    MMM-NetworkScanner
    networkscannerstatusmac address
    117 Posts 32 Posters 253.0k Views 33 Watching
    • P Offline
      pugsly
      This was working great for me until the latest git pull. I am getting the following errors now.
      mm-0 (err): at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/electron-prebuilt/dist/resources/electron.asar/common/reset-search-paths.js:35:12)
      mm-0 (err): at Function.Module._load (module.js:403:25)
      mm-0 (err): at Module.require (module.js:483:17)
      mm-0 (err): at require (internal/module.js:20:19)
      mm-0 (err): at Object. (/home/pi/MagicMirror/modules/MMM-NetworkScanner/node_helper.js:10:14)
      mm-0 (err): at Module._compile (module.js:556:32)
      mm-0 (err): at Object.Module._extensions…js (module.js:565:10)
      mm-0 (err): at Module.load (module.js:473:32)
      mm-0 (err): at tryModuleLoad (module.js:432:12)
      mm-0 (err): { Error: Cannot find module ‘ping’
      mm-0 (err): at Module._resolveFilename (module.js:455:15)
      mm-0 (err): at tryModuleLoad (module.js:432:12) code: ‘MODULE_NOT_FOUND’ }
        BenNewsome @ianperrin
        @ianperrin No problem, thanks for the great module(s). I hope I accidentally didn’t break anything as I’m pretty new to Node.
          BenNewsome @pugsly
          @pugsly Sorry thats from my update. Have you done a NPM install inside the module as it has a new dependency?
          Hopefully this will fix the problem.
          P 2 Replies Last reply Reply Quote 0
          • P Offline
            pugsly @BenNewsome
            @BenNewsome yes I did
            • P Offline
              pugsly @BenNewsome
              @BenNewsome I see that it installed two things under \Magicmirror\modules\MMM-NetworkScanner\node_modules
              one dir called ping which is what the error says it can’t find
              the other called sudo (that one kinda worries me).
              Anyway it still doesn’t work.
                BenNewsome @pugsly
                @pugsly Hi pugsly,
                sudo is for arp-scan which is the MAC address checker as this requires sudo to be called.
                Ping is the one I added which just calls the ping command from node.
                Could you try editing the file: /home/pi/MagicMirror/modules/MMM-NetworkScanner/node_helper.js
                On line 10 it says
                const ping = require('ping')
                Could you replace it with:
                const ping = require("ping");
                (Change the speach marks and add a semicolon.)
                I have no idea if this is the reason as it works fine on my system, but it is my current best guess.
                • P Offline
                  pugsly @BenNewsome
                  @BenNewsome Sorry… same thing, still says can’t find module ‘ping’.
                    BenNewsome @pugsly
                    @pugsly I think I have managed to replicate your error.
                    Could you run the following command.
                    (cd /home/pi/MagicMirror/modules/MMM-NetworkScanner && npm install)
                    npm install needs running from the module directory so that it downloads the npm ping module. When I delete the ping module I get the error you do, and when I run the command above the error goes away.
                    D P 2 Replies Last reply Reply Quote 0
                      derek7467 @BenNewsome
                      @BenNewsome any easy way to change the text color? I’m able to change text size via custom.css but the color doesn’t seem to take.
                        Mykle1 Project Sponsor Module Developer @ianperrin
                        @ianperrin said in MMM-NetworkScanner:
                        there no such thing as a stupid question so keep asking away…
                        Hi, and please help. Thank you.
                        I’ve got this module running but the only devices that will show as active are the Github from the sample config and the showUnknown devices which I have turned off. All others that I have added appear as offline. I’m using the MAC addresses that I got from my router and they are correct and all in lower case. I read above where that might be an issue. I did git pull and npm install in the MMM-NetworkScanner folder.
                                		module: 'MMM-NetworkScanner',
                                		position: 'top_left',
                        			devices: [
                        				{ ipAddress: "github.com", name: "Github", icon: "globe"},
                        				{ ipAddress: "192.168.1.4", name: "MykleDesktop", icon: "desktop"},
                                            		{ macAddress: "mac.address.all.lower.case", name: "DoveMBP", icon: "laptop"},
                                            		{ macAddress: "mac.address.all.lower.case", name: "MyklesiPhone", icon: "mobile"},
                                            		{ macAddress: "mac.address.all.lower.case", name: "JayAndroid", icon: "mobile"},
                                            		{ macAddress: "mac.address.all.lower.case", name: "DonnaMBP", icon: "laptop"},
                                            		{ macAddress: "mac.address.all.lower.case", name: "DonnaiPhone", icon: "mobile"},
                        				{ macAddress: "mac.address.all.lower.case", name: "NikkiiPhone", icon: "mobile"},
                                    			showUnknown: false,
                                			showOffline: true,
                                			showLastSeen: true,
                                			keepAlive: 180,
                                			updateInterval: 10,
                                			residents: "Mobile", // I tried this with each name of the devices above and each icon name
                                			occupiedCMD: {notification: 'TEST', payload: {action: 'occupiedCMD'}},
                                			vacantCMD:   {notification: 'TEST', payload: {action: 'vacantCMD'}},
                          derek7467 @Mykle1
                          @Mykle1 looks like when i use IP, it shows offline vs online accurately. When i use MAC or a web address, it doesnt. Something is wrong with the scan by mac option.
                          • P Offline
                            pugsly @BenNewsome
                            @BenNewsome
                            Removed it, did a new clone, and ran the npm install (See Below). Still getting the error that ping is missing and all of my MAC machines are grayed out.
                            pi@MagicMirror:~/MagicMirror/modules/MMM-NetworkScanner $ cd …
                            pi@MagicMirror:~/MagicMirror/modules $ sudo rm -r ~/MagicMirror/modules/MMM-Netw orkScanner
                            pi@MagicMirror:~/MagicMirror/modules $ git clone https://github.com/ianperrin/MM M-NetworkScanner.git
                            Cloning into ‘MMM-NetworkScanner’…
                            remote: Counting objects: 132, done.
                            remote: Compressing objects: 100% (16/16), done.
                            remote: Total 132 (delta 6), reused 0 (delta 0), pack-reused 116
                            Receiving objects: 100% (132/132), 80.07 KiB | 0 bytes/s, done.
                            Resolving deltas: 100% (74/74), done.
                            Checking connectivity… done.
                            pi@MagicMirror:~/MagicMirror/modules $ cd /home/pi/MagicMirror/modules/MMM-Netwo rkScanner && npm install
                            ping@0.1.10 node_modules/ping
                            └── q@1.4.1
                            sudo@1.0.3 node_modules/sudo
                            ├── inpath@1.0.2
                            ├── pidof@1.0.2
                            └── read@1.0.7 (mute-stream@0.0.7)
                            mm-0 (out): { macAddress: ‘18:b4:30:1d:f6:50’,
                            mm-0 (out): name: ‘Nest Thermostat’,
                            mm-0 (out): icon: ‘dot-circle-o’ },
                              derek7467
                              Only difference between you and I is you run the install with the &&. Remove it again, rerun from the beginning and manually CD into the directory and run the install from there. Skip using the && to install all in one shot.
                              P slametpsS 2 Replies Last reply Reply Quote 0
                              • P Offline
                                pugsly @derek7467
                                @derek7467
                                as you said, IP works fine MAC doesn’t… MAC was working up until the update where you could add the ‘last seen xxx min ago’ option.
                                D slametpsS 2 Replies Last reply Reply Quote 0
                                  derek7467 @pugsly
                                  @pugsly yea I’m in same boat. I haven’t read all the code just yet but I imagine the way it performs the ARP scan by Mac is the culprit. For now I set my untangle router to serve out static DHCP leases and thus my problem is gone.
                                    Speedy-one
                                    Me too o.O
                                    • slametpsS Offline
                                      slametps @pugsly
                                      @pugsly Unfortunately, mine is not working anymore, neither MAC or IP. :sob:
                                      regards,
                                      Slamet PS
                                      • slametpsS Offline
                                        slametps @derek7467
                                        @derek7467
                                        @derek7467 said in MMM-NetworkScanner:
                                        Still no luck. Neither MAC or IP.
                                        regards,
                                        Slamet PS
                                          Mykle1 Project Sponsor Module Developer @slametps
                                          @slametps
                                          This worked for me. If you have FIOS you might want to try it. If not, if you have the ability to set static ip addresses in your own system, you could try that
                                          I went into my FIOS router and assigned a “static lease” on the IP addresses of the devices that would not show in NetworkScanner with their MAC addresses. Went back into my config.js and changed the macAddress to ipAddress for each device and put in the static IP addresses I just assigned in the router.
                                          It’s working now, all except for the machine I am working on now (my desktop). It doesn’t show as active, even with a static lease on the IP address. That’s sort of alright, as I really just wanted the cell phones to appear, which they do, but odd,
                                          For those with FIOS that want to try:
                                          Sign in to Verizon router. Click Advanced tab (almost top right). Click yes to proceed. Click IP Address Distribution bottom right. Click Connection List almost in the middle. On the left, find the device that you want to assign a static lease IP address to. On the right, in the Action column, click the Edit icon. Tick the Static Lease Type box. Click Apply. That is now a static IP address. GO back one page and look in the Lease Type column. It will show you the Static designation.
                                          Peace
                                          slametpsS 1 Reply Last reply Reply Quote 0
                                          • slametpsS Offline
                                            slametps @Mykle1
                                            @Mykle1 I’m already assigned static IP for all my devices connected to the router. When I set config showUnknown: true, the module display all detected devices (of course only display MAC addresses in upper-case), instead displaying the proper device name I set in the config.
                                            regards,
                                            Slamet PS
                                            • 6
                                            • 2 / 6
