    MMM-NetworkScanner
    networkscannerstatusmac address
    117 Posts 32 Posters 256.9k Views 33 Watching
      bminer1 @binderth
      @binderth I think you are on a right track. We just need to debug the “simple” task of turning on and off and then the fun can begin with other stuff.
      • I
        ianperrin @bminer1
        @bminer1, @pugsly, @Speedy-one
        I’m still working through the issues introduced last weeekend, but have just added a commitwhich attempts to resolve the duplicate devices issue. I’d be grateful if you could try it out and confirm.
        “Live as if you were to die tomorrow. Learn as if you were to live forever.” - Mahatma Gandhi
        • I
          ianperrin @derek7467
          @derek7467
          If you can provide the arp-scan command for this, an option could be added to support it - once the current issues are fixed of course ;)
          Cc @bluedoors
          • I
            ianperrin @bminer1
            @bminer1, @binderth
            I’m going to be taking a look at the notifications functionally after the issues with the current release have been resolved.
              Blackmirror
              Nice to make a output gpio in this module, so I can installed a relais, to switch thinks on, only when I am in the house.
              • zdenekZ
                zdenek
                I’ve also issue - “resident” doesn’t work for me:
                and here ic config:
                      		module: 'MMM-NetworkScanner',
                        	position: 'bottom_right',
                            		devices: [
                	                    	{ macAddress: "ab:ab:ab:ab:ab:ab", name: "Mobile", icon: "server"},
                            		showUnknown: false,
                			debug: false,
                            		showOffline: true,
                            		keepAlive: 60,
                            		updateInterval: 30,
                            		residents: "Mobile",
                			showLastSeen: true,
                 	                occupiedCMD: {notification: 'REMOTE_ACTION', payload: {action: 'MONITORON'}},
                            		vacantCMD  : {notification: 'REMOTE_ACTION', payload: {action: 'MONITOROFF'}},
                any idea? module get started, Icon and name appers, but it’s still “grey” (like offline - wifi is on, I can see Raspberry and also Server on the same network via Fing)
                Tried also with IP - the same. Tried another device, the same. And arp-scan --localnet I can see the devices I want to monitor
                thanks for help
                Zdeněk
                • Mykle1M
                  Mykle1 Project Sponsor Module Developer @zdenek
                  @zdenek said in MMM-NetworkScanner:
                  any idea?
                  you could use an earlier version that does work until this one gets fixed
                  zdenekZ 1 Reply Last reply Reply Quote 0
                  • zdenekZ
                    zdenek @Mykle1
                    @Mykle1 thanks fir help. Stupid question - how? I can download source code of v0.0.1 and these files simply copy/paste to /home/pi/MagicMirror/modules/MMM-NetworkScanner folder? And subfolder node_modules leave as it is? If I did (and nothing else changed), module starts and on screen is just “Loading…” forever.
                    MMM-NetworkScanner received SCAN_NETWORK
                    MMM-NetworkScanner is scanning for mac addresses
                    and it continue on the same way
                    thanks, Zdeněk
                    • Mykle1M
                      You can delete your existing MMM-NetworkScanner folder, seeing as it’s not working for you. Then go here, where you’ll find previous versions:
                      https://github.com/ianperrin/MMM-NetworkScanner/commits/master
                      I am using late January or earlier February. I can’t remember which and I’m not with my Pi right now. Note: I am using only IP addresses, not MAC addresses, but it works perfectly for me
                      • zdenekZ
                        zdenek @Mykle1
                        @Mykle1 thanks. Module starts, but “residents” doesn’t work for me.
                        MMM-NetworkScanner is scanning for ip addresses
                        Recived payload: [ { ipAddress: ‘192.168.1.11’,
                        icon: ‘server’,
                        online: true,
                        lastSeen: ‘2017-04-28T12:50:02.107Z’ } ]
                        So, device is online, but in Raspberry is “NO DEVICE ONLINE”
                        in config is:
                        residents: “Mobile”,
                        if I turn on “show unknow”, it lists about 10 devices in my net, include MAC belongs to 192.168.1.11
                        one more thing - the time of “last seen” (lastSeen: ‘2017-04-28T12:50:02.107Z’) is 2 hours lower compared to system time. It’s cause of time zone+winter/summer time. How to avoid the thime difference?
                        • Mykle1M
                          residents: [] belong inside the array. That is why residents: "Mobile", won’t work. However, I don’t fill the
                          residents:array at all, leaving it simply as, residents: [] See my config entry:
                          			disabled: f,
                                  		position: 'top_left',
                          			debug: false,
                                      		devices: [
                                              	{ ipAddress: "192.168.1.2", name: "Dove", icon: "medkit"},
                          			{ ipAddress: "192.168.1.15", name: "BabyJesus", icon: "futbol-o"},
                                              	{ ipAddress: "192.168.1.8", name: "BottlePop", icon: "globe"},
                                              	{ ipAddress: "192.168.1.11", name: "Donna", icon: "venus"},
                          			{ ipAddress: "192.168.1.10", name: "Nikki", icon: "coffee"},
                          			{ ipAddress: "192.168.1.7", name: "Jason", icon: "fire-extinguisher"},
                          			{ ipAddress: "192.168.1.18", name: "MJD", icon: "child"}
                                      		showUnknown: false,
                                      		showOffline: true,
                          			showLastSeen: false,
                                      		keepAlive: 1200, // in seconds (20 min)
                                      		updateInterval: 30, // in seconds
                                      		residents: []
                          and the result:
                          I don’t know about your time issue, sorry.
                          • zdenekZ
                            zdenek @Mykle1
                            @Mykle1 You are the best! Thanks. Finally it works. The problem was with the array. But see home page of module https://github.com/ianperrin/MMM-NetworkScanner - there is an example config and there is
                            The only difference is that I’ve 1st icon and then name
                            The time difference i’ve to check. Thanks a lot
                            BTW, Hot to format text as code? If I tried the icon it place ```, than row
                            //my code
                            and again the same three signs. I tried to add row between the weird signs, but it’s normal text
                            • Mykle1M
                              Yes, I’ve changed mine to suit my liking.
                              To display code, wrap it in one back tick character (for inline code) or three back ticks (for code blocks).Note that the back tick character isn’t the same as the single quote — ’ — mark; the back tick is located on the same key as the ~ on most keyboards.
                              zdenekZ 1 Reply Last reply Reply Quote 1
                              • zdenekZ
                                zdenek @Mykle1
                                @Mykle1 great, thanks. The last (I hope) question is about CSS - I would like to have online devices not white, but let say green. Or just “icon” to have green. Or just Name of device. (depends, what is easier) And the offline keep grey. Do you know, how to do that? Thanks
                                • Mykle1M
                                  @zdenek
                                  I see you started another topic and are getting assistance there. :thumbsup_tone1:
                                  • zdenekZ
                                    zdenek @Mykle1
                                    @Mykle1 yep, sorry
                                    • Mykle1M
                                      @Mykle1 yep, sorry
                                      No worries. I’m glad you are getting the help you need.
                                      Peace
                                      • zeularZ
                                        zeular
                                        Hi
                                        I’ve been playing a bit with this now and my phones come and go all the time, I have tested keepAlive from 120 - 1200 and updateInterval at 10.
                                        My server that runs 24/7 also disappears sometimes (connected with cable).
                                        I’ve added everything with macAddress, IP doesn’t work for me…
                                        • Mykle1M
                                          Mykle1 Project Sponsor Module Developer @zeular
                                          @zeular said in MMM-NetworkScanner:
                                          Go up about 8 or 9 posts from here and you’ll see what I recommended to someone about using an earlier version.
                                          zeularZ 1 Reply Last reply Reply Quote 0
                                          • zeularZ
                                            zeular @Mykle1
                                            @Mykle1 Aha, I thought the latest would work now.
                                            I’m now testing a version from early February, seems to work but I must have “showOffline: true” otherwise “No device online”.
                                            • 4 / 6
