    Default Calender-absolute Date
    14 Posts 11 Posters 11.8k Views 10 Watching
    • L Offline
      Les
      I’m also having the same problem of absolute/relative dates. From the config file if it helps to troubleshoot…
                          module: 'calendar',
                          header: 'Calendar',
                          position: 'top_left',
                                  maximumEntries: '6',
                                                  symbol: 'calendar-check-o ',
                                                  url: 'https://calendar.google.com....',
                                                  fade: 'false',
                                                  timeFormat: 'absolute'
        paulocarrasco
        I’m new to this MM but I had the same problem. The solution is placing the timeFormat: ‘absolute’ parameter before the "calendars: [ " line.
        I hope this helps.
        • L Offline
          Les
          Also the urgency variable. Default is set to 7 days, so only those items after 7 days are displayed in absolute. So I set my to 3 days, anything after that shows up as it should. So SimJim, you may want to check that variable. Even set it to 1 for testing :)
            deadherring
            I can’t get absolute dates working. Here’s the relevant part of my calandar.js file.
            Anyone have any ideas?
            Module.register(“calendar”,{
            // Define module defaults
            defaults: {
            	maximumEntries: 10, // Total Maximum Entries
            	maximumNumberOfDays: 365,
            	displaySymbol: true,
            	defaultSymbol: "calendar", // Fontawesome Symbol see http://fontawesome.io/cheatsheet/
            	displayRepeatingCountTitle: false,
            	defaultRepeatingCountTitle: '',
            	maxTitleLength: 15,
            	fetchInterval: 5 * 60 * 1000, // Update every 5 minutes.
            	animationSpeed: 2000,
            	fade: false,
            	urgency: 0,
            	timeFormat: "absolute",
            	fadePoint: 0.25, // Start on 1/4th of the list.
            			symbol: "calendar",
            			url: "http://www.calendarlabs.com/templates/ical/US-Holidays.ics",
              A Former User
              Just a note for others (adding as i work out the system), to change the feed for dates (holidays) from the default list of 10, just open up Calandar.js and
              Update that to the appropriate days… i.e
              maximumEntries: 4, // Total Maximum Entries
              and to change colours add to Custom CSS
              .calendar .symbol {
              color: yellow;
              .calendar .time {
              color: red;
              • O Offline
                orayoflighto Project Sponsor
                Did anyone resolve this? I am having the same issue.
                  Mykle1 Project Sponsor Module Developer @orayoflighto
                  @orayoflighto said in Default Calender-absolute Date:
                  Paste your config.js entry for the calendar module here, using this guide:
                  https://forum.magicmirror.builders/topic/4247/how-to-post-code-on-the-forum-for-absolute-beginners
                  1 Reply Last reply Reply Quote -1
                    morso @paulocarrasco
                    @paulocarrasco said in Default Calender-absolute Date:
                    I followed @paulocarrasco suggestion and it worked!
                    Here is the code
                                            header: "US Holidays",
        symbol: "calendar-check-o ",
                      Peter
                      I just checked my module, I have timeFormat: ‘absolute’,
                      So not: “absolute”
                      I hope this makes the difference!
                      Peter
                      • T Offline
                        Tabbe
