    MMM-NetworkScanner
    networkscannerstatusmac address
    117 Posts 32 Posters 258.7k Views 33 Watching
    • Mykle1M
      Mykle1 Project Sponsor Module Developer @ianperrin
      @ianperrin said in MMM-NetworkScanner:
      there no such thing as a stupid question so keep asking away…
      Hi, and please help. Thank you.
      I’ve got this module running but the only devices that will show as active are the Github from the sample config and the showUnknown devices which I have turned off. All others that I have added appear as offline. I’m using the MAC addresses that I got from my router and they are correct and all in lower case. I read above where that might be an issue. I did git pull and npm install in the MMM-NetworkScanner folder.
              		module: 'MMM-NetworkScanner',
              		position: 'top_left',
      			devices: [
      				{ ipAddress: "github.com", name: "Github", icon: "globe"},
      				{ ipAddress: "192.168.1.4", name: "MykleDesktop", icon: "desktop"},
                          		{ macAddress: "mac.address.all.lower.case", name: "DoveMBP", icon: "laptop"},
                          		{ macAddress: "mac.address.all.lower.case", name: "MyklesiPhone", icon: "mobile"},
                          		{ macAddress: "mac.address.all.lower.case", name: "JayAndroid", icon: "mobile"},
                          		{ macAddress: "mac.address.all.lower.case", name: "DonnaMBP", icon: "laptop"},
                          		{ macAddress: "mac.address.all.lower.case", name: "DonnaiPhone", icon: "mobile"},
      				{ macAddress: "mac.address.all.lower.case", name: "NikkiiPhone", icon: "mobile"},
                  			showUnknown: false,
              			showOffline: true,
              			showLastSeen: true,
              			keepAlive: 180,
              			updateInterval: 10,
              			residents: "Mobile", // I tried this with each name of the devices above and each icon name
              			occupiedCMD: {notification: 'TEST', payload: {action: 'occupiedCMD'}},
              			vacantCMD:   {notification: 'TEST', payload: {action: 'vacantCMD'}},
      D 1 Reply Last reply
        derek7467 @Mykle1
        @Mykle1 looks like when i use IP, it shows offline vs online accurately. When i use MAC or a web address, it doesnt. Something is wrong with the scan by mac option.
        • pugslyP
          pugsly @BenNewsome
          @BenNewsome
          Removed it, did a new clone, and ran the npm install (See Below). Still getting the error that ping is missing and all of my MAC machines are grayed out.
          pi@MagicMirror:~/MagicMirror/modules/MMM-NetworkScanner $ cd …
          pi@MagicMirror:~/MagicMirror/modules $ sudo rm -r ~/MagicMirror/modules/MMM-Netw orkScanner
          pi@MagicMirror:~/MagicMirror/modules $ git clone https://github.com/ianperrin/MM M-NetworkScanner.git
          Cloning into ‘MMM-NetworkScanner’…
          remote: Counting objects: 132, done.
          remote: Compressing objects: 100% (16/16), done.
          remote: Total 132 (delta 6), reused 0 (delta 0), pack-reused 116
          Receiving objects: 100% (132/132), 80.07 KiB | 0 bytes/s, done.
          Resolving deltas: 100% (74/74), done.
          Checking connectivity… done.
          pi@MagicMirror:~/MagicMirror/modules $ cd /home/pi/MagicMirror/modules/MMM-Netwo rkScanner && npm install
          ping@0.1.10 node_modules/ping
          └── q@1.4.1
          sudo@1.0.3 node_modules/sudo
          ├── inpath@1.0.2
          ├── pidof@1.0.2
          └── read@1.0.7 (mute-stream@0.0.7)
          mm-0 (err): at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/electron-prebuilt/dist/resources/electron.asar/common/reset-search-paths.js:35:12)
          mm-0 (err): at Function.Module._load (module.js:403:25)
          mm-0 (err): at Module.require (module.js:483:17)
          mm-0 (err): at require (internal/module.js:20:19)
          mm-0 (err): at Object. (/home/pi/MagicMirror/modules/MMM-NetworkScanner/node_helper.js:10:14)
          mm-0 (err): at Module._compile (module.js:556:32)
          mm-0 (err): at Object.Module._extensions…js (module.js:565:10)
          mm-0 (err): at Module.load (module.js:473:32)
          mm-0 (err): at tryModuleLoad (module.js:432:12)
          mm-0 (err): { Error: Cannot find module ‘ping’
          mm-0 (err): at Module._resolveFilename (module.js:455:15)
          mm-0 (err): at tryModuleLoad (module.js:432:12) code: ‘MODULE_NOT_FOUND’ }
          mm-0 (out): { macAddress: ‘18:b4:30:1d:f6:50’,
          mm-0 (out): name: ‘Nest Thermostat’,
          mm-0 (out): icon: ‘dot-circle-o’ },
            derek7467
            Only difference between you and I is you run the install with the &&. Remove it again, rerun from the beginning and manually CD into the directory and run the install from there. Skip using the && to install all in one shot.
            pugslyP slametpsS 2 Replies Last reply
            • pugslyP
              pugsly @derek7467
              @derek7467
              as you said, IP works fine MAC doesn’t… MAC was working up until the update where you could add the ‘last seen xxx min ago’ option.
              D slametpsS 2 Replies Last reply
                derek7467 @pugsly
                @pugsly yea I’m in same boat. I haven’t read all the code just yet but I imagine the way it performs the ARP scan by Mac is the culprit. For now I set my untangle router to serve out static DHCP leases and thus my problem is gone.
                  Speedy-one
                  Me too o.O
                  • slametpsS
                    slametps @pugsly
                    @pugsly Unfortunately, mine is not working anymore, neither MAC or IP. :sob:
                    regards,
                    Slamet PS
                    • slametpsS
                      slametps @derek7467
                      @derek7467
                      @derek7467 said in MMM-NetworkScanner:
                      Still no luck. Neither MAC or IP.
                      regards,
                      Slamet PS
                      Mykle1M 1 Reply Last reply
                      • Mykle1M
                        Mykle1 Project Sponsor Module Developer @slametps
                        @slametps
                        This worked for me. If you have FIOS you might want to try it. If not, if you have the ability to set static ip addresses in your own system, you could try that
                        I went into my FIOS router and assigned a “static lease” on the IP addresses of the devices that would not show in NetworkScanner with their MAC addresses. Went back into my config.js and changed the macAddress to ipAddress for each device and put in the static IP addresses I just assigned in the router.
                        It’s working now, all except for the machine I am working on now (my desktop). It doesn’t show as active, even with a static lease on the IP address. That’s sort of alright, as I really just wanted the cell phones to appear, which they do, but odd,
                        For those with FIOS that want to try:
                        Sign in to Verizon router. Click Advanced tab (almost top right). Click yes to proceed. Click IP Address Distribution bottom right. Click Connection List almost in the middle. On the left, find the device that you want to assign a static lease IP address to. On the right, in the Action column, click the Edit icon. Tick the Static Lease Type box. Click Apply. That is now a static IP address. GO back one page and look in the Lease Type column. It will show you the Static designation.
                        Peace
                        slametpsS 1 Reply Last reply
                        • slametpsS
                          slametps @Mykle1
                          @Mykle1 I’m already assigned static IP for all my devices connected to the router. When I set config showUnknown: true, the module display all detected devices (of course only display MAC addresses in upper-case), instead displaying the proper device name I set in the config.
                          regards,
                          Slamet PS
                          • Mykle1M
                            @slametps Yes, at first the same thing happened to me.
                            This might seem obvious but did you change your config.js to ipAddress instead of macAddress?
                            • slametpsS
                              slametps @Mykle1
                              @Mykle1
                              @Mykle1 said in MMM-NetworkScanner:
                              I add new entries with ipAddress, but did not recognized. All displayed MAC (with showUnknown: true) already defined as entries with macAddress, but it said as Unknown devices.
                              regards,
                              Slamet PS
                              • I
                                ianperrin
                                Hi all
                                The updates last week seem to have introduced a few issues - sorry folks!
                                I’ve quashed one bug with MAC Address scans which you can git pull from the repo to see if that helps, but there still appear to be a few others which need resolving.
                                I am looking at it but please bear with me ;)
                                “Live as if you were to die tomorrow. Learn as if you were to live forever.” - Mahatma Gandhi
                                Mykle1M pugslyP 2 Replies Last reply
                                Reply Quote 2
                                • Mykle1M
                                  Shhhhh! Quiet! Genius at work!
                                  I am completely serious. I think you are a brilliant young man.
                                  Much success to you. :thumbsup_tone1:
                                  • pugslyP
                                    pugsly @ianperrin
                                    @ianperrin
                                    Yup good work on getting the updates…
                                    MAC is working again, but the entries are all duplicated. ;)
                                      Speedy-one @pugsly
                                      @pugsly same here -.-
                                      • slametpsS
                                        slametps @Speedy-one
                                        @Speedy-one said in MMM-NetworkScanner:
                                        I freshly install rather than update the module, and working flawlessly.
                                        regards,
                                        Slamet PS
                                        pugslyP 1 Reply Last reply
                                        • pugslyP
                                          pugsly @slametps
                                          @slametps Deleted the module and did a fresh install, still showing duplicate entries.
                                          • slametpsS
                                            slametps @pugsly
                                            @pugsly said in MMM-NetworkScanner:
                                            Lucky me. Btw, had you installed v0.0.1?
                                            regards,
                                            Slamet PS
                                            • 2 / 6
