    MMM-voice setup but MagicMirror wont display
    31 Posts 4 Posters 16.4k Views 4 Watching
    • C Offline
      cyberphox
      Run this from terminal
      cat /proc/asound/cards
      and see if your microphone is listed as : 1
        shazglass @cyberphox
        @cyberphox said in MMM-voice setup but MagicMirror wont display:
        this is the response:
        pi@raspberrypi:~ $ cat /proc/asound/cards
        0 [ALSA ]: bcm2835_alsa - bcm2835 ALSA
        bcm2835 ALSA
        pi@raspberrypi:~ $
          shazglass
          the one above I took the USB sound card out and plugged the mic directly to the pi.
          this one I did your command again with the sound card in the USB slot and mic connected to USB sound card:
          bcm2835 ALSA
          1 [Device ]: USB-Audio - USB Audio Device
          GeneralPlus USB Audio Device at usb-3f980000.usb-1.3, full speed
            shazglass @shazglass
            I have gone onto the pi itself and chossen the usb as an audio device with clicking microphone and microphone capture… but still shows the “error” in MM display.
            • C Offline
              cyberphox
              and you ran the dependencies script from the installers folder?
              • C Offline
                cyberphox
                mine was error cause i accidentally cloned into MMM-Voice…capital V and it didnt create the dic file…
                maybe try running npm start dev and see what errors you have in the console
                  @cyberphox yes, that I def did -was super careful with that.
                    @cyberphox heres what I get with the npm start dev…not sure I am doing this in the right dir. I checked the Capital V or v, and mine is def lowercase v
                    pi@raspberrypi:~/MagicMirror/modules/MMM-voice $ npm start dev
                    npm ERR! missing script: start
                    npm ERR! /home/pi/.npm/_logs/2018-04-07T15_24_32_070Z-debug.log
                      pi@raspberrypi:~/MagicMirror $ npm start dev
                      magicmirror@2.3.1 start /home/pi/MagicMirror
                      sh run-start.sh “dev”
                      Starting MagicMirror: v2.3.1
                      Loading config …
                      Loading module helpers …
                      Initializing new module helper …
                      Module helper loaded: MMM-EARTH
                      No helper found for module: MMM-CountDown.
                      Module helper loaded: MMM-voice
                      No helper found for module: MMM-QRCode.
                      All module helpers loaded.
                      Starting server on port 8080 …
                      Server started …
                      Connecting socket for: MMM-EARTH
                      Starting module: MMM-EARTH
                      Connecting socket for: MMM-voice
                      Starting module helper: MMM-voice
                      Starting module: newsfeed
                      Sockets connected & modules started …
                      Launching application.
                      https://epic.gsfc.nasa.gov/api/natural
                      Create new news fetcher for url: http://ewn.co.za/RSS Feeds/Latest News - Interval: 300000
                      MMM-voice: Checking files.
                      MMM-voice: Starting pocketsphinx.
                      Shutting down server…
                      Stopping module helper: updatenotification
                      Stopping module helper: MMM-EARTH
                      Stopping module helper: MMM-voice
                      Stopping module helper: newsfeed
                      • C Offline
                        cyberphox
                        is the dev window…check the console tab…look for errors
                        • 3 / 4
