    showRainAmount not working in 2.3.1
    9 Posts 4 Posters 2.6k Views 4 Watching
    • ? Offline
      A Former User
      This post is deleted!
      • yawnsY Offline
        yawns Moderator
        Please note it is true and false and not 'true' and 'false'
        • ? Offline
          A Former User
          • yawnsY Offline
            yawns Moderator
            That’s how javascript works. A string is always true, so 'true' is true, 'false' is also true, true is true and even 'MagicMirror' is true. Only false is false
            • ? Offline
              A Former User @yawns
              • yawnsY Offline
                yawns Moderator
                Good. Now with this being clear I have no idea why you don’t see the rain amount. Maybe it’s not provided for your location currently? I can check on my installation tomorrow
                • ? Offline
                    Mykle1 Project Sponsor Module Developer @Guest
                    @wesmininger said in showRainAmount not working in 2.3.1:
                    Im in Brooklyn NYC which should be pretty well covered as far as the data,
                    Depends on the reliability of the API data.
                    Greetings from Staten Island! :-)
                    • ? Offline
                      A Former User
                      Has anyone found a workaround for this? I plugged in 5375911 for a location which is Murrieta CA. The UI on openweathermap.com shows it getting “moderate” rain today so I expect that the data is there. I still did not see any indicator of rain on the MM widget though.
