    MMM-NetworkScanner
    networkscannerstatusmac address
    117 Posts 32 Posters 258.7k Views 33 Watching
    • I
      ianperrin @BenNewsome
      @BenNewsome Hi Ben - I’m commited elsewhere at the moment so sorry for not getting back to you sooner. Thanks for the pull request - I’ve accepted it and merged it into the module for all to share!
      “Live as if you were to die tomorrow. Learn as if you were to live forever.” - Mahatma Gandhi
      B 1 Reply Last reply
      • I
        ianperrin @outjet
        @outjet I’ve not been able to spend much time on the Mirror (or this module) recently but I’ve just updated the module to include @BenNewsome’s additional functionality along with a showLastSeen option
        Can you try updating your module and adding this to your config.js file e.g. showLastSeen: true,
        • pugslyP
          pugsly
          This was working great for me until the latest git pull. I am getting the following errors now.
          mm-0 (err): at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/electron-prebuilt/dist/resources/electron.asar/common/reset-search-paths.js:35:12)
          mm-0 (err): at Function.Module._load (module.js:403:25)
          mm-0 (err): at Module.require (module.js:483:17)
          mm-0 (err): at require (internal/module.js:20:19)
          mm-0 (err): at Object. (/home/pi/MagicMirror/modules/MMM-NetworkScanner/node_helper.js:10:14)
          mm-0 (err): at Module._compile (module.js:556:32)
          mm-0 (err): at Object.Module._extensions…js (module.js:565:10)
          mm-0 (err): at Module.load (module.js:473:32)
          mm-0 (err): at tryModuleLoad (module.js:432:12)
          mm-0 (err): { Error: Cannot find module ‘ping’
          mm-0 (err): at Module._resolveFilename (module.js:455:15)
          mm-0 (err): at tryModuleLoad (module.js:432:12) code: ‘MODULE_NOT_FOUND’ }
            BenNewsome @ianperrin
            @ianperrin No problem, thanks for the great module(s). I hope I accidentally didn’t break anything as I’m pretty new to Node.
              BenNewsome @pugsly
              @pugsly Sorry thats from my update. Have you done a NPM install inside the module as it has a new dependency?
              Hopefully this will fix the problem.
              pugslyP 2 Replies Last reply
              • pugslyP
                pugsly @BenNewsome
                @BenNewsome yes I did
                • pugslyP
                  pugsly @BenNewsome
                  @BenNewsome I see that it installed two things under \Magicmirror\modules\MMM-NetworkScanner\node_modules
                  one dir called ping which is what the error says it can’t find
                  the other called sudo (that one kinda worries me).
                  Anyway it still doesn’t work.
                    BenNewsome @pugsly
                    @pugsly Hi pugsly,
                    sudo is for arp-scan which is the MAC address checker as this requires sudo to be called.
                    Ping is the one I added which just calls the ping command from node.
                    Could you try editing the file: /home/pi/MagicMirror/modules/MMM-NetworkScanner/node_helper.js
                    On line 10 it says
                    const ping = require('ping')
                    Could you replace it with:
                    const ping = require("ping");
                    (Change the speach marks and add a semicolon.)
                    I have no idea if this is the reason as it works fine on my system, but it is my current best guess.
                    pugslyP 1 Reply Last reply
                    • pugslyP
                      pugsly @BenNewsome
                      @BenNewsome Sorry… same thing, still says can’t find module ‘ping’.
                        BenNewsome @pugsly
                        @pugsly I think I have managed to replicate your error.
                        Could you run the following command.
                        (cd /home/pi/MagicMirror/modules/MMM-NetworkScanner && npm install)
                        npm install needs running from the module directory so that it downloads the npm ping module. When I delete the ping module I get the error you do, and when I run the command above the error goes away.
                        D pugslyP 2 Replies Last reply
                          derek7467 @BenNewsome
                          @BenNewsome any easy way to change the text color? I’m able to change text size via custom.css but the color doesn’t seem to take.
                          • Mykle1M
                            Mykle1 Project Sponsor Module Developer @ianperrin
                            @ianperrin said in MMM-NetworkScanner:
                            there no such thing as a stupid question so keep asking away…
                            Hi, and please help. Thank you.
                            I’ve got this module running but the only devices that will show as active are the Github from the sample config and the showUnknown devices which I have turned off. All others that I have added appear as offline. I’m using the MAC addresses that I got from my router and they are correct and all in lower case. I read above where that might be an issue. I did git pull and npm install in the MMM-NetworkScanner folder.
                                    		module: 'MMM-NetworkScanner',
                                    		position: 'top_left',
                            			devices: [
                            				{ ipAddress: "github.com", name: "Github", icon: "globe"},
                            				{ ipAddress: "192.168.1.4", name: "MykleDesktop", icon: "desktop"},
                                                		{ macAddress: "mac.address.all.lower.case", name: "DoveMBP", icon: "laptop"},
                                                		{ macAddress: "mac.address.all.lower.case", name: "MyklesiPhone", icon: "mobile"},
                                                		{ macAddress: "mac.address.all.lower.case", name: "JayAndroid", icon: "mobile"},
                                                		{ macAddress: "mac.address.all.lower.case", name: "DonnaMBP", icon: "laptop"},
                                                		{ macAddress: "mac.address.all.lower.case", name: "DonnaiPhone", icon: "mobile"},
                            				{ macAddress: "mac.address.all.lower.case", name: "NikkiiPhone", icon: "mobile"},
                                        			showUnknown: false,
                                    			showOffline: true,
                                    			showLastSeen: true,
                                    			keepAlive: 180,
                                    			updateInterval: 10,
                                    			residents: "Mobile", // I tried this with each name of the devices above and each icon name
                                    			occupiedCMD: {notification: 'TEST', payload: {action: 'occupiedCMD'}},
                                    			vacantCMD:   {notification: 'TEST', payload: {action: 'vacantCMD'}},
                            D 1 Reply Last reply
                              derek7467 @Mykle1
                              @Mykle1 looks like when i use IP, it shows offline vs online accurately. When i use MAC or a web address, it doesnt. Something is wrong with the scan by mac option.
                              • pugslyP
                                pugsly @BenNewsome
                                @BenNewsome
                                Removed it, did a new clone, and ran the npm install (See Below). Still getting the error that ping is missing and all of my MAC machines are grayed out.
                                pi@MagicMirror:~/MagicMirror/modules/MMM-NetworkScanner $ cd …
                                pi@MagicMirror:~/MagicMirror/modules $ sudo rm -r ~/MagicMirror/modules/MMM-Netw orkScanner
                                pi@MagicMirror:~/MagicMirror/modules $ git clone https://github.com/ianperrin/MM M-NetworkScanner.git
                                Cloning into ‘MMM-NetworkScanner’…
                                remote: Counting objects: 132, done.
                                remote: Compressing objects: 100% (16/16), done.
                                remote: Total 132 (delta 6), reused 0 (delta 0), pack-reused 116
                                Receiving objects: 100% (132/132), 80.07 KiB | 0 bytes/s, done.
                                Resolving deltas: 100% (74/74), done.
                                Checking connectivity… done.
                                pi@MagicMirror:~/MagicMirror/modules $ cd /home/pi/MagicMirror/modules/MMM-Netwo rkScanner && npm install
                                ping@0.1.10 node_modules/ping
                                └── q@1.4.1
                                sudo@1.0.3 node_modules/sudo
                                ├── inpath@1.0.2
                                ├── pidof@1.0.2
                                └── read@1.0.7 (mute-stream@0.0.7)
                                mm-0 (out): { macAddress: ‘18:b4:30:1d:f6:50’,
                                mm-0 (out): name: ‘Nest Thermostat’,
                                mm-0 (out): icon: ‘dot-circle-o’ },
                                  derek7467
                                  Only difference between you and I is you run the install with the &&. Remove it again, rerun from the beginning and manually CD into the directory and run the install from there. Skip using the && to install all in one shot.
                                  pugslyP slametpsS 2 Replies Last reply
                                  • pugslyP
                                    pugsly @derek7467
                                    @derek7467
                                    as you said, IP works fine MAC doesn’t… MAC was working up until the update where you could add the ‘last seen xxx min ago’ option.
                                    D slametpsS 2 Replies Last reply
                                      derek7467 @pugsly
                                      @pugsly yea I’m in same boat. I haven’t read all the code just yet but I imagine the way it performs the ARP scan by Mac is the culprit. For now I set my untangle router to serve out static DHCP leases and thus my problem is gone.
                                        Speedy-one
                                        Me too o.O
                                        • slametpsS
                                          slametps @pugsly
                                          @pugsly Unfortunately, mine is not working anymore, neither MAC or IP. :sob:
                                          regards,
                                          Slamet PS
                                          • slametpsS
                                            slametps @derek7467
                                            @derek7467
                                            @derek7467 said in MMM-NetworkScanner:
                                            Still no luck. Neither MAC or IP.
                                            regards,
                                            Slamet PS
                                            Mykle1M 1 Reply Last reply
                                            • 2 / 6
