
                    	defaultRepeatingCountTitle: '',
                    	maxTitleLength: 15,
                    	fetchInterval: 5 * 60 * 1000, // Update every 5 minutes.
                    	animationSpeed: 2000,
                    	fade: false,
                    	urgency: 0,
                    	timeFormat: "absolute",
                    	fadePoint: 0.25, // Start on 1/4th of the list.
                    			symbol: "calendar",
                    			url: "http://www.calendarlabs.com/templates/ical/US-Holidays.ics",
                    • ? Offline
                      A Former User
                      Just a note for others (adding as i work out the system), to change the feed for dates (holidays) from the default list of 10, just open up Calandar.js and
                      Update that to the appropriate days… i.e
                      maximumEntries: 4, // Total Maximum Entries
                      and to change colours add to Custom CSS
                      .calendar .symbol {
                      color: yellow;
                      .calendar .time {
                      color: red;
                      • O Offline
                        orayoflighto Project Sponsor
                        Did anyone resolve this? I am having the same issue.
                          Mykle1 Project Sponsor Module Developer @orayoflighto
                          @orayoflighto said in Default Calender-absolute Date:
                          Paste your config.js entry for the calendar module here, using this guide:
                          https://forum.magicmirror.builders/topic/4247/how-to-post-code-on-the-forum-for-absolute-beginners
                          1 Reply Last reply Reply Quote -1
                            morso @paulocarrasco
                            @paulocarrasco said in Default Calender-absolute Date:
                            I followed @paulocarrasco suggestion and it worked!
                            Here is the code
                                                    header: "US Holidays",
        symbol: "calendar-check-o ",
        url: "webcal://www.calendarlabs.com/templates/ical/US-Holidays.ics"
                            • P Online
                              Peter
                              I just checked my module, I have timeFormat: ‘absolute’,
                              So not: “absolute”
                              I hope this makes the difference!
                              Peter
                              • T Offline
                                Tabbe
                                This post is deleted!
