    MMM-NetworkScanner
    networkscannerstatusmac address
    117 Posts 32 Posters 258.7k Views 33 Watching
    • pugslyP
      pugsly @BenNewsome
      @BenNewsome I see that it installed two things under \Magicmirror\modules\MMM-NetworkScanner\node_modules
      one dir called ping which is what the error says it can’t find
      the other called sudo (that one kinda worries me).
      Anyway it still doesn’t work.
      B 1 Reply Last reply
        BenNewsome @pugsly
        @pugsly Hi pugsly,
        sudo is for arp-scan which is the MAC address checker as this requires sudo to be called.
        Ping is the one I added which just calls the ping command from node.
        Could you try editing the file: /home/pi/MagicMirror/modules/MMM-NetworkScanner/node_helper.js
        On line 10 it says
        const ping = require('ping')
        Could you replace it with:
        const ping = require("ping");
        (Change the speach marks and add a semicolon.)
        I have no idea if this is the reason as it works fine on my system, but it is my current best guess.
        pugslyP 1 Reply Last reply
        • pugslyP
          pugsly @BenNewsome
          @BenNewsome Sorry… same thing, still says can’t find module ‘ping’.
            BenNewsome @pugsly
            @pugsly I think I have managed to replicate your error.
            Could you run the following command.
            (cd /home/pi/MagicMirror/modules/MMM-NetworkScanner && npm install)
            npm install needs running from the module directory so that it downloads the npm ping module. When I delete the ping module I get the error you do, and when I run the command above the error goes away.
            D pugslyP 2 Replies Last reply
              derek7467 @BenNewsome
              @BenNewsome any easy way to change the text color? I’m able to change text size via custom.css but the color doesn’t seem to take.
              • Mykle1M
                Mykle1 Project Sponsor Module Developer @ianperrin
                @ianperrin said in MMM-NetworkScanner:
                there no such thing as a stupid question so keep asking away…
                Hi, and please help. Thank you.
                I’ve got this module running but the only devices that will show as active are the Github from the sample config and the showUnknown devices which I have turned off. All others that I have added appear as offline. I’m using the MAC addresses that I got from my router and they are correct and all in lower case. I read above where that might be an issue. I did git pull and npm install in the MMM-NetworkScanner folder.
                        		module: 'MMM-NetworkScanner',
                        		position: 'top_left',
                			devices: [
                				{ ipAddress: "github.com", name: "Github", icon: "globe"},
                				{ ipAddress: "192.168.1.4", name: "MykleDesktop", icon: "desktop"},
                                    		{ macAddress: "mac.address.all.lower.case", name: "DoveMBP", icon: "laptop"},
                                    		{ macAddress: "mac.address.all.lower.case", name: "MyklesiPhone", icon: "mobile"},
                                    		{ macAddress: "mac.address.all.lower.case", name: "JayAndroid", icon: "mobile"},
                                    		{ macAddress: "mac.address.all.lower.case", name: "DonnaMBP", icon: "laptop"},
                                    		{ macAddress: "mac.address.all.lower.case", name: "DonnaiPhone", icon: "mobile"},
                				{ macAddress: "mac.address.all.lower.case", name: "NikkiiPhone", icon: "mobile"},
                            			showUnknown: false,
                        			showOffline: true,
                        			showLastSeen: true,
                        			keepAlive: 180,
                        			updateInterval: 10,
                        			residents: "Mobile", // I tried this with each name of the devices above and each icon name
                        			occupiedCMD: {notification: 'TEST', payload: {action: 'occupiedCMD'}},
                        			vacantCMD:   {notification: 'TEST', payload: {action: 'vacantCMD'}},
                D 1 Reply Last reply
                  derek7467 @Mykle1
                  @Mykle1 looks like when i use IP, it shows offline vs online accurately. When i use MAC or a web address, it doesnt. Something is wrong with the scan by mac option.
                  • pugslyP
                    pugsly @BenNewsome
                    @BenNewsome
                    Removed it, did a new clone, and ran the npm install (See Below). Still getting the error that ping is missing and all of my MAC machines are grayed out.
                    pi@MagicMirror:~/MagicMirror/modules/MMM-NetworkScanner $ cd …
                    pi@MagicMirror:~/MagicMirror/modules $ sudo rm -r ~/MagicMirror/modules/MMM-Netw orkScanner
                    pi@MagicMirror:~/MagicMirror/modules $ git clone https://github.com/ianperrin/MM M-NetworkScanner.git
                    Cloning into ‘MMM-NetworkScanner’…
                    remote: Counting objects: 132, done.
                    remote: Compressing objects: 100% (16/16), done.
                    remote: Total 132 (delta 6), reused 0 (delta 0), pack-reused 116
                    Receiving objects: 100% (132/132), 80.07 KiB | 0 bytes/s, done.
                    Resolving deltas: 100% (74/74), done.
                    Checking connectivity… done.
                    pi@MagicMirror:~/MagicMirror/modules $ cd /home/pi/MagicMirror/modules/MMM-Netwo rkScanner && npm install
                    ping@0.1.10 node_modules/ping
                    └── q@1.4.1
                    sudo@1.0.3 node_modules/sudo
                    ├── inpath@1.0.2
                    ├── pidof@1.0.2
                    └── read@1.0.7 (mute-stream@0.0.7)
                    mm-0 (err): at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/electron-prebuilt/dist/resources/electron.asar/common/reset-search-paths.js:35:12)
                    mm-0 (err): at Function.Module._load (module.js:403:25)
                    mm-0 (err): at Module.require (module.js:483:17)
                    mm-0 (err): at require (internal/module.js:20:19)
                    mm-0 (err): at Object. (/home/pi/MagicMirror/modules/MMM-NetworkScanner/node_helper.js:10:14)
                    mm-0 (err): at Module._compile (module.js:556:32)
                    mm-0 (err): at Object.Module._extensions…js (module.js:565:10)
                    mm-0 (err): at Module.load (module.js:473:32)
                    mm-0 (err): at tryModuleLoad (module.js:432:12)
                    mm-0 (err): { Error: Cannot find module ‘ping’
                    mm-0 (err): at Module._resolveFilename (module.js:455:15)
                    mm-0 (err): at tryModuleLoad (module.js:432:12) code: ‘MODULE_NOT_FOUND’ }
                    mm-0 (out): { macAddress: ‘18:b4:30:1d:f6:50’,
                    mm-0 (out): name: ‘Nest Thermostat’,
                    mm-0 (out): icon: ‘dot-circle-o’ },
                      derek7467
                      Only difference between you and I is you run the install with the &&. Remove it again, rerun from the beginning and manually CD into the directory and run the install from there. Skip using the && to install all in one shot.
                      pugslyP slametpsS 2 Replies Last reply
                      • pugslyP
                        pugsly @derek7467
                        @derek7467
                        as you said, IP works fine MAC doesn’t… MAC was working up until the update where you could add the ‘last seen xxx min ago’ option.
                        D slametpsS 2 Replies Last reply
                          derek7467 @pugsly
                          @pugsly yea I’m in same boat. I haven’t read all the code just yet but I imagine the way it performs the ARP scan by Mac is the culprit. For now I set my untangle router to serve out static DHCP leases and thus my problem is gone.
                            Speedy-one
                            Me too o.O
                            • slametpsS
                              slametps @pugsly
                              @pugsly Unfortunately, mine is not working anymore, neither MAC or IP. :sob:
                              regards,
                              Slamet PS
                              • slametpsS
                                slametps @derek7467
                                @derek7467
                                @derek7467 said in MMM-NetworkScanner:
                                Still no luck. Neither MAC or IP.
                                regards,
                                Slamet PS
                                Mykle1M 1 Reply Last reply
                                • Mykle1M
                                  Mykle1 Project Sponsor Module Developer @slametps
                                  @slametps
                                  This worked for me. If you have FIOS you might want to try it. If not, if you have the ability to set static ip addresses in your own system, you could try that
                                  I went into my FIOS router and assigned a “static lease” on the IP addresses of the devices that would not show in NetworkScanner with their MAC addresses. Went back into my config.js and changed the macAddress to ipAddress for each device and put in the static IP addresses I just assigned in the router.
                                  It’s working now, all except for the machine I am working on now (my desktop). It doesn’t show as active, even with a static lease on the IP address. That’s sort of alright, as I really just wanted the cell phones to appear, which they do, but odd,
                                  For those with FIOS that want to try:
                                  Sign in to Verizon router. Click Advanced tab (almost top right). Click yes to proceed. Click IP Address Distribution bottom right. Click Connection List almost in the middle. On the left, find the device that you want to assign a static lease IP address to. On the right, in the Action column, click the Edit icon. Tick the Static Lease Type box. Click Apply. That is now a static IP address. GO back one page and look in the Lease Type column. It will show you the Static designation.
                                  Peace
                                  slametpsS 1 Reply Last reply
                                  • slametpsS
                                    slametps @Mykle1
                                    @Mykle1 I’m already assigned static IP for all my devices connected to the router. When I set config showUnknown: true, the module display all detected devices (of course only display MAC addresses in upper-case), instead displaying the proper device name I set in the config.
                                    regards,
                                    Slamet PS
                                    • Mykle1M
                                      @slametps Yes, at first the same thing happened to me.
                                      This might seem obvious but did you change your config.js to ipAddress instead of macAddress?
                                      • slametpsS
                                        slametps @Mykle1
                                        @Mykle1
                                        @Mykle1 said in MMM-NetworkScanner:
                                        I add new entries with ipAddress, but did not recognized. All displayed MAC (with showUnknown: true) already defined as entries with macAddress, but it said as Unknown devices.
                                        regards,
                                        Slamet PS
                                        • I
                                          ianperrin
                                          Hi all
                                          The updates last week seem to have introduced a few issues - sorry folks!
                                          I’ve quashed one bug with MAC Address scans which you can git pull from the repo to see if that helps, but there still appear to be a few others which need resolving.
                                          I am looking at it but please bear with me ;)
                                          “Live as if you were to die tomorrow. Learn as if you were to live forever.” - Mahatma Gandhi
                                          Mykle1M pugslyP 2 Replies Last reply
                                          Reply Quote 2
                                          • Mykle1M
                                            Shhhhh! Quiet! Genius at work!
                                            I am completely serious. I think you are a brilliant young man.
                                            Much success to you. :thumbsup_tone1:
                                            • 2 / 6
