    MMM-Loxone
    loxonesmart home
    94 Posts 11 Posters 99.1k Views 14 Watching
    • idoodlerI Offline
      idoodler Module Developer @bobbythemoh
      @bobbythemoh Yeah, looks like there are some files missing. I think a new installation is a good idea. You can first check if there are any problems with git status.
        sdetweil @bobbythemoh
        @bobbythemoh Do
        cd ~/MagicMirror
        git checkout -- modules/node_modules/node_helper/index.js
          bobbythemoh
          Hey guys, I was pretty busy in work this week, so i just wanted to redo the installation, then i saw your post @sdetweil That solved the issue for me! thank you so much for your help…
          • elmatttE Offline
            elmattt
            Hi ! this is working great !!
            it show my indoor temp in the forecast module, and presence works great.
            i have an issue, i want to show on the mirror the temp of another room (mine), but it show only : CHARGEMENT … (loading …)
            any idea ??
            Thanks :D
            • P Offline
              pavka28 @elmattt
              @elmattt
              Recieved the same
              Loading…&HELLIP
              Did you solve?
              idoodlerI 1 Reply Last reply Reply Quote 0
              • idoodlerI Offline
                idoodler Module Developer @pavka28
                @pavka28 @elmattt Can you guys please provide me your MMM-Loxone config without your credentials. Can you also please double check the UUID of the control you want to display.
                • idoodlerI Offline
                  @pavka28 @elmattt Any update, did you fix the issue?
                  • elmatttE Offline
                    elmattt
                    didn’t have time to test … sorry ! but i think i was doing the wrong thing… is it possible to double the module in the config ? and show another UUID for the second module ?
                    • idoodlerI Offline
                      idoodler Module Developer @elmattt
                      @elmattt I guess you want to show multiple controls, right? If this is the case you need to assign the observingUuids property an array of UUIDs, something like.
                      observingUuids: ["0eaf7a2f-0011-1f28-ffff2083eaf2523c", "12a97c52-00a6-aea9-ffffc00216fecef2", "10338564-033c-226f-ffff0b7b5fc746d6"]
                      Please provide the relevant part of your config.js without any crucial informations like IP, username, password, …
                      • P Offline
                        Phil__
                        Hello Everyone,
                        today i updated my MagicMirror Setup (and all modules).
                        Now i have trouble with the MMM-Loxone Module. My Display do not turn off, it shows a black screen instead turning off.
                        The pm2 log shows a interessting Message: " This is no Raspberry Pi, toggle the display is not supported!"
                        My Setup:
                        • Raspberry Pi 4
                        • latest Raspian Image with all Updates
                        • latest Updates for MagicMirror and Modules
                        Can anyone help me?
                        Phil
                        1|MagicMirror | MMM-Loxone Found room: Wohnzimmer
                        1|MagicMirror | [2020-09-25 12:57:13.716] [INFO] MMM-Loxone Search IRC for room temperature
                        1|MagicMirror | [2020-09-25 12:57:13.723] [INFO]
                        1|MagicMirror | MMM-Loxone Found IRC (WZ Raumregelung) in room Wohnzimmer
                        1|MagicMirror | [2020-09-25 12:57:13.724] [INFO] MMM-Loxone Check if presenceUuid is defined
                        1|MagicMirror | [2020-09-25 12:57:13.733] [INFO]
                        1|MagicMirror | MMM-Loxone Search LightControls and LightV2Controls in room
                        1|MagicMirror | [2020-09-25 12:57:13.735] [INFO]
                        1|MagicMirror | MMM-Loxone Found LightControl (Flur-EG Lichtsteuerung) in room Wohnzimmer
                        1|MagicMirror | [2020-09-25 12:57:13.737] [INFO]
                        1|MagicMirror | MMM-Loxone NotificationUuid: 0d314264-022b-0294-ffffed497d367efa
                        1|MagicMirror | [2020-09-25 12:57:13.738] [INFO] MMM-Loxone Enabling statusupdates
                        1|MagicMirror | [2020-09-25 12:57:13.798] [LOG]
                        1|MagicMirror | MMM-Loxone Successfully executed ‘dev/sps/enablebinstatusupdate’ with code 200 and value 1
                        1|MagicMirror | [2020-09-25 12:57:14.467] [INFO]
                        1|MagicMirror | MMM-Loxone Got room temperature: 23.5
                        1|MagicMirror | [2020-09-25 12:57:14.531] [INFO]
                        1|MagicMirror | MMM-Loxone Got lightMood change to: All off(778)
                        1|MagicMirror | [2020-09-25 12:57:14.534] [INFO]
                        1|MagicMirror | This is no Raspberry Pi, toggle the display is not supported!
                        • idoodlerI Offline
                          idoodler Module Developer @Phil__
                          Hi @Phil__,
                          I think the Raspberry Pi 4 works a little bit different that the 3 or so.
                          If MMM-Loxone can‘t toggle off the display it just fades in a black overlay to hopefully trigger the screens power saving mode.
                          I will have a look at it when my Pi 4 arrives.
                          Meanwhile I ask you to create an issue on the Github Repo
                            bobbythemoh
                            Dear Community and David,
                            I was operating the mirror for 3 years now without any issue but 2 weeks ago i destroyed it with an update. So i made a new setup and found out some things with MMM-Loxone where i need help. I did not change the hardware (still raspi 3B) - just new OS + Latest MM + Latest Modules.
                            “Fade Out” is default false according to documentation but my obervation is: If nothing is in the config - it is fading out - if I set fadeout: false, peresence is not working anymore. I think this is not working correctly.
                            The monitor is not switching off - its just getting black but no power safe option - so “wasting” 46 Watts all the time. i found a commit from 09.02.2022 where you removed “vcgencmd” because of compatibility issues - i found the passage in “node_helper.js” at line 314 - uncommented it and it works fine again.
                            CSS Style - The font became so much smaller - i would like to make it bigger i tried to edit it in custom.css file but it did not change fontsize - then i found out that there is a “MMM-Loxone.css” - why is there a separate css?
                            I tried to add the code below without success. How to make the font bigger?
                            Thank you in advance!
                             * MMM-Loxone
                             * idoodler
                             * MIT Licensed.
                             * Custom here your css module
                            .xsmall{
                            font-family: 'Roboto Condensed';
                            font-size: 30px;
                            line-height: 40px;
                            .small{
                            font-size: 30px;
                            line-height: 40px;
                            .medium{
                            font-size: 30px;
                            line-height: 40px;
                              @bobbythemoh I recommend u open an issue on the module GitHub page to engage the author. no guarantee they are looking at the forum
                                bobbythemoh @sdetweil
                                @sdetweil thanks, i will do so!
                                • 5 / 5
