    MMM-NetworkScanner
    networkscannerstatusmac address
    117 Posts 32 Posters 258.7k Views 33 Watching
      Blackmirror
      Nice to make a output gpio in this module, so I can installed a relais, to switch thinks on, only when I am in the house.
      • zdenekZ
        zdenek
        I’ve also issue - “resident” doesn’t work for me:
        and here ic config:
              		module: 'MMM-NetworkScanner',
                	position: 'bottom_right',
                    		devices: [
        	                    	{ macAddress: "ab:ab:ab:ab:ab:ab", name: "Mobile", icon: "server"},
                    		showUnknown: false,
        			debug: false,
                    		showOffline: true,
                    		keepAlive: 60,
                    		updateInterval: 30,
                    		residents: "Mobile",
        			showLastSeen: true,
         	                occupiedCMD: {notification: 'REMOTE_ACTION', payload: {action: 'MONITORON'}},
                    		vacantCMD  : {notification: 'REMOTE_ACTION', payload: {action: 'MONITOROFF'}},
        any idea? module get started, Icon and name appers, but it’s still “grey” (like offline - wifi is on, I can see Raspberry and also Server on the same network via Fing)
        Tried also with IP - the same. Tried another device, the same. And arp-scan --localnet I can see the devices I want to monitor
        thanks for help
        Zdeněk
        Mykle1M 1 Reply Last reply
        • Mykle1M
          Mykle1 Project Sponsor Module Developer @zdenek
          @zdenek said in MMM-NetworkScanner:
          any idea?
          you could use an earlier version that does work until this one gets fixed
          zdenekZ 1 Reply Last reply
          • zdenekZ
            zdenek @Mykle1
            @Mykle1 thanks fir help. Stupid question - how? I can download source code of v0.0.1 and these files simply copy/paste to /home/pi/MagicMirror/modules/MMM-NetworkScanner folder? And subfolder node_modules leave as it is? If I did (and nothing else changed), module starts and on screen is just “Loading…” forever.
            MMM-NetworkScanner received SCAN_NETWORK
            MMM-NetworkScanner is scanning for mac addresses
            and it continue on the same way
            thanks, Zdeněk
            • Mykle1M
              You can delete your existing MMM-NetworkScanner folder, seeing as it’s not working for you. Then go here, where you’ll find previous versions:
              https://github.com/ianperrin/MMM-NetworkScanner/commits/master
              I am using late January or earlier February. I can’t remember which and I’m not with my Pi right now. Note: I am using only IP addresses, not MAC addresses, but it works perfectly for me
              • zdenekZ
                zdenek @Mykle1
                @Mykle1 thanks. Module starts, but “residents” doesn’t work for me.
                MMM-NetworkScanner is scanning for ip addresses
                Recived payload: [ { ipAddress: ‘192.168.1.11’,
                icon: ‘server’,
                online: true,
                lastSeen: ‘2017-04-28T12:50:02.107Z’ } ]
                So, device is online, but in Raspberry is “NO DEVICE ONLINE”
                in config is:
                residents: “Mobile”,
                if I turn on “show unknow”, it lists about 10 devices in my net, include MAC belongs to 192.168.1.11
                one more thing - the time of “last seen” (lastSeen: ‘2017-04-28T12:50:02.107Z’) is 2 hours lower compared to system time. It’s cause of time zone+winter/summer time. How to avoid the thime difference?
                • Mykle1M
                  residents: [] belong inside the array. That is why residents: "Mobile", won’t work. However, I don’t fill the
                  residents:array at all, leaving it simply as, residents: [] See my config entry:
                  			disabled: f,
                          		position: 'top_left',
                  			debug: false,
                              		devices: [
                                      	{ ipAddress: "192.168.1.2", name: "Dove", icon: "medkit"},
                  			{ ipAddress: "192.168.1.15", name: "BabyJesus", icon: "futbol-o"},
                                      	{ ipAddress: "192.168.1.8", name: "BottlePop", icon: "globe"},
                                      	{ ipAddress: "192.168.1.11", name: "Donna", icon: "venus"},
                  			{ ipAddress: "192.168.1.10", name: "Nikki", icon: "coffee"},
                  			{ ipAddress: "192.168.1.7", name: "Jason", icon: "fire-extinguisher"},
                  			{ ipAddress: "192.168.1.18", name: "MJD", icon: "child"}
                              		showUnknown: false,
                              		showOffline: true,
                  			showLastSeen: false,
                              		keepAlive: 1200, // in seconds (20 min)
                              		updateInterval: 30, // in seconds
                              		residents: []
                  and the result:
                  I don’t know about your time issue, sorry.
                  • zdenekZ
                    zdenek @Mykle1
                    @Mykle1 You are the best! Thanks. Finally it works. The problem was with the array. But see home page of module https://github.com/ianperrin/MMM-NetworkScanner - there is an example config and there is
                    The only difference is that I’ve 1st icon and then name
                    The time difference i’ve to check. Thanks a lot
                    BTW, Hot to format text as code? If I tried the icon it place ```, than row
                    //my code
                    and again the same three signs. I tried to add row between the weird signs, but it’s normal text
                    • Mykle1M
                      Yes, I’ve changed mine to suit my liking.
                      To display code, wrap it in one back tick character (for inline code) or three back ticks (for code blocks).Note that the back tick character isn’t the same as the single quote — ’ — mark; the back tick is located on the same key as the ~ on most keyboards.
                      • zdenekZ
                        zdenek @Mykle1
                        @Mykle1 great, thanks. The last (I hope) question is about CSS - I would like to have online devices not white, but let say green. Or just “icon” to have green. Or just Name of device. (depends, what is easier) And the offline keep grey. Do you know, how to do that? Thanks
                        • Mykle1M
                          @zdenek
                          I see you started another topic and are getting assistance there. :thumbsup_tone1:
                          • zdenekZ
                            zdenek @Mykle1
                            @Mykle1 yep, sorry
                            • Mykle1M
                              @Mykle1 yep, sorry
                              No worries. I’m glad you are getting the help you need.
                              Peace
                              • zeularZ
                                zeular
                                Hi
                                I’ve been playing a bit with this now and my phones come and go all the time, I have tested keepAlive from 120 - 1200 and updateInterval at 10.
                                My server that runs 24/7 also disappears sometimes (connected with cable).
                                I’ve added everything with macAddress, IP doesn’t work for me…
                                • Mykle1M
                                  Mykle1 Project Sponsor Module Developer @zeular
                                  @zeular said in MMM-NetworkScanner:
                                  Go up about 8 or 9 posts from here and you’ll see what I recommended to someone about using an earlier version.
                                  zeularZ 1 Reply Last reply
                                  • zeularZ
                                    zeular @Mykle1
                                    @Mykle1 Aha, I thought the latest would work now.
                                    I’m now testing a version from early February, seems to work but I must have “showOffline: true” otherwise “No device online”.
                                    • Mykle1M
                                      I use “showOffline: true” (see post above) so I don’t see that.
                                      • zdenekZ
                                        zdenek @Mykle1
                                        @Mykle1 for me it works also weird. For my iPhone (7, latest iOS) and Samsung (Android - don´t knwo which version, but the latest supported by phone) it works perfect. But for iPhone (5S, lates iOS) of my wife it works “randomly”. When is she is at home, module sometimes detects her phone, sometimes not. Sometimes it works, but after some time it makes her phone oflline even she still at home, iPhone on wifi (if I run any app detecting devices in the same network - Fing on my iPhone - it detects her iP5S). Any idea?
                                        zeularZ Mykle1M 2 Replies Last reply
                                        • zeularZ
                                          zeular @zdenek
                                          @zdenek @Mykle1 For me, it’s the same error on iPhone and Android. I think the phones turn off WiFi or use some energy saving mode because they log on and off all the time when they are passive/inactive, When I keep the screen ON, they are visible all the time. Therefore, the “KeepAlive” is a “must have”.
                                          Now that I use early Februray, it works better, the phones only log off sometimes when inactive.
                                          But I would really like to hide devices that are not logged in, so you can add other friends and family who do not need to be visible all the time.
                                          • Mykle1M
                                            But I would really like to hide devices that are not logged in, so you can > add other friends and family who do not need to be visible all the time.
                                            I would like that, too, but that is out of my hands. You could post an option request to the author. I understand he is away at the moment. Or, better still, you could fork the repo and develop that feature yourself. Then send a pull request to the author and he might add it permanently to the module.
                                            • 4 / 6
