    Default Calender-absolute Date
    14 Posts 11 Posters 12.5k Views 10 Watching
      SimJim
        deadherring
        I am having the same problem. However: the way I configured it, is I modified calendar.js in magicmirror/modules/default/calendar. There is a setting in that file timeformat:. It was set to relative and I modified it to absolute.
        Can someone please clarify if this is the proper way to configure this or does something have to be changed in config.js too?
        My calendar is still relative right now.
        Thanks!
        Nathan
        • L Offline
          Les
          I’m also having the same problem of absolute/relative dates. From the config file if it helps to troubleshoot…
                              module: 'calendar',
                              header: 'Calendar',
                              position: 'top_left',
                                      maximumEntries: '6',
                                                      symbol: 'calendar-check-o ',
                                                      url: 'https://calendar.google.com....',
                                                      fade: 'false',
                                                      timeFormat: 'absolute'
            paulocarrasco
            I’m new to this MM but I had the same problem. The solution is placing the timeFormat: ‘absolute’ parameter before the "calendars: [ " line.
            I hope this helps.
            • L Offline
              Les
              Also the urgency variable. Default is set to 7 days, so only those items after 7 days are displayed in absolute. So I set my to 3 days, anything after that shows up as it should. So SimJim, you may want to check that variable. Even set it to 1 for testing :)
                deadherring
                I can’t get absolute dates working. Here’s the relevant part of my calandar.js file.
                Anyone have any ideas?
                Module.register(“calendar”,{
                // Define module defaults
                defaults: {
                	maximumEntries: 10, // Total Maximum Entries
                	maximumNumberOfDays: 365,
                	displaySymbol: true,
                	defaultSymbol: "calendar", // Fontawesome Symbol see http://fontawesome.io/cheatsheet/
                	displayRepeatingCountTitle: false,
                	defaultRepeatingCountTitle: '',
                	maxTitleLength: 15,
                	fetchInterval: 5 * 60 * 1000, // Update every 5 minutes.
                	animationSpeed: 2000,
                	fade: false,
                	urgency: 0,
                	timeFormat: "absolute",
                	fadePoint: 0.25, // Start on 1/4th of the list.
                			symbol: "calendar",
                			url: "http://www.calendarlabs.com/templates/ical/US-Holidays.ics",
                  A Former User
                  Just a note for others (adding as i work out the system), to change the feed for dates (holidays) from the default list of 10, just open up Calandar.js and
                  Update that to the appropriate days… i.e
                  maximumEntries: 4, // Total Maximum Entries
                  and to change colours add to Custom CSS
                  .calendar .symbol {
                  color: yellow;
                  .calendar .time {
                  color: red;
                  • O Offline
                    orayoflighto Project Sponsor
                    Did anyone resolve this? I am having the same issue.
                      Mykle1 Project Sponsor Module Developer @orayoflighto
                      @orayoflighto said in Default Calender-absolute Date:
                      Paste your config.js entry for the calendar module here, using this guide:
                      https://forum.magicmirror.builders/topic/4247/how-to-post-code-on-the-forum-for-absolute-beginners
                      1 Reply Last reply Reply Quote -1
                        morso @paulocarrasco
                        @paulocarrasco said in Default Calender-absolute Date:
                        I followed @paulocarrasco suggestion and it worked!
                        Here is the code
                                                header: "US Holidays",
        symbol: "calendar-check-o ",
                          Peter
                          I just checked my module, I have timeFormat: ‘absolute’,
                          So not: “absolute”
                          I hope this makes the difference!
                          Peter
                          • T Offline
                            Tabbe
