    MMM-NetworkScanner
    networkscannerstatusmac address
    117 Posts 32 Posters 232.1k Views 33 Watching
      AshDarko
      I do however get this from time to time…
      MMM-NetworkScanner received SCAN_NETWORK
      MMM-NetworkScanner is performing arp-scan
      TypeError: Cannot read property 'network' of undefined
          at Class.scanNetworkMAC (/home/pi/MagicMirror/modules/MMM-NetworkScanner/node_helper.js:42:36)
          at Class.socketNotificationReceived (/home/pi/MagicMirror/modules/MMM-NetworkScanner/node_helper.js:30:18)
          at Socket.<anonymous> (/home/pi/MagicMirror/modules/node_modules/node_helper/index.js:113:11)
          at emitTwo (events.js:126:13)
          at Socket.emit (events.js:214:7)
          at /home/pi/MagicMirror/node_modules/socket.io/lib/socket.js:528:12
          at _combinedTickCallback (internal/process/next_tick.js:132:7)
          at process._tickCallback (internal/process/next_tick.js:181:9)
      Any ideas?
      • I Offline
        ianperrin @AshDarko
        @AshDarko said in MMM-NetworkScanner:
        Just changed it to “devices:” and now it works… god knows why i had “device”… i dont know if this is in some code somewhere haha
        Glad you got it sorted.
        I think all the documentation and code uses devices, but if you spot otherwise, please raise an issue.
        "Live as if you were to die tomorrow. Learn as if you were to live forever." - Mahatma Gandhi
        • I Offline
          ianperrin @AshDarko
          Any ideas?
          Difficult to say without more information. If you are able to reproduce the error, please share more details.
            Bob
            There appears to be a bug in the OUI and IAB scripts for arp-scan. IEEE have changed the URL for both files (from the defaults listed)
            They are now:
            http://standards-oui.ieee.org/oui/oui.txt
            http://standards-oui.ieee.org/iab/iab.txt
            You can either edit the get-oui and get-iab perl scripts (which was my preference), or run the scripts with the above URL’s instead of the defaults.
            Also, don’t forget to move the resulting TXT files to /usr/share/arp-scan (if you run the scan from anywhere other than that directory)
            • I Offline
              ianperrin @Bob
              Thanks @Bob, I’ve updated the URLs in the ReadMe file
                Arjan Project Sponsor
                I’m trying to use MMM-NetworkScanner as a monitoring tool so I can see what device is down.
                Is there a way to only show devices if they are off-line. I have got to many devices to show them all, so I’m not interested in the on-line devices.
                Also I’m trying to get there some colour in . But nonmatter what I do, there is only white. What is wrong in my config?
                module : “MMM-NetworkScanner”,
                disabled : false,
                position : “top_right”,
                header : “Monitoring”,
                config : {
                showUnknown : false,
                showLastSeen : false,
                keepAlive : 180,
                updateInterval : 60,
                showLastSeenWhenOffline : true,
                color : true,
                coloredSymbolOnly : true,
                devices : [
                { ipAddress: “10.0.0.200”, name: “Wifi-Meterkast”, icon: “wifi”, color: “#ff0000” },
                { ipAddress: “10.0.0.201”, name: “Wifi-Woonkamer”, icon: “wifi”, color: “#ff0000” },
                { ipAddress: “10.0.0.202”, name: “Wifi-Zolder”, icon: “wifi”, color: “#ff0000” },
                { ipAddress: “10.0.99.201”, name: “Wifi-Garage”, icon: “wifi”, color: “#ff0000” },
                I 2 Replies Last reply Reply Quote 0
                • I Offline
                  ianperrin @Arjan
                  @Arjan said in MMM-NetworkScanner:
                  Unfortunately, there’s not currently an option to hide online devices via the config. Feel free to raise a issue suggesting this enhancement via GitHub or even a Pull Request :winking_face:
                  However, there may be a way to do it using css. Devices which are online should be rendered in a table row (tr) with the class of bright, whilst offline devices will have the class of dimmed.
                  I’m away from my mirror right now, so the example below may not be quite right, but try adding the following to the custom.css.
                  .MMM-NetworkScanner table tr.bright {
                    display: none;
                  • I Offline
                    ianperrin @Arjan
                    As I’m away from my mirror at the moment, I can’t test your config, however, there may be an issue with the new color functionality introduced following a recent pull request.
                    Until I get chance to look at it, then if you want to color the icons for all offline devices in the same color (e.g. red), then again try adding this to the custom.css file
                    .MMM-NetworkScanner table tr.dimmed td i {
                      color: #f00;
                    To color online devices, change tr.dimmed to tr.bright
                    To color the text as well as the icon, remove the trailing td i
                      Arjan Project Sponsor @ianperrin
                      @ianperrin : Cool, The colors are working now and the part for only displaying Off-Line is also working.
                      Thanks guys.
                        AshDarko @ianperrin
                        @ianperrin I am able to reproduce quite often, but it is seemingly running normally?
                        i had several of these happen just now:
                        • 8
                        • 9
                        • 10
                        • 11
                        • 12
                        • 11 / 12
