    MMM-NetworkScanner
    networkscannerstatusmac address
    117 Posts 32 Posters 232.1k Views 33 Watching
    • zdenekZ Offline
      zdenek @Mykle1
      @Mykle1 You are the best! Thanks. Finally it works. The problem was with the array. But see home page of module https://github.com/ianperrin/MMM-NetworkScanner - there is an example config and there is
      residents: “Mobile”,
      The only difference is that I’ve 1st icon and then name
      The time difference i’ve to check. Thanks a lot
      BTW, Hot to format text as code? If I tried the icon it place ```, than row
      //my code
      and again the same three signs. I tried to add row between the weird signs, but it’s normal text
        Mykle1 Project Sponsor Module Developer @zdenek
        @zdenek said in MMM-NetworkScanner:
        Yes, I’ve changed mine to suit my liking.
        To display code, wrap it in one back tick character (for inline code) or three back ticks (for code blocks).Note that the back tick character isn’t the same as the single quote — ’ — mark; the back tick is located on the same key as the ~ on most keyboards.
        zdenekZ 1 Reply Last reply Reply Quote 1
        • zdenekZ Offline
          zdenek @Mykle1
          @Mykle1 great, thanks. The last (I hope) question is about CSS - I would like to have online devices not white, but let say green. Or just “icon” to have green. Or just Name of device. (depends, what is easier) And the offline keep grey. Do you know, how to do that? Thanks
            @zdenek
            I see you started another topic and are getting assistance there. :thumbsup_tone1:
            zdenekZ 1 Reply Last reply Reply Quote 0
            • zdenekZ Offline
              zdenek @Mykle1
              @Mykle1 yep, sorry
                @Mykle1 yep, sorry
                No worries. I’m glad you are getting the help you need.
                Peace
                • zeularZ Offline
                  zeular
                  Hi
                  I’ve been playing a bit with this now and my phones come and go all the time, I have tested keepAlive from 120 - 1200 and updateInterval at 10.
                  My server that runs 24/7 also disappears sometimes (connected with cable).
                  I’ve added everything with macAddress, IP doesn’t work for me…
                    Mykle1 Project Sponsor Module Developer @zeular
                    @zeular said in MMM-NetworkScanner:
                    Go up about 8 or 9 posts from here and you’ll see what I recommended to someone about using an earlier version.
                    zeularZ 1 Reply Last reply Reply Quote 0
                    • zeularZ Offline
                      zeular @Mykle1
                      @Mykle1 Aha, I thought the latest would work now.
                      I’m now testing a version from early February, seems to work but I must have “showOffline: true” otherwise “No device online”.
                        I use “showOffline: true” (see post above) so I don’t see that.
                        • 6
                        • 7
                        • 8
                        • 9
                        • 10
                        • 11
                        • 12
                        • 8 / 12
